Question about Bose SoundDock Digital Music System for Apple iPod - White
Female plug for i pod came off on 282490-001 board need new board
  • 26 Answers
  • ddanby2002 Apr 14, 2011
    do you ship to england
    also how much gbp included delivery
  • Robert Patterstine
    Robert Patterstine Apr 25, 2013
    you can get them on ebay
    Problem Solver:
  • 15 Answers
Invebo.com supply all docking parts and charge upgrade boards for Bose Sounddocks.
Posted on May 13, 2011
2 Suggested Answers
mark24354
  • 776 Answers
SOURCE: female plug for i pod came off on 282490-001 board
Don't bother doing it yourself, Bose has excellent customer service.
support@bose.com
1-877-210-3782.
Posted on Mar 18, 2010
Convert off board battery charger to work on rascal scooter
It has been done before, but you will violate the safety to do that and anything that happens with this scooter will be your fault! You will need a female electrical part for an XLR Plug to make it so the Male end from the charger will plug in. after wiring the Female connector and plugging the charger in the scooter will run while the charger is plugged in. This can cause safety problems.
Apr 03, 2014 | Electric Mobility Health & Beauty
What should I do to make f-pin coax coupler I bought (to link two coax cables to extend the range of my cable box) receive and display cable programs?
Female to female couplers will only connect to a male plug either side. If the two plugs are female you won't be able to do it, till you either change to two males or get a male to male coupler!
Sep 21, 2013 | Cable Wholesale F-Pin Coax Coupler, 1GHz...
I have a bose radio which is 8 yrs old..what i am trying to do is connect my mini I Pod to my bose...I have audio in and outon back of my bose...I tryed a cable which just has to male ends 91.CM AUDIO...
hi,
You need a STEREO to RCA cable for connecting you I pod to the audio input of you boss. you Can connect the stereo jack in the one end of the cable to the I pod and the RCA end to the boss's audio input L/R.
i have added the picture of the cable for you reference.
ok
Apr 04, 2011 | Bose & Wave& Music System
I just got a new Optoma HD20 and only after 1day of use it is not showing HDMI signal, although it is showing VGA signal. Why is this?
Hi miracles4all: I solved HDMI signal issue in my Optoma HD20. In my case it was the lack of contact between the HDMI cable plug male ending and the Optoma HD20 HDMI female port. My 35ft cable plug male HDMI ending was not completely "seating" in the Optoma HD20 HDMI female port. I solved the problem by purchasing a HDMI female to female coupler and adding a 3ft HDMI cable that had a slim male ending. This 3ft HDMI extension cable made better contact to the Optoma HDMI port and the projector was immediately able to detect HDMI signal. Hope this helps you... kaufmanekpr
Nov 05, 2010 | Optoma HD20 DLP Projector
Power cord will not light up where it is inserted into the laptop unless you hold it steady. It will not charge unless it is held in a certain position. Is the male part on the cord bad or is it the female...
You'll need to get another power cord that is identical in power and polarity and plug. One can buy a generic power supply from Walmart that will power most laptops or Radio Shack (Walmart is probably cheaper).
Once the new power supply is obtained, try it, and if the same thing happens, then the problem is in the female plug connection to the motherboard of the Compaq Presario C762NR Notebook.
The Notebook will have to be disassembled and the female plug connection to the motherboard will have to be replaced.
If the male plug end shows any fraying or excessive bending signs, then I would definitely replace the cord.
It is difficult to determine which is bad, the male or female part without changing the easiest part... the power supply.
Also, you could go to your local Compaq dealer and ask to plug in one of their power supplies to your computer and tell them the problem that you are having, determining which is bad, the male or female part of your power supply.
Good luck on this repair.
Aug 17, 2010 | Compaq Presario C762NR Notebook
support@bose.com
1-877-210-3782.
Mar 18, 2010 | Bose SoundDock Digital Music System for...
The F connector has broken off of a Sylvania model 6520FDG set
Replace the connector with a bit of cable and a new female end. Go to Walmart or BigLots, buy a 6' extender cable (6.00) cut off the female end with 6" of cable, strip it back and solder in in(?)
Go to Dollar Tree, spen a buck and get a 3-way splitter. Take home, saw apart and get the connectors off the board inside (3 of them(!)
or... Check Mouser, Allied, Newark, Radio Shack, Ace hardware for the part.
. Good luck
(You need a Female, F-Head, PCB Mount connector
Mar 26, 2009 | Sylvania 6520FDG 20" TV/DVD Combo
Broken Female audio plug
take a 1-1/2" safety pin, straighten it a bit, heat the tip, stick it inside the broken pin, let it cool then work it out w/the broken pin attached. I had the same problem & this worked.
Nov 05, 2008 | Onkyo Audio Players & Recorders
Broken sayno part
Hi wingshooter,
Your son is right. the 2 screw of the male should be fasten
to the hole of the female dvi. replacing the whole part
need careful de-soldering.
However, if the shield is still there and only the hole where
to screw in the male end of the cable, you can get from
old computer discarded around. you only have to remove
the two hex screw and replace it into your DVI female.
Observe that the head of these screws are hex, six corners,
and the hole is threaded. that threaded hole is where to screw in
the screw attached to your male DVI socke
Good luck,
siliconchips
Oct 31, 2008 | Sanyo Televison & Video
Bose SoundDock Digital Music System for Apple iPod - White Logo
1,077 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Ben Armstrong
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
