Question about Refrigerators
I have an hmg 21874 model refrigerator that keeps freezing up on me..this happens about once a month and I must take the inner panel off and defrost the coils in the freezer. It then works fine... I notice there is a defrost timer under the front of the refrigerator. Is this part still available and how likely is it that this is my problem..
aborcass
  • 2651 Answers
SOURCE: Freezer/refrigerator compressor running constantly
th ebi-metal is a thermostat which shuts the defrost heater on/off, but doesnt actually put the unit into defrost. if it were bad the defrost heater would never go on resulting in massive build up of ice on back wall of freezer, and noticable refrigeration sect. cooling.. dont know how you know the compressor never shuts down, but if that the case perhaps you have a sealed system/ freon issue. try removing the back panel of freezer section and check the evaporator coil. you shuld have an even frost pattern over the entire evap coil. if theres just frost over the top 1or 2 coils, and the rest of coil is shiny aluminum , thats an indication of a sealed system issue.( 5 year part warr by manufacture) def not a do it yourself issue...but that would,, depending on extent of restriction/loss of freon,, cause freezer to freeze and defrost eratically,and the compressor would be running constantly trying to achieve a good stable temp
Posted on Apr 02, 2008
SOURCE: ice maker on Admiral HMG 62165 side by side
check the lever in the ice bin. if it is stuck in the up position it thinks the ice bin is full and will not make ice. Just wiggle it to the down position.
Posted on Apr 23, 2009
SOURCE: My Ward, HMG - 1400 - 0, refridgerator coils will ice over
The problem sounds like the defrost thermostat is bad. I would replace it first.
Posted on Jul 09, 2009
AndreaBl
  • 218 Answers
SOURCE: i have admiral refrigerator HMG 21164 and it is
this is a problem that can only be solved by a professional so please get your local repairman on the line and have him come and take a look.
Posted on Jun 11, 2010
  • 1891 Answers
SOURCE: coils in freezer - freezes up and the refrigerator
the timer tell it when to defrost but the defrost terminator and heaters must be working . ( you probley need the heater. and if so replace the terminator also .. mm
Posted on Jul 03, 2010
My admiral model hmg-64184 is leaking water from the bottom of freezer
It sounds like you have a broken place in the door gasket that is allowing warm air to enter the freezer.
May 29, 2015 | Admiral 26 cu. ft. Side-By-Side...
Water insider refrigerator
I have water inside the fridge, icing on the bottom of freezer, objects on
bottom are freezing, but not items on top. It is a signature 2000, model # HMG, 21514 FROSTLESS REFER
Apr 12, 2013 | Refrigerators
Icemaker does not eject ice all the way so it freezes up on unit
The model number you provided is not a valid model number. Please verify the model number.
Mar 13, 2013 | Admiral 26 cu. ft. Side-By-Side...
Admiral- Model HMG 19153 Freezer is cold, but doesn't freeze What's the problem?
Is it set at max? Try switching to fast freeze. it bypasses the thermostat and may help find if it is faulty
Mar 27, 2012 | Refrigerators
Freezer portion doesn't freeze.
check settings. if good check if compresor is running. a relay on compresor could fail
Feb 10, 2010 | Maytag Admiral Top-Freezer Refrigerator
My mother inlaw has an admiral refrigerator model HMG 21154 the top draw on the left side keeps falling off when you pull it out. She said it had some kind of clip on it that broke. Can you help me fix it?
it seems to me that maytag has a service memo on this problem and that the fix is wider supports or guided . i would ck with ither maytag or your local parts dist and the fix is the only part suplied when ordering parts for this .. mm
Jan 18, 2010 | Refrigerators
Make and model numbers are important to give answers.
Jun 19, 2009 | Montgomery Ward Refrigerators
Admiral HMG 62163 water leaking internally & freezing in lower basket
good attempt, its actually a clogged drain thats backing up and your drain water is not able to leave refrig so it falls to bottom of freezer floor and eventually out the door. romve the items from the freezer and take the lower back wall off form inside, directly under the evaporator under all that ice there is a drain hole, youll need to clear that hole of iec( pouring boiling water down until you get a free flow of water then you can reassemble uint problem solved
Oct 25, 2008 | Admiral 26 cu. ft. Side-By-Side...
Not cooling
Replace the defrost timer about $20-30.00. One plug 2 screws. Mine was located on the bottom front behind the grill. (model HMG 24922) . Follow startup directions.
Sep 14, 2008 | Admiral 26 cu. ft. Side-By-Side...
Refrigerators Logo
78 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
