Question about JVC AV-56WP74 56" Rear Projection HDTV-Ready Television
Convergence Issue I would like you to post the step-by-step instructions
  • JVC Master
  • 8,617 Answers
As I mentioned in the last post. I dont have the step by step. The site that sells the replacement ICs include the step by step instuctions with the new ICs. Heres the link.
http://servicemanuals.vstore.ca/
Posted on Mar 29, 2008
SOURCE:
IQB50M90W 50" Rear Projection convergence issue
convergence chips need to be replaced. this can be done yourself but it takes ome soldering skills. Convergence repair kits can be purchased onlne for around $65. most kits come with step by step instructions, some have DVD repiar at shop can run $300 to well over $600 god luck.
Nov 30, 2013 | Zenith IQB50M90W 50" Rear Projection...
My tv shows doble colors how do i fix it
Thats a convergence issue. You can get the Phillips DPTV305 - DPTV335 convergence repair kit from www.tvrepairworld.com which fits your model and also includes the step by step instructions for the repair.
Jun 28, 2011 | Philips Magnavox 51MP392H Rear Projection...
Bottom 4 inches of my mitsubishi 65" rear projection tv is distorted. it seems like the colors aren't correct in this area. the rest of the picture is great. Justin
LOOK AT ATTACHED PHOTOS AND TELL ME IF THEY LOOK FAMILIAR.
THE MODEL INDICATED USES TWO of the STK-392-570 CONVERGENCE CHIPS.
I have step by step, start to finish instructions for this repair in this set. It involves getting the middle circuit board out of the set and replacing the two chips.
Total parts cost on EBAY WILL BE UNDER 25 DOLLARS AND repair takes on average about a hour--I have done hundreds of these sets and if you are doing it for the first time it may take longer.
The instructions tell you everything you will need and how to do the repair from start to finish and they are free.
If the information helped you, rate this solution as "very helpful: as I do this here for free.
If you want the instructions let me know and I will post them here for you for free. I will assist you from start to finish if you attempt the repair.
REGARDS, SD TECH
NO TWO SETS WILL LOOK EXACTLY THE SAME BUT YOU SHOULD KNOW IF WHAT THESE PICTURES SHOW IS YOUR PROBLEM.
Aug 11, 2010 | Mitsubishi WS-65809 65" Rear Projection...
I can't get the convergence on my ws 55511 hdtv to go away. I've tried with the remote. How can I get this corrected?
If the convergence will not adjust you have a convergence circuit problem.
This model uses a single STK-393-110 CONVERGENCE IC 129b244.jpg If you are handy and know how to solder it is a 12 dollar part on EBAY
I have start to finish step by step instructions for this repair in this set.
Most shops will charge 300 or more for this repair.
If you want the instructions let me know and I will post them here for free.
If this helped you rate this solution as I do this here for free.
SD TECH
Dec 16, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Appears convergence is not working. when i use the video button to see the convergence lines at the top and bottom of the screen the lines are curved which is causing the color and letters to be off on the...
WS-65511?
This model uses a single convergence IC chip----
STK-393-110.
The chip needs to be replaced and there are about a dozen light blue resistors in front of it that need to be checked also.
Considering you can buy the part on Ebay for about 12 dollars plus shipping---if you or someone you know can do it for you, you can save the set and a lot of money.
I have done hundreds of these repairs and I have had so many people here asking that I composed step by step-----start to finish instructions for this repair in this set----
The instructions tell you everything you will need to do the repair and are detailed.
I just today received a comment from someone who got the instructions tell me the repair went perfect and he now has a working TV again for a fraction of what a shop wanted to repair it.
If you want the instructions let me know, I am not allowed here to post MY email address, but you.....
If you have any questions or need advice let me know.
I am here to help people, I do this here for free.
SD TECH
Oct 28, 2009 | Mitsubishi WS-65511 65" Rear Projection...
Color
you need to install a convergence repair kit which should take care of that issue. Heres a link to the repair kit for your model. The kit contains the parts and step by step instructions on how to do the repair.
http://servicemanuals.vstore.ca/product_info.php/pName/av48wp30-convergence-repair-kit/cName/convergence-repair-kits
Jul 05, 2009 | JVC AV-56WP30 56" Rear Projection...
Philips 60pw9363 convergence issue
there is a convergence repair kit for ypour model which has both convergence ICs and all 12 Feed resistors at the following link. They also include step by step instructions with pictures of how to do the repair. Heres the kit for your model.
http://servicemanuals.vstore.ca/product_info.php/pName/phillips-dptv-305-dptv345-convergence-repair-kit/cName/convergence-repair-kits
Feb 03, 2009 | Philips 60PW9363 60" Rear Projection...
The red convergence is off
replace the convergence ICs post your model and I will post a link where you can get the parts and they include step by step instructions with pictures so you can do the repair yourself takes an hour and will save you about a 400 dollar repair bill.
Mar 30, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Convergence Issues
I dont have the step by step instructions. The site that sells the Replacement Convergence ICs have the step by step instructions that they include with the new ICs. Here is the link I am one of their support techs.
Mar 29, 2008 | Televison & Video
JVC AV-56WP74 56" Rear Projection HDTV-Ready Television Logo
Top JVC Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
