Question about Nokia E75 Cell Phone
In my E75 3G connection,i am not able yo get tv
In my E75 3G connectioni am not able yo get tv connections.please help.
    Guru:
  • 274 Answers
To get tv, you need to subscribe tv service from your network provider
to do that just call to CC and ask the procedure to activate the service
Posted on May 12, 2010
How does it work? I need to connect it yo my tv to bring up channels
Your question is too generic to answer, please provide more information as to what you are trying to do. Get channels using a tuner? Are you using a cable box or satellite receiver? Please indicate Make and Model of television. Perhaps I could be more helpful with additional info.
Apr 17, 2015 | Televison & Video
How to connect my compaq 6710b yo tv
If your TV supports VGA you can connect using that or else the S-Video output should work.
If using S-Video make sure you have the correct signal for your tv. ie. NTSC or PAL. You also may have to enable that output by using the function keys on your keyboard. Lastly you may need to reduce your resolution to a size your tv supports 800x600?
If you could be more specific i may be able to help more.
Sep 27, 2010 | HP Compaq 6710b Notebook
Although the Freeview box is correctly installed with my TV,when the men button is pressed the only message to appear on the TV screen is No Signal,HELP!!
Ok, if you have "No Signal" that can only mean you must be selecting the wrong INPUT, when it is hooked up yo the TV, essentially the TV, is just a Display Monitor, and it doesn't use "Channels" anymore, it uses the AV, or EXTERNAL Inputs, any channel changing is done on the Freeview box. Make sure you are connected color to color, cables are connected. The antenna, goes into the freeview, the AV cables go to TV, taking the Video 7 Audio, from the Freeview box, to the "Screen" TV, set to the External input, that the "Box" has been connected too. Check your manual out.
May 08, 2010 | Televison & Video
In my E75 3G connection,i am not able yo get tv connections.please help.
Hello :
To get TV connections on your E75 , you need to change the access point to live . For example , if you are with AT&T , you need to change the access point from [ AT&T wap or AT&T net to AT&T live ] .
good luck .
rate please !
Mar 18, 2010 | Nokia E75 Cell Phone
How do i connect awa set top box with a dvd player and tv, setup yo tv is easy but i also want to use dvd player
Hi
Thanks for using FixYa. Please see this diagram to check the set top box, DVD player and TV connections---
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 26, 2009 | Televison & Video
2 Wire 802.11g wont stay connected
Hi, had the same prob. I was able to fix it. The file set you downloaded for the driver (TWWGPC_TEMP) has a file in it called Wireless Cfg, run that if you haven't already, that will configure the card. Then open the folder CMG and run the Setup file. This will install the Wireless Client Card Utility. In the utility add the network(s) you connect with to My networks. After I did that the intermittency of the connection went away. I hope it works for you too.
Dec 04, 2008 | 2wire (1000-000005-002) 802.11g/b Wireless...
No signals found when searching for channels at setup
you need to press the channel up button 3 times if yo get message as please connect av sources. then do the manual channel search for 2 times. it should solve the problem.
Oct 13, 2008 | Sanyo DP32746 32 in. LCD Television
I have no power to my 26 in. tv
try checking the fuse in the mains plug and also check the that the wires is all connected in the plug.Also try some other electrical appliance for eg.a hair dryer in the mains where yo are connecting the tv.
ricch
Sep 13, 2008 | Mintek DTV-263 26 in. TV/DVD Combo
Can not connect to router via a wireless connection.
You could try to manually set your IP address in the TCP/IP, the gateway and your ISP DNS
Jan 23, 2008 | D-Link DI-624 Air Plus XtremeG Wireless...
Nokia E75 Cell Phone Logo
47 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
