Question about Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
Keep getting error 2075 when i try to use the kodak aio Home Center
  • Dazzy D May 13, 2010
    To resolve this error code: Close Home Center Software. Go to Start>Computer. Show hidden files and folders: Select Tools>Folder Options. NOTE: If the Tools menu is not available on the menu bar, press the key on the keyboard, and then a menu bar with the Tools menu will appear. Select the View tab. In the Advanced Settings, select Show hidden files or folders. Select Apply. Click OK. • right click on the Kodak icon on your desktop and select properties. •Then on the general tab select find target. Right-click AiOHomeCenter.exe.config and select delete to remove the file. Hide hidden files and folders: Select Tools>Folder Options. Select the View tab. In the Advanced Settings, select Do not show hidden files or folders. Select Apply. Click OK. Run Home Center Software to run as an administrator: Right-click the Home Center icon, then select properties. Select the Run this program as an administrator check box in the compatibility mode. Click OK. Open Home Center Software and print or scan a job.
  • 64 Answers
  1. Close Home Center Software.
  2. Go to Start>Computer.
  3. Show hidden files and folders:
    • Select Tools>Folder Options.
      NOTE: If the Tools menu is not available on the menu bar, press the <Alt> key on the keyboard, and then a menu bar with the Tools menu will appear.
    • Select the View tab.
    • In the Advanced Settings, select Show hidden files or folders.
    • Select Apply.
    • Click OK.
  4. • right click on the Kodak icon on your desktop and select properties. •Then on the general tab select find target.
  5. Right-click AiOHomeCenter.exe.config and select delete to remove the file.
  6. Hide hidden files and folders:
    • In the Advanced Settings, select Do not show hidden files or folders.
    • Select Apply.
    • Click OK.
  7. Run Home Center Software to run as an administrator:
    • Right-click the Home Center icon, then select properties.
    • Select the Run this program as an administrator check box in the compatibility mode.
    • Click OK.
  8. Open Home Center Software and print or scan a job.
Posted on May 13, 2010
    If you have a problem finding tools then folder options. Go into your control panel then go into folder options.
100-2070 home center
Right click on the KODAK AiO icon - select properties. Click on the compatibility tab and check "run this program in compatibility mode for:" and select your operating system. Then check the box for "run this program as an administrator". Click apply and run your KODAK AiO Home Center program. No more 2070 error.
Jan 26, 2012 | Kodak Office Equipment & Supplies
Hello my name is Amy and i recently had to do a complete system recover to my pc, Well when i went to reinstall my Kodak ESP.3 All-in-One Printer it loads the bojour and when it starts to install the Kodak...
Before you try re-installing it again, restart your computer. Sometimes installed programs require restart even if they don't force it on the user.
After restart try installing the software again, if it fails with the same error then your installer may be corrupt or not suitable for your OS. Go to the Kodak website and download the latest software and drivers for your printer. Here is the link. You will have to click on the right side on Downloads to select your OS and then search for ESP 5 will show up the results.
If you get the same error, check to see if you have the latest Service Pack installed (do a System Update for MAC). Update your computer and try again. By this time you have everything up to date and if it still won't work I'd say that there must be something corrupt into your OS.
Dec 05, 2010 | Kodak ESP 5 Printer
Error code 2075 when I download updates for Kodak ESP7 all in one
right click on kodak home center, select properties, compatability, check "run as administrator"
Mar 21, 2010 | Office Equipment & Supplies
Keep getting error 2075 when i try to use the KODAK AiO Home Center
Even i faced the same problem once, spent a lot of time talking with kodak support, it finally been solved. One of solutions they gave me takes effect, just delete all kodak files under "c:\users\<your user name>\appdata\", try it.
Mar 18, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak 5300 all in one printer will not scan. Cannot get on line with 5300 a10 home center program, tells me printer is not connected
try to unplug replug the usb cable of the printer.
You may also go to control panel printer and faxes and look for the printer of your 5300 now if you see 2 icons delete them both then exit to printer and faxes. and unplug/replug your USB cable then restart computer.
If this issue not solve try to uninstall the software and download the clearutility kodak.com/go/clear. then after doing this restart computer.
Nov 07, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Home Center will not open - getting Error Code 1-2010
uninstall the printer software complettly than reinstall it.
Sep 27, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
I have a kodak esp9 on win xp wireless connection. Constantly get the 1-2010 error code and kodak aio home center will not open and the printer will not connect any solutions?
  1. From your computer, access Device Manager.
    • For WINDOWS XP OS:
    • Right-click My Computer, then select Properties.
      • Select the Hardware tab, then Device Manager.
  2. Select View > Show hidden devices.
  3. Select Printers.
  4. Select Action > Uninstall.
  5. Select Action > Scan for hardware changes.
  6. Double-click the KODAK AiO Home Center icon. If the error occurs again, go to the next step.
  7. Set administrator rights for the Home Center application:
        • Right-click on the Home Center icon.
        • Click Properties.
        • Click the Compatibility tab.
        • Clear all the check boxes.
        • Click Apply and OK.
    1. Double-click the KODAK AiO Home Center icon. If the error occurs again, go to the next step.
      IMPORTANT: In the next step, before you install the Home Center Software, make sure you disconnect the USB cable. Then, connect the USB cable when the software installation instructions tell you to do so.
    2. Upgrade the software and firmware for your printer:
Jul 17, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
The kodak aio home center won't open getting error 1--2010 esp3 printer
if using vista try this:
Select Properties.
Select the Compatibility tab.
Click Run this program as administrator.
Click OK.
reply if does not work.........
Jun 08, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kodak AiO home Center will not open
My son has the same model and issue. I had him go to http://www.kodak.com/global/en/service/downloads/dln_ekn034524.jhtml?pq-path=12667 and get the latest software and firmware update.
Make sure to use the dropdown to select your operating system. The page defaults to XP.
The software is a new version of the AIO home center.
The firmware installer updates the physical printer. Before you run this program be sure to read and understand the instructions.
If both ink cartridges have good levels of ink, and you keep getting the clean the print head issue after updating both the software and the firmware, then call Kodak support. 1-800-421-6699, 7 A.M. to midnight Eastern time, 7 days a week. They will ask you if you put in new cartridges and installed the updates for the firmware and the AiO centre software. Be patient. They will get a solution for you.
Jan 16, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak ESP 3 Multifunction Printer/ Copier/ Scanner Logo
341 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
