Question about Refrigerators
Our jenn-air side by side refrigerator with ice-maker has a problem. Quite often it makes a buzzing sound which seems to be more frequent than is normal. There is water inside the freezer which solidifies into ice on the bottom and on the bottom of the door shelves. Then the refrigerator defrosts and the food melts. Then when you open the door water comes out. After clearing that up the whole cycle starts again. The freezer gets cold again ..... I tried turning off the ice-maker by lifting the wire switch but the problem still continued. There also seems to be water droplets )which can be ice or water depending whether the firdge is defrosting or not) inside the door. It seems that the water must be coming from the ice maker but I'm not exactly sure where it's coming from
    President:
  • 1,218 Answers
Good day,
You'll need to isolate the problem. Shut the water off to the machine to eliminate the ice maker as an issue. Clean up any mess left over and restart the machine with the ice maker set to the off position.
Run for a few days to test the quality of the cooling capacity of the machine. If it tests O.K. then the ice maker situation can be addressed.
Posted on May 12, 2010
Jenn-Air Side-by-side Refrigeration not making ice and leaks water underneath when ice maker arm is up
With the arm up in the ice tray, the water solenoid valve should be closed. When the arm drops, that tells the ice maker to open the water solenoid valve to fill the ice maker tray. It sound like the leak is at the inlet side of the water solenoid valve. On some models its not easy to get to, but follow the water line to it. Hope this is it for you. Good luck.
Dec 30, 2013 | Refrigerators
We have a Jenn Air Side-by-Side. Water dispenses without problem, but the ice maker has stopped making ice. Now, when we try to produce ice (by lowering the ice arm), the ice hose pops free of the...
It sounds like the tube you speak of is frozen with ice, so it expanded the tube. Try unplugging the refrigerator and allow or help the ice in the tube to melt. You likely need a new hose, as when water freezes it expands and it likely expanded the hose, which is why it will not stay on securely. ( I don't know without seeing it, but this seems plausible to me)
Nov 03, 2017 | Jenn-Air JSD2695KES Side by Side...
Water does not flow
first you should take the water feed off, clear all water out of tube going to ice maker.remoe ice maker and check the wiring and all looks good.hook water up,turn water on just enough to see you have waterflow yo ice maker.might need a towel or two in the freezer.replace icemaker,make sure bar on ice maker is down,turn water on full,give it 12hrs to make ice. good water flow-no ice--replace ice maker.
Jun 02, 2012 | Jenn-Air JCD2389G Side by Side...
Buzzing/humming noise with jenn-air bottom freezer
i have this problem too on my GE Profile. A youtube video seems to suggest a compressor problem. Turn off the fridge for a while and let it cool down and try again? I tried but to no avail. Would someone answer this? Please :)
Mar 21, 2010 | Jenn-Air Refrigerators
The ice maker in my Jenn Air refrigerator stopped working.
Check that there wasn't a clog in the line after replacing the filter. Make sure you get water going to the solenoid, if so, it may either be a clog in the solenoid or a fluke that it's no longer working.
Sep 10, 2009 | Jenn-Air JCD2389G Side by Side...
The refrigerator makes a noise about every 4 minutes, like a it is trying to start something i don't think it is the ice maker
sounds like ice maker . when noise is happening open freezer and listen to the ice maker and see .. it could be ice stuck in the ice maker and needs to be freed up......
Aug 12, 2009 | Jenn-Air JSD2789GES Side by Side...
Jenn-Air refrigerator is not making ice but it's dispensing water
It can take up to 24 hours for a new ice maker to make ice.  Check it tomorrow.
May 31, 2009 | Jenn-Air JCD2295HES Side by Side...
My Jenn Air refrigerator ice maker quit working
My Jenn-Air refrigerator (JRSD2790) quit making ice, dispensor works, water dispensor works. Do I need to replace the entire
ice maker?
bjones03@comcast.net
Mar 25, 2009 | Jenn-Air JCD2389G Side by Side...
Intermittant noise
hi thanks for the question that buzzing noise is probably coming from the ice maker water valve that's about the time it cycles i would not worry about its fine just a little noise thanks the appliance doc but if it s too noisy replace the water valve
Sep 20, 2008 | Jenn-Air JCD2389G Side by Side...
Regrigerator stopped, now freezer too.
It is due to the defrost timer is not working. Once it is replaced, you should be good for another year. The information is given by the repairman. I have this replaced two days ago. The MayTag part number is: 61005988.
Aug 07, 2008 | Jenn-Air JSD2789GES Side by Side...
Refrigerators Logo
87 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
