What is a carriage jam - Office Equipment & Supplies
  • 1,218 Answers
Here are some solutions for your carriage jam error.
1. Clear any jam...remove loose paper.
2.Clear the jam from the back of the printer
turn off the printer...remove the rear access door..
pull the paper out of the roller and return the rear access door.
3. Clear the paper jam from the front of the printer..while printer is on..open the carriage access door..
disconnect the power cable from the back.. remove the paper output tray.
look inside the product..check for torn papers..gently pull out the paper fromthe roller...return the paper output tray and the carriage access door. plugthe power corn and turn on..
4. Make sure the carriages move freely...while the printer is on.. open the carriageaccess doorwhat is a carriage jam - clip_image002.gifhttp://i.fixya.net/uploads/images/clip_image002.gif" alt="clip_image002.gif" class="h_mi" />
disconnect the power cord from the back..remove the paper output tray...lookinside if the carriage is stuck and if there is no papers or object that restrictthe carriage to move..return the output tray.. return the carriage accessdoor...
And lastly after doing this steps try to reset the printer and try to print..
To reset the printer....press the power button to turn on theprinter..disconnect the power cord from the product..disconnect the power cordfrom the wall outlet.. wait for 15 seconds.. plug the power cord to the wallsocket....plug the power cord at the back of the printer.. press the power onof the printer.. try to print the test page...
http://www.fixya.com/support/t6088190-hp_7400_displayshttp://www.fixya.com/support/t6088190-hp_7400_displays
Good luck! hope this solve the problem
Much appreciated if you rate this help.. thanks
Posted on Sep 28, 2010
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Scholar:
  • 53 Answers
A carriage Jam is an obstruction between the carriage movement on the rod. The carriage is a Device inside the printer which holds the printer cartridges. It helps the printer to print. It moves back and forth on the rod inside the printer and helps to print on the paper.
When the printer says carriage jam It means when the printer is trying to print some thing the carriage moves back and forth and during that movement some thing is obstructing the carriage to move back and forth.
If you have this problem ever on your printer try the steps in the link provided below.
link :-
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00786043&cc=us&dlc=en&lc=en
I hope it clarifies all your queries of a carriage jam ..!
You have a good day ..!
Posted on May 12, 2010
Carriage jam
Hi
The carriage door is the cartridges access door.Access the cartridges and make sure they're properly installed.To open:
  • Turn the machine on.
  • Open the cartridges door by lifting from the front center of the device until the door locks into place on its own.
Feb 27, 2012 | HP C6250 InkJet Printer
I'm getting an error msg and can't print. It says please fix cartridge jam and hit enter. I can't find any jam. What do I do?
If there isn't a cartridge jam then it's probably a carriage jam:
However, I'm not too familiar with clearing a carriage jam. I just know that if your cartridges are not blocked then the carriage is likely at fault. You will need to Google this on how to fix a carriage jam.
Jan 24, 2011 | HP OfficeJet 6110 All-In-One InkJet...
I just changed the (2) ink cartridges in my HP PCS 1610 All-in-One HP printer and now get an error message "CARRIAGE JAM - OPEN DOOR. CLEAR CARRIAGE JAM, AND THEN PRESS OK." I don't see any jam...
Have you tried moving the carriage to see if it really is jammed? Maybe you haven't put the levers down properly on your new cartridges....remove them, see if the carriage slides, then refit them and check the carriage again. You wont visually 'see' a carriage jam,; you have to try moving it. By the way, if it doesn't move, DONT force it to try and overcome the jam try and reason out why it doesn't move.
Hope this helps!
nicam49
Jan 18, 2011 | HP PSC 1610v All-in-One Printer
Carriage jam - Turn machine on, get carriage jam message, however the carriage can move freely if moved by hand. If I close and hit enter, carriage sounds like it's moving, then I get the error message...
Sorry about the B.S., you can move the carriage by hand, and all you need is to clean the encoder strip that runs across behind the carriage assembly. You can wipe the strip gently with an alcohol swab or a Q-tip moist with alcohol. The bars on that strip tell the carriage where it is and grease or ink on it will give the carriage jam error. No calibration necessary after moving the head or cleaning the strip.
Jan 07, 2010 | HP OfficeJet 7410 All-In-One InkJet...
Paper Jammed. Have appeared to remove all paper. But I keep getting "Carriage Jam, open door, clear carriage jam then pres OK" message. Message on my computer screen says "The print cartridge carriage is...
HP support has extensive documentation for both paper and carriage jams for your model:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00304007&lc=en&dlc=en&cc=us&lang=en&product=391182
I hope this helps!
Dec 10, 2009 | HP OfficeJet 7310 All-In-One InkJet...
My HP PHotosmart C4150 is reporting a carriage jam. I have removed all paper , opened the door, and reclosed it. It is not working. I cannot see any carriage jam.
Hi
Please see this link from HP, and check how to clear the carriage jam(link includes the pictures aswell)--
HP Photosmart C4150 Carriage jam Troubleshooting
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Jul 07, 2009 | HP Office Equipment & Supplies
Carriage jam
Usually when the printer displays a carriage jam error the carriage assembly is jamming along the carrige path.
There may be something in the carriage path or the carriage shaft may need lubricating.
Check the area where the carriage is has stoped. There might be an obstruction visible.
Jan 04, 2009 | HP Officejet J5780 All-In-One InkJet...
HP Officejet 5110 - Carriage Jam Message
I have an Hp Officejet 5110. I have an error message saying "Open door,clear carriage jam, then press enter". But where is its door? How can I clear the carriage jam?
I tried pressing the # & 6 at the same time, but the error message still there.
Mar 09, 2008 | HP OfficeJet 5110 All-In-One InkJet...
641 people viewed this question
jasbo
jasbo
