Question about Sony Cyber-shot DSC-W50 Digital Camera
How too Hey, How would you check the connections for the ccd sensor in this camera? Any advice would be greatly appreciated. Jo x
    Novelist:
  • 198 Answers
You need to dissasemble the camera first. There is no way to check it otherwise. Also please be carefull near the main flash capacitor.
Even with the battery removed it still stores some 250 volts.
With the camera dissasembled, you should look for 2 ribbon like cables near the lens assembly (they are on the same side with the main board). The larger one is the CCD-Main board connection. The other one is a bit smaller and it is the lens mechanism controll connection. Check to see if both of them are firmly connected and eventually try to reconnect them.
I haven't see your reason for suspecting that connection. Please give more details about your problem.
Posted on Mar 29, 2008
Image does not show on screen
Sound like a CCD sensor problem; you will need to visit your local photo technician in order to solve it, CCD sensor need to be replaced.
CCD image sensor itselft; this is a few commun propblem the manufacturers have stated an intention to correct the problem free of charge, regardless of the current warranty status of the individual camera. For specific details on the repair process. Some of the advisories have noted that for cameras outside warranty, any camera problems unrelated to the CCD sensor issue will be treated as regular unwarrantied service, which is logical.
Check this CANON article: support-asia.canon-asia.com=notices-digitalcameras-lcd
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day
Feb 14, 2012 | Canon PowerShot SD1000 Digital Camera
Screen is black
Just as reference, check this Canon article: support-asia.canon-asia.com=notices-digitalcameras-lcd
Feb 13, 2012 | Panasonic Lumix DMC-TZ3 Digital Camera
The screen is red
Hi Karen:
a CCD problem would explain the lines on your pictures and the lines on the LCD (since the CCD is used to feed the live image). CCD (Charge Coupled Device) is one of the two main types of image sensors used in digital cameras.
Some symptoms of a defective CCD include distorted images or abnormal colors, scratchy purple lines, blank or black pictures, and/or black videos with good sound being recorded on the camera's flash card.
When a picture is taken, the CCD is struck by light coming through the camera's lens. Each of the thousands or millions of tiny pixels that make up the CCD convert this light into electrons. The number of electrons, usually described as the pixel's accumulated charge, is measured, then converted to a digital value. This last step occurs outside the CCD, in a camera component called an analog-to-digital converter.
In order to correct this issue, the repair facility needs to replace the CCD. This is not something you may do on your own; check this article for additional details: Bad CCDs. This, isn't a good new, but hope helps to solve it.
Thank you for using FixYa, have a nice day.
Jan 04, 2012 | Cameras
I have a Kodak EasyShare C813, I have had it for about 3 years now. The photos it takes are coming out mainly white, with what you have taken a photo of barely visible. It looks like the white balance or...
It's probably a loose connection between CCD and main board. It's a well know problem with these cameras or youre CCD is go to bad, if this is your cases, sorry but these are classic symptoms of a failed CCD imaging chip, and it's effectively irreparable.
Additional details in this link: http://www.fixya.com/support/t9529959-z612_pictures
Don't throw your digital camera away if it has a bad CCD and it is covered under this recall, get it repaired for free! The best part about having the manufacturer repair your camera under this recall is that they will inspect, test, calibrate and update the camera as well as replacing the CCD with an updated version that will not fail as the first one did. (Article Source: http://EzineArticles.com/2623638 )
Hope helps.
Jun 21, 2011 | Kodak Easyshare C813 Digital Camera
Samsung mini dv vp-d30 model fault
You propably have a problem with the ccd sensor, this type of camera has a sony sensor which was manifactured in 2002-2004,many camera having mounted the same sensor have the type of problem you are reporting.
Some manifacture, canon , jvc will change free of charge, but I don't think samsung does it.
Anyway , It should cost around 50€
Saluti
Dec 12, 2007 | Video Cameras
Camcorder viewfinder fuzzy image
Defective ccd imager!! company will replace this ccd imager free of charge. Year 2002 up to 2005 released unit has a factory defect ccd imager. the company recalled those units and replaced with a stronger version of ccd imager ( they are still doing it). check it out.
Oct 29, 2007 | Video Cameras
Problem with DVRTVR22E
first check the iris of the camera if it is opening,you will see this when you look inside the lens of the camera when you turn on and off the switch at camera mode if the iris is opening....if the iris is ok the second problem may occurs of your camera is the ccd image sensor...
Aug 19, 2007 | Sony Handycam CCD-TRV107E Camcorder
Problem with Sony Handycam
ccd image sensor of your camera is already damage...go to the sony service center for replacing the ccd...the model of your camera is one of the recall products due to the factory error of the ccd image sensor production...
Feb 07, 2007 | Sony Handycam DCR-HC20 Mini DV Digital...
Sony Cyber-shot DSC-W50 Digital Camera Logo
35 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
