Question about Cobra 29 LTD CB Radio
I have a cobra 20 ltd and i cued it up with a break in my antenna wire and now i have no reception but i have power
    Champion:
  • 219 Answers
First make sure your mic is good this could cause you not to hear or transmitt if its bad. Then if you have an external speaker take it and plug it into your PA jack key up your mic, does it squeal if so then its not your IC chip if it doesn't it is your IC chip it will have to be replaced.Also make sure your speaker is good.
Posted on May 13, 2010
My cb will transmit ok but my reception range is not very far and I have a K40 trucker antenna
location of the antenna is every thing.the other thing to check is you swr.If your swr is to high your reception will be poor
Feb 20, 2011 | Cobra 29 LTD CB Radio
I have a cobra 25 ltd classic with a 102" whip. It
hello firstly it would be wise to connect your power lead directly to your battery secondly have you checked the vswr on the antenna make sure it is tuned to your radio i presume you have an swr metre and lastly check all coax connection make sure none are shortening out check pl259 at rear of radio and also check lead goin into antenna you can ajust the antenna by raising or lowering the whip .when you acheive 1.5 or better tighten up it should work ok for then
goodluck
Jan 09, 2011 | Cobra 25 LTD 40-Channels Base CB Radio
I have a Cobra CB RAdio What model I don not know? It's similar to the cobra 29 Ltd. It has at least 6 knobs/dials. Anyway...I can broadcast out very clearly. However, when I go around a corner or...
id check the coax conector first then the wire and antenna if its not the conector or the coax try a differnt antenna if you still have problems its internal with the radio
Apr 04, 2010 | Cobra Radio Communications
I have a cobra 20 ltd and i cued it up with a break in my antenna wire, and now i have no reception, but i have power
Replace the antenna wire.
If that does not fix it, the RF energy that reflected back blew out the transmit section of the radio and the receive section.
Mar 18, 2010 | Cobra 29 LTD CB Radio
Can't get reception, new antennas and new radio
yes that could be ythe problem if u have an external antenna, my comment was based on a more common built in antenna..
Nov 05, 2009 | Cobra 29 LTD CB Radio
Reception is very poor. Grounding issues? Please
Reception has little to do with grounding. The ground plan is for transmitting. As long as the coax is connected and is in good standing, it should receive fine regardless of grounding.
There are a few reasons you may have bad reception.
  1. Turn the RF GAIN all the way up. This is your receive sensitivity.
  2. Squelch is too high. It should only be turned up enough to cut out the background noise.
  3. Poor antenna. If the antenna is cheap, and not made well, this could be the problem.
  4. Not enough of the antenna above the vehicle. It needs to be at least 60% of the antenna above the vehicle.
Hope this helps!
Oct 21, 2009 | Cobra 29 LTD CB Radio
I have a cobra 29 ltd and sometimes i get some noise and sometimes doesnt i can here voices and its clear but i drive like 1 and a half and i lose that voice what would i need to do for the radio not to do...
What kind of antenna? How is this mounted? What type of car or truck are you using on? Antenna is the key to any radio.... Let me know some info I'd be gald to help...
Jul 23, 2009 | Cobra 29 LTD CB Radio
What Voltage Does The cobra 25 ltd classic use?
12 volts, around 15 amps. For a base station, try an Antron-99 groundplane antenna.
Jul 19, 2009 | Cobra 25 LTD 40-Channels Base CB Radio
Cobra 25 LTD - building causing a shadow area
The older base station was probably peaked and tuned by a CB shop, basically giving it a lot more power. Stock radios very rarely have a full 4watts of power, to tell you the truth. Mine now does 5 1/2 watts and swings to around 20 when I talk. Might be a good investment. Oh, the antenna can't be too big for any wattage. Might want to recheck the antenna's tuning, though...
The truckers wont pop the fuse at all, but I might recommend backing your RF gain down some when they are that close so they dont burn up your receive.
Jan 14, 2009 | Cobra 29 LTD CB Radio
No reception
Open it up,
check your speaker connections.
Check your antenna connections, Radio & Antenna
Check inside your mic connector for a broken solder joint on one of the pins. Otherwise, it could be a bad audio chip.
Maybe even a break at the antenna connector inside the radio.
If none of these, Radioshack has a reasonable repair service on many radios, cobra is made by uniden, who makes radioshack radios as well.
Aug 10, 2008 | Cobra 29 LTD CB Radio
Cobra 29 LTD CB Radio Logo
94 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
