My MSI Wind Laptop case came apart at the screen hinges
My case came apartmust of opened the screen to far backwardsnow the laptop switches on and off on it's own with no apparent rhyme or reasondepending on how far the screen is opened or closed. The hinges of the screen seemed warped also Question Will I need to take it apart and line everything back up(hinge and power button) or do I need professional help? I have put in ram hard drives Cd's etc to desk tops but never had a laptop opened Thank you Benita Harris
  • Mark Zbylut
    Mark Zbylut May 12, 2010
    I would recommend professional help. This is a much more agressive repair than just opening a case for memory. But a Google search showed a NEW MSI Netbook for $360 at Walmart. A refurbished U100 sells for $123.00 at cedarPC.com
    Guru:
  • 551 Answers
Yes. you need a technicians or professional help on this... there might be problem on your unit.
Posted on May 13, 2010
Screen
There is a switch that controls the on/off of display when the lid is opened or closed. Sometimes it's located near the hinges. Perhaps it's been damaged, loose, dirty, etc. Unplug, remove battery, plug in, reboot.
Jun 01, 2013 | MSI Wind UmNotebook
Msi wind smoking from side
This sounds like the cable from the motherboard to the screen.
Feb 01, 2013 | MSI Wind U100-016US Laptop
Samsung R519 laptop screen blank -apart from when lid nearly closed??
There is a tiny on/off switch, that controls the backlighting when the lid is opened/closed, located near the hinges, usually, on a laptop, sometimes the switch will stick due to dirt ,dust, loose hinges...etc. locate the switch and free it from its obstructions, if any.
Nov 12, 2012 | Samsung R519-53S Notebook
Msi wind. when i open up the screen and switch on the screen wont come on
Yes, Barry.
You have a problem with the Video Cable,
http://www.ebay.co.uk/itm/New-MSI-NO11-LVDS-LCD-CABLE-K19-3030028-H58-MSI-Wind-U90-U100-U110-U120-/261099941400?pt=US_Laptop_Screens_LCD_Panels&hash=item3ccac4ee18
In the photo of the cable the Bottom connector shown, plugs into the back of the LCD screen.
The Top connector shown plugs into the motherboard.
(The wire with the metal loop on it is a ground wire )
Just from normal opening, and closing of the laptop, the video cable may become pinched, and pulling on the cable can result.
This may pull the connection loose at the motherboard, or connection loose at the back of the LCD screen, or both.
Happens a LOT. (Have seen it on here a lot, also)
How to solve the problem?
You have to open the netbook, and PHYSICALLY check. A visual check is NOT good enough.
All it takes is a slight disconnection that you cannot see.
If you Physically, check to make sure the cable is plugged in tightly to the motherboard, AND LCD screen, you are assured the connections are tight.
You can also test the laptop before reassembling, and make sure this is the problem.
You are going to need an ESD wrist strap, and connect it's alligator clip to a good ground source.
(Electro Static Discharge)
Access to the Video Cable for the motherboard connection, is accessed from the Bottom of the laptop.
You have to remove the Base Cover.
This means all Static sensitive hardware components will be exposed.
You Do Not want to Static shock your laptop, or you will be using it to skip across a lake with.
("Oh that? That's an old MSI Windstar U100 I tried to work on. I use it for a paper weight now.")
http://www.radioshack.com/product/index.jsp?productId=2103245
[ I connect to an unpainted surface, of the metal frame of an open, empty desktop computer case.
You can set a large metal serving tray (Unpainted), on the table you're working on, and connect to it.
You can also use a large metal knickknack (Unpainted), and connect to it ]
I do not have access to a clear, concise Service Manual, or pictorial disassembly guide, to give you.
What I DO have however;
1) http://www.laptopmag.com/advice/how-to/msi-wind-hard-drive.aspx?
Details on removing the Base Cover.
2) http://forum-en.msi.com/index.php?topic=145775.0
Under U200 (MS-1242) click on the blue -
http://forum-en.msi.com/moderator/assembly-guides/ms-1242-disassemble-sop.pdf
This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the above link it may take up to 30 seconds, before the first page comes up.
Not a Wind U100, I grant you, but information detailed crosses over.
Loose connection wasn't the problem? Then you need to take the Video Cable down to the nearest 'Mom and Pop' computer store, and have the tech use a multimeter to check continuity on all the wires in the cable. (Few bucks)
Regards,
joecoolvette
Sep 28, 2012 | MSI Wind U100-030US Laptop
Msi u100 casing around power switch broken
Try www.ebay.com type make and model of laptop, and scroll through the list.
Jun 12, 2012 | MSI Wind U100-030US Laptop
Cannot remove msi u100 bios password.
To reset the BIOS read the information from this link.
In case of your laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper.
Oct 14, 2010 | MSI Wind U100-030US Laptop
How to open msi wind to replace screen
this is a very difficult process if you do not know what you are doing but here is a link to help you. i got half way through and quit while i was ahead.
http://netbookmag.com/2009/02/26/tutorial-msi-wind-advent-4211-touchscreen-installation/#more-121
Feb 18, 2010 | MSI Wind U100-030US Laptop
Computers & Internet Logo
85 people viewed this question
David Payne
David Payne
