When i try to change the screen resolution it is locked and it wont move at it is stuck at 640x480 how can fix it.
  • Viresh Kujur
    Viresh Kujur May 13, 2010
    Hi , please let me no what is the model no for the computer that u have and the operating system ,thankyou
    Guru:
  • 551 Answers
Reinstall your video card driver. it is corrupted.
Posted on May 13, 2010
Screen resolution desktop
go to control panel from start menu. change resolution to 1280
May 03, 2013 | Dell E2011H Monitor
I plugged in the pc with a dvi cable but no pict is showing,in the front pc connection the pict shows but the picture is rather 4:3 or full screen but very bad pict(changing the resolution on the pc)telll...
When you connect the DVI, try hitting the input, source, or conection button on the remote on TV. Some vendors use different names for the button. Use the procedure below to set the resolution for the second screen to 640X480 first, then move the resolution up one notch at a time to see what your TV can handle.
Many televisions don't allow an input through the VGA connector that's a higher resolution than 640X480. That is probably the format that you see appearing on screen where everything looks huge. You may be able to increase from that slightly after getting 640X480 working.
When you've made all the cable connections right-click on the desktop, then choose PROPERTIES from the bottom of the list.
A small window will appear with a few tabs on the top choose the last one, SETTINGS.
Click on the screen shown on this tab with a numeral 2 shown. On the middle-left you'll see a slider showing large and smaller at each end, bring it down to 640X480, then hit apply
A pop-up will appear asking you to confirm that this size is working, click yes if when it does.
Try increasing the resolution by a notch to see if the next size up works with your TV. If you see the Invalid Format on your TV again, you've gone higher than this particular input on your TV will accept.
To get a higher resolution signal you made need to switch to a different cable type, try DVI or HDMI. Either of the two should work more automatically than the VGA cable you are now trying.
If your computer only has a DVI port and the TV has an HDMI port you can get a cable that has DVI at one end and HDMI at the other by clicking here:
May 11, 2011 | Televison & Video
It is stuck in full screen how do i fix it
Hi,to adjust your screen,right-click on an empty space on the desktop,select Properties,a dialog box will appear,go to the settings tab,move to resolutions,move the slider to either 640x480 or 800x600 click ok and accept the other prompt which ask if you want to maintain these settings.
Dec 23, 2010 | Acer Aspire One Netbook 8.9" Notebook
My lap tops screen is stretched out so you have to move the mouse to see the whole screen, I did not do this on purpose and have no idea how to change it back. It's not the scrolling it's the actual...
Right click on your screen and select screen resolution under windows 7 or properties under XP. Change the screen resolution to one of the following: 640x480 or 800 x 600 or 1024 x 768
Sep 08, 2010 | Computers & Internet
How to get 1200 X800 resolution
It depends upon the notebook you use if it support the resoulution you want. You can change the resolution by display properties in control panel. Also 1280*800 is used only by widescreen desktop or laptops.
Mar 24, 2010 | Compaq Presario 700 470024-192 Notebook
Check for drivers from the manufacturers website or on a CD/DVD that came with the computer. It sounds like it does not have the correct video display drivers installed.
Mar 18, 2010 | Computers & Internet
The screen resolution will not change. One some computers this happens on, it is stuck at 800x600. Others, 640x480. Some are even stuck at 1024x768. The slider is movable and shows all available...
Seems to be a common problem: Here's one possible solution: http://ask.metafilter.com/76449/Dell-notebook-Vista-and-Screen-Resolution
I recommend you search the Dell forums, as they are likely to have received the most complaints and if there is a workaround someone will have posted it there....
May 02, 2009 | Dell XPS M1710 Notebook
Trying to connect my pc to a wharfedale lcd37f1080p using the standard moniter cable and am getting the message !out of range! on the tv
Change you screen resolution to lower resolutions, like 640x480, connect it. if you get video, move your resolution up and test which ones work for you TV. Try to stay under 1920×1080.
Dec 07, 2008 | Computers & Internet
My screen resolution wont go above 640x480 pixels,16 colors
that probably the highest ur screen can go unless u update ur video card u can purchase some really good video cards at Best Buy or Wal mart Looking to help u Shaun
Nov 15, 2008 | Dell Microsoft Windows XP Home Edition
Resolution change on my lap top screen when I load my webcam
I had this problem on my PC and I tried everything from updating drivers to re installing the software and updating my graphics card but nothing seemed to work.
And then as a last resort I right clicked on the icon on my desktop and chose properties and clicked on the Compatability tab and unchecked on display settings Run in 640x480 screen resolution.
This worked and did not affect the webcam in anyway.
Feb 16, 2007 | Acer TravelMate 4672WLMi Notebook
Computers & Internet Logo
David Payne
David Payne
