Question about Dryers
Not blowing hot air to make the clothes dry. What's wrong.?
  • 269 Answers
I dont know the make or model but firstly is the drum turning if not then check the drive belt.If ok then it could be the safety thermostats or the heater thats faulty.
Hope this helped.
Posted on May 12, 2010
Ge front load dryer
Your issue probably causes by vent duck was blocked either at the rear or from inside the duck. Take off the vent where it hooks up to the rear of the dryer. Turn on the dryer, if it works with hot air again then you have to clean your vent duct. Else, you need a service man to find down what is wrong with the thermostat, burner, etc...
Oct 15, 2013 | Washing Machines
I recently had a water leak in the crawl space of my house. It is being dried out with several fans,and a dragon, blowing hot air under the hose. This will continue to go on for another week. Now I&#
Very likely.
Here's why.
Because of the real danger of overheating and fire, dryers are "loaded" with overheat switches which will shut thr dryer off if they get hot.
One reason is that lint catches fire so easily.
Here's hoping you problem will resolve soon!
Be blessed
Jan 27, 2013 | Kenmore Dryers
Dryer is running longer than usual, it's tumbling,
no make listed here...I would pull the hose off the back of dryer and see if a lot of air is blowing out of vent. if not, heres your answer a clogged filter area ..if air blowing out leave vent hose off and dry clothes with vent off for one cycle. if clothes dry with vent hose off..you have a venting issue and need your vent cleaned out...
May 15, 2010 | Dryers
AF Code flashes briefly; Clothes don't dry - vent clear
Remove the back of the dryer and chek the lint filter area from the lint catching filter to the exhaust tube. There is a blockage in airflow even though you feel the air at the exhaust there still insn't enough air flow to allow the proper drying of the clothes. This symptom that you gave clothes being hot but not dry the only cause for this is improper air flow
Dave
Mar 31, 2010 | Dryers
Dryer has heat in back but cloths won't dry.
Howdy: Some models have a little fan that blows the hot air into the drum. I do not know what model you have but I would start there. Sorry - Good luck - Doug
Dec 09, 2009 | Maytag Dryers
Our dryer does not blow hot air? The cloths do not
more than likely the heating element has gone out. if your clothes have no heat then the element is the most likely cause. you can get one for anywhere between $30 - $50. you'll need to know model and serial #'s. usually easy to replace.
Jul 30, 2009 | Estate Dryers
Dryer doesn't dry
no but are you sure your replacement parts are correct the cycle stat is usally running about 140 - 160 temps did you switch the high one and the cycling wires or parts?
May 12, 2008 | Dryers
Dryers Logo
41 people viewed this question
Top Dryers Experts
