My Daenyx seems to be locked up by parental lock....the power light comes on but the tv wont turn on at all. Is there a way of reseting whatever the code may be?
Try this remote:
Bluesens T-3K-03
We tried it with a programmable ComGenius and it worked !!!!!
Posted on Jan 21, 2011
I have a Daenyx Model DN263D TV and I need to know how to unlock the parental control lock or reset it.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Unlock procedure and to override the password lock to many popular brand TVs are given.
Sep 11, 2015 | Televison & Video
Sansui TV/VCR/DVD combo
This solution is provided by one of our experts premtech
Child Lock
Combos
--Should have original remote. Press and hold the power button for 6 to 10 seconds
Combo Model T25208, V-Chip Forgotten Password
If you forget your password, simultaneously press VOLUME down on the TV/VCR front panel and the 0 number button on the remote for a few seconds. This resets the password and you can enter a new one.
Combo Model 13TVR62, V-Chip Forgotten Password
If you forget your password, press STOP/EJECT on the TV/VCR front panel and MENU on the remote simultaneously. This resets the password, but not the limits you’ve set.
Televisions with Parental Lock Feature
If you forgot your password for this feature, press the following buttons on the remote, one at a time. (Note: You must be in the password entry screen) Press, Mute, Display,Clear and Reset, this unlocks parental controls and you can now re-enter a new password.
OR TRY THIS..
Press and hold Menu on the TV AND volume down on the remote for 3 seconds. Nothing will appear on the screen, and the Parental Controls will unlock, and you can re-enter a new password with the LOCK PARENTAL CONTROLS
CTC169AU
Channels that have been locked can be viewed only when the PARENTAL CTRL function is set to OFF. This can only be done with the remote control-it can not be changed with the buttons on the front of the TV.
Therefore, after you turn on PARENTAL CTRL, you simply hide the remote control so that your children can not watch the locked channels. The locked-out channels will remain unviewable even if the TV is unplugged or the channels are autoprogrammed again. The only way to view locked channels is to use the supplied remote control to set the PARENTAL CTRL function to OFF.
The PARENTAL CTRL and the CHAN CTRL functions work hand-in-hand. The instructions below will first tell you how to turn parental control on or off with the PARENTAL CTRL function and then how to lock desired channels with the CHAN CTRL function.
1. Repeatedly press MENU to select SETUP MENU, and then press + or - to display setup functions. Repeatedly press MENU to select the PARENTAL CTRL function. . When this function is set to ON, PARENTAL CTRL is activated and any channels you locked with the CHAN CTRL function will not be viewable. . When this function is set to OFF, PARENTAL CTRL is deactivated and all channels are viewable.
2. To lock channels, press the MENU button to select the CHAN CTRL function. Select a channel you want to lock by pressing CHANNEL up or down. Then press +. The CHAN CTRL setting will change from NORMAL to LOCKED when that channel is locked. To return the channel to NORMAL, press the - button. Repeat step 2 for each channel you want to lock. If the PARENTAL CTRL function is set to ON while you are locking out channels, each channel will go blank as you lock it. When the PARENTAL CTRL function is set to ON and a channel which has been locked out is tuned, the TV will display the words PARENTAL CONTROL to let your kids know you have locked it.
CTC185's
If the front panel function buttons don't work, (menu, ch up/dn etc.) but the functions work normal with the remote, enter the "Channel" menu with the remote and turn "Parental Control" off.
CTC203's
In the event you have forgotten your password, perform the following procedure:
Press and hold for 3 seconds the TV button on the remote while pressing the menu button on the TV.
This procedure will turn off the parental lock and erase the previous password .
Another Possibility To Try For Various Models: If TV's in the Parental mode and askes for a password that's forgotten, Press menu on the TV, select Parental Lock #4 on menu, then with the remote press Mute, Display, Clear, and Reset buttons in sequence.
TX808 Chassis
If Parental Controls have been set and you don't know the password, do this:
Press and hold the volume down and the channel up buttons at the same time for 5 seconds.
Now you can reset the password to 0000, and using that password you can now access the V-Chip menus.
TV's (Made by Daewoo or possibly Apex, ie. GE model 24GP653)
The factory default pass code of 6688 is also the override code, in case the owner forgets their pass code. If that doesn't work, another place in the owners manual says to push Function and Mute on the remote at the same time. Function is the top right button.
Jun 28, 2008 | Sansui DTV2760 27" TV
Daenyx dn19
check the fuse to see if power is there, and see if light is blinking a trouble code.
May 29, 2014 | Daenyx Televison & Video
Reset parental lock for panasonic pt-53wx53
Hi, try this it works' on most pan. tv`s, ON REMOTE push the power button for at least 7 seconds, video-tek
Feb 11, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Tv wont work
The first thing to try is to reset the TV. It seems it may be locked in a parental mode or something. If you have the manual try to find a reset function. Otherwise you'll need to post the model of the TV since there are many configurations.
Nov 20, 2008 | Televison & Video
Hacker code maybe
Hi Karyne1975,
Initially, I would venture that the Parental Lock has been engaged and was set to the lowest level meaning the TV will not allow any channel to be displayed, they are all blocked.
To remove the parental lock, proceed to the Main Menu display, press on LEFT or RIGHT arrow key till Parental Guide Setting is highlighted. Before you can access, an entry code is required. The factory default is 1225 (that is if it has not been changed). Upon gaining entry, press on UP or DOWN and/or LEFT or RIGHT arrow keys to turn any entry in the MPAA-Rating and/or the TV-Rating to show U (unblock). Additionally, it may also be necessary to turn the RATE SETTING to OFF. Exit.
To my knowledge Parental Lock is not disengaged by full hard reset or unplugging from mains.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 26, 2008 | Apex Digital PF3230 32" TV
Parental lock
Child Lock
Combos
OR TRY THIS..
CTC169AU
CTC185's
CTC203's
TX808 Chassis
Mar 26, 2008 | RCA TruFlat 27F520T 27" TV
Problem with rca truflat 27f520t 27"
as you are seeing blue colour along with lines called retrace lines. solution 1 check supply to blue video circuit.& transistor. 2 check crt base for loose 3 check components in blue video circuit. 4 check for loose contact in connector. 5 check for signal processor called chroma ic.
Oct 01, 2007 | RCA TruFlat 27F520T 27" TV
Channel locked
with the tv off press and hold the volume down button on the tv & clear button on the remote for 5 to 7 seconds. perhaps you can borrow a friends remote for a day to fix it. good luck.
Apr 14, 2007 | RCA 27F530T 27" TV
Televison & Video Logo
248 people viewed this question
Top Televison & Video Experts
