Question about Clarion ARX7370
How to remove the stereo from the sleeve or unlock the stereo from thesleeve
    President:
  • 676 Answers
You will need to use and thin but stiff piece of metal. You will need to remove the bezel around the radio, If the radio is a detachable face, you will also have to detach the face. Insert the the pieces of metal, about 3 inches long, on the sides of the radio. You will only have about a half inch sticking out. You will need to then carefully pry the radio out towards you. It will come out slowly and carefully. Good Luck.
Posted on May 12, 2010
JVC KD-S595 car stereo. Trouble removing
It depends what kind of car it's installed into and the mounting technique used. Removal keys apply only to a radio that has been DIN mounted (ie: metal sleeve utilized). Many vehicles or radio kits use the ISO mounting method which involves screwing into the sides of the radio to secure it. Keys will not help in this situation. The dash or radio trim must be removed to access the screws on the sides.
With the front trim of the JVC removed, you should be able to see the metal sleeve around the radio if it was used. If not, the radio was ISO mounted.
Dec 26, 2013 | Car Audio & Video
I have a toyota trueno 1992 and i want to put a new stereo in it
Go to the auto parts store and get a wire adaptor made for a 1992 trueno. It will plug into your factory harness. The wire colors are prematched to your sony and other aftermarket stereos. Just match the wire colors, splice with connectors making sure no wires are exposed. (A little electrical tape for good measure around splices helps). Then it just plugs in. If your factory stereo has mounts that screw onto the radio, unscrew them and attach them to the sony. Remove sleeve from radio and discard. The screw holes are already on the sony.
Dec 29, 2012 | Cars & Trucks
How to remove a deh 21001b from a vt commodore
He may have to get underneath the dashboard and see if their is a security strap or wire harness holding the radio into the mounting sleeve. It's common for installers to strap down the stereo to prevent thefts and other installer from easily taking the radio out. Have him keep trying.
Nov 26, 2012 | Pioneer DEH-2100 CD Player
I need the radio operating manual for a Jeep Patriot 2009 model. Where can I down load it from as the local dealer cannot seem to find a hard copy for me.
following is the procedure. u can also check ehow for more details.
  • Twist the negative cable off the terminal on the vehicle battery, using an adjustable wrench.
  • Remove the factory issue stereo. Pry off the radio trim bezel with a flat head screwdriver. Remove the four bolts on each corner of the radio. Pull the radio out the dashboard. Unplug the thick black radio antenna cable. Disconnect the wire harnesses from the rear of the stereo. Place the old stereo to one side.
  • Prepare the dashboard for the new stereo. Fit the radio installation sleeve provided with the aftermarket stereo to the radio installation kit. Feed the sleeve through the portal of the radio installation kit and bend the tabs on the sides of the sleeve to secure it in place. Feed the audio wiring of the Jeep and the radio antenna cable through the portal of the assembly and slide the assembly into the dashboard. Secure it in place with the bolts removed earlier.
  • Wire the new stereo. Connect the wiring of the stereo to the audio wiring of the Patriot, using a custom wire harness adapter. Push the connections together until they snap into place and test the connection by tugging gently on either end.
  • Plug the radio antenna cable into the alloted port on the rear of the aftermarket head unit.
  • Slide the connected aftermarket stereo into the prepared housing in the Patriot's dashboard. Click it into place in the radio installation sleeve, taking care not to trap any wiring.
  • Jan 03, 2011 | 2009 Jeep Patriot
    What's the best way to connect a PC (with DJ software) to a Fender PAssport 500 PRO (I want stereo input)?
    Best way is to use a 1/8 TRS (stereo) to 1/4 TRS (stereo) cable from the PC into the Stereo 1/4 inch jacks right below the RCA stereo input jacks.
    TRS stands for tip-ring-sleeve which means the jacks have the extra "ring" over a mono jack.
    Jan 28, 2010 | Fender Passport Deluxe 500watt Sound...
    Trying to install a CDE-9881 into a 93 Honda Accord, is the mounting sleeve the only hardware used, or is there a mounting bracket also. Stereo will go in dash, but is unstable, and cuts out.
    Take your radio unit out of the mounting sleeve and see if you can bend tabs to hold the sleeve more securely to the dash panel... Not the greatest mounts... look on top, bottom and sides...
    Nov 27, 2009 | Alpine CDE-9881 CD Player
    How can i replace the manufacture radio in my car and replace it with aftermarket car stereo
    You best bet, because of a warranty, is to have a professional shop install your stereo. But if you are like all of us guru's here, you like to get your hands dirty.
    First you need to remove the dash around your factory stereo. Be patient here and try not to break any of the dash. You may need to remove screws and pop loose plastic retainers located on the backside of the dash.
    Wire the after market stereo to the harness located below by maching the colors provided. Thank the stereo companies for making this simple. Use crimp connectors or solder your connections, which ever best suits you. Tape up any remaining wires with eectrical to minimize the chance of a short.
    Take the metal sleeve provided by the sereo you choose and install it into the install kit located below. Once you have removed the factory stereo, test fit the install kit and attach any tabs neccessary provided by the kit.
    Now take the aftermarket stereo and place into the sleeve you installe din the install kit until it clicks into its locks. Now, the harness you wired up earlier, plug it into the factory harness and then into you stereo. Hook up the antenna, you may need to purchase a antenna adapter. Now before you install the stereo, do a test run to make sure everything is working. Once you are content that it is all working, install the new stereo and then reverse the steps in removing the dash panel and stereo.
    Below are pictures of the needed hardware:
    Sep 14, 2009 | 2003 Pontiac Vibe
    How to hook up a kdc-105 kenwood in a sunfire
    There are 3 things you need to purchase for this install. 1) The factory spec install kit. 2) The factory spec additional wiring harness. 3) Antenna adapter.
    Find the easied way to remove the plastic cowling around the radio and ac controls. Usually you can locate screws helping to retain the plastic dash parts. Be careful not to break the plastic dash by taking your time and looking over and over the part ofr connection hardware. Once you have located and removed all/if any screws, carefully pry out on the piece you are removing. There are often metal clips on the back of the piece that also help to retain the dash. Once that is removed, unbolt/unclip the factory stereo and slowly pull it out of the dash. Remove the factory harness from the backside of the factory stereo. DO NOT CUT THE HARNESS!! The wiring harness you have purchased is designed to plug and play into the factory harness. All you hae to do is color match the Kenwoods harness with the one you purchased. When wiring the two harnesses together use connectors **** a **** connectors, crimp connectors so forth and so on. If there is wiring you will not be using, take some electrical tape and tape the bare wire. We don't want a short. Once you are sure and have doubled checked that all the wiring is secure and matched, reverse the order of disassembly.
    The plastic install kit should replace the factory radio size difference. Just remember to take the metal sleeve tha came with the kenwood and install it into the plastic install kit via the instructions provided. Slide the Aftermarket stereo into the sleeve you just installed. Then you are ready to make all the needed connections. Before you reassemble everything make sure to do a test run with your stereo. If all is well reassemble and jam on.
    Sep 10, 2009 | 1999 Pontiac Sunfire
    No mounting sleeve for my car stereo
    autozone or ebay will have it!
    thanks
    erik
    Feb 26, 2009 | Car Audio & Video
    Car Audio & Video Logo
    453 people viewed this question
    Top Clarion Car Audio & Video Experts
    xxxxxx xxx
    Marco Avila
    Marco Avila
    Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
