Philips TV turns off and on and has a very bad picture
I have the 19PFL5422D/27 - got it from Walmart in 2007. The picture is really bad with vertical lines and loud screaching sounds. It constantly turns itsel*** and on - used to last about 20 minutes then the tv would be fine - it constantly does this and cannot watch tv at all. I put it in the garage for about a year and now i am ready to fix it. Haven't found a solution yet.
    Problem Solver:
  • 11 Answers
Check electrolytic capacitors on the power supply board for bulged tops.
Posted on Jun 08, 2010
Phillips 19" flat screen
OK, I had the same problem and I fix it 100%.
The power board is ok, the lamps are ok, don't waste time there.
Just open the TV, remove the shield of the mainboard, and in the side where are the wires from the power board, there are many capacitors, check them, in my case 4 were "fat", exploded.
I had to change 9 to make shure, and that's all !!!
Saludos de Mexico!!!
Feb 21, 2010 | Philips 19PFL5422D Television
My philips 19pfl5422d tv turn on then turn off with no picture how do i fix it.
Power supply board is dead.Replaced the power supply board.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply.
Feb 15, 2010 | Philips 19PFL5422D Television
My tv when turned on goes to a black screen with 3 color strips of lines going across the picture then goes to a snowy picture but only shows on half the screen and then shuts off
This sounds like a vertical problem. It could be just a bad solder joint or it could be a IC that has failed and surrounding componets. Hope this is helpful.
Nov 30, 2009 | Philips 27PT5445 27" TV
I have problems with this 27pt5445/37 philips tv when I turn on the screen with vertical problems and within seconds it turns off and replace some capacitors and no improvement
Did you replace cap 2465, 100volt 10Mf to cure the vertical problem? and You may still have a bad cap at location 2415, 160 or 200volt 2.2 at 85 degrees. Check this out! When the tv tries to come on does it make a very good effort with the picture tube cracklin on and then shuts down? If this is true you may need a mosfet, located at 7404. Part# 934054713215. Good Luck! This is a smd!
Sep 28, 2009 | Philips 27PT5445 27" TV
First two inches of screen have no picture
maybe bad cap solder connection bad vertical ic thats the thing these newer tv are out of control w these ic good luck shad
May 02, 2009 | Philips Magnavox 27MS343S 27" TV
Philips tv model id: 19pfl5422d/27 terrible loud sound
The issue is 4 1000uF X 10V on the main board under the shield close to the connector that from the power board. you will see them because they will be FAT( exploded)
Feb 28, 2009 | Televison & Video
Horizontal lines on top of phillips tv
bad feedback electrolytic in vertical circuit. need tech.
Nov 23, 2008 | Philips TP2797B 27" TV
Philips flat screen TV MODEL ID 19PFL5422D/27
I bought the television less than a year ago, so I called Philips Magnavox and they asked for the serial and model numbers. Next thing I know they asked for my name and address and Philips is sending a brand new television to replace it !!! The new one should arrive in about ten days. How's that for service? I'm very happy that I bought Philips and I will do so again. So don't forget to keep all the paper work that comes with your new televisions,especially Model and Serial numbers ! Thanks for asking , Debbie Hoffman
Aug 17, 2008 | Philips Televison & Video
Philips TV showing horizontal lines model 27pt6441/37
You likely have an elevtrlytic capacitor bad on the B+ line to the vertical ouput ic. If you continue to use the set like this it is likely the vertical ouput ic will fail.
I’m happy to help further over the phone at https://www.6ya.com/expert/dewayne_4a10eab6caecdb92
Jun 26, 2007 | Philips 27PT6441 27" TV
Televison & Video Logo
196 people viewed this question
Top Televison & Video Experts
