Question about BenQ FP71E 17" LCD Monitor
My benq lcd fp71e 17"
Weird colors on my monitor what to do please help if theres any driver for this monitor please tell me
Ive solved this by taking out my vga cable and plug in my dvi cable and ive done some settings on my ati control center i have x1300 512 mb all you need is change your settings that this lcd dont support plus this monitor is huge!!!!!!!!! thank you for your support lol
Posted on Mar 29, 2008
SOURCE:
How to get sound working on a Benq 17" FP71E?
is on the back audio input connector, and you can set audio levels on the monitor menu items.
Nov 06, 2010 | BenQ FP71E 17" LCD Monitor
When I try to turn the BenQ FP71E 17" LCD monitor on, the on/off button glows blue for around 1 second, the monitor screen comes on for around half a second and then they both turn off simultaneousely. Any...
Since Dell monitors are made by BenQ, please look at Dell photo albums.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 19, 2010 | BenQ FP71E 17" LCD Monitor
Benq FP71E, No Image Displayed
Try checking the settings in properties for this device to make sure they are as you left them. YOu can also uninstall the drivers for the card and reinstall them to see if that takes care of the issue.
Jan 05, 2009 | BenQ FP71E 17" LCD Monitor
BenQ FP71E 17 - how to open
There are 4 pieces 2 each around yellow invertor transformers.
Check visually for darkened back of the transistor.For reliable testing you need to desolder and test with an ohmmeter.Also check the FET Fu9024 or D10Pf for similiar problems.
What is your actual symptom?
Samir
Aug 20, 2008 | BenQ FP71E 17" LCD Monitor
BenQ FP71E 17 goes black during post
Hi...there,
With AC adapter it's to your left, a rectangle piece. Without, it's under you power supply w/ built-in inverter... the capacitors look like a tiny battery on the side it have voltages size ( example like 1000uf 16v ) Good lucks, have a nice day!
BeNQ FP71E Monitor won't display desktop
The problem seems to be with the monitor.When there is no Display,if you power-off and on again do you get a Benq Startup screen?If not the problem should be dry solder on the Invertor board.Try tapping screen lightly,if it comes on the problem is dry solder on Invertor board.
Provide feedbacj and rate this solution.
Samir
Jul 28, 2008 | BenQ FP71E 17" LCD Monitor
Mail me what you need samir @viziks.com.
Samir
Jul 27, 2008 | BenQ FP71E 17" LCD Monitor
BenQ FP72E 17" LCD Monitor Problem
The video card driving the monitor or the video section of the monitor circuitry is getting bad, probably a capacitor on the board.
srich
May 23, 2008 | BenQ FP71E 17" LCD Monitor
BenQ lcb monitor
Monitor blanks out due to problems with internal power supply, have a quilified technician take a look at it, BenQ LCD monitors have 3 years warranty
Feb 11, 2007 | BenQ FP71E 17" LCD Monitor
My moniter has these weird lines beside dark areas
i have the same monitor. you might be able to purchase new cords for the monitor or it might just be the monitor itself if it is you will need to get a new one.
Oct 23, 2006 | BenQ FP71E 17" LCD Monitor
BenQ FP71E 17" LCD Monitor Logo
104 people viewed this question
Top BenQ Computers & Internet Experts
Steve Allison
Steve Allison
Ekse
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
