Question about Uniden BC60XLT Handheld Scanner
L/O on the screen only picking up 1 chanel - Uniden BC60XLT Handheld Scanner
    President:
  • 2,761 Answers
Do you have frequencies programmed into the other channels? Use the MANUAL key to advance through the channels. If each shows a frequency of 000.0000, you need to program the scanner. It will automatically show LOCKOUT for each unprogrammed (000.0000) channel.
Bill B
Posted on May 12, 2010
I have older vizio tv that is picking up 12 of the 15 possible digital chanels, plug my newer vizio in and got all 15 chanels is there something I can do?
Try using the TV's on-screen menu to manually add the channels or run another auto-scan. If done manually and the TV has no reception on these channels, the best you can do is to purchase a digital antenna which will provide more channels to a poor built-in antenna.
Feb 07, 2014 | Televison & Video
Auto tuner
Replace the tuner. It is faulty.
Apr 26, 2013 | JVC AV-36050 TV
How do I auto program my Zenith 20 inch lcd tv?
Click here to download the user manual to your Zenith TV. It has all details.
Sep 27, 2012 | Zenith Z20LCD1 20 in. EDTV-Ready LCD...
Cannot pick up all freeview chanels. no chanels above 68?
68 is the highest analogue channel there is in the UK. Digital freeview is around the mid frequencies usually, 28 to 40 ish.
Mar 31, 2011 | Televison & Video
Full signal picks up chanels but no picture or sound appears
i would think that your emu is turned off if you have a good signal you should have supplied us with more info on box and such
May 20, 2010 | StarTech.com StarView SV211K 2-port KVM...
I have an Edimax 802.11/n wireless adapter installed on a desktop. We moved and the new location barely picks up the signal from my Linksys access point. In my previous house, it did okay, although it was...
check your edimax setting for the adapter if teh wireless signal is the same as the routers chanel the edimax defaul channel is always set to chanel 1 for the signal of its wireless and if your router has a different channel most probably channel 11 or 6 which is the most likely chanel that many use
May 22, 2010 | Computers & Internet
Someone has pressed the lock-out button,press the L/O button,press scan. ...hope this helps...
Mar 18, 2010 | Uniden BC60XLT Handheld Scanner
I cannot find the code for my (ilo) brand TV from Wal-Mart and after the scan the scanner does not pick up on a channel I know is there. My friend has the working channel on his digital TV, but it...
try the Funai codes look on the back of your tv and see if Funai made it if so try ther codes. My Magnavox converter box wont pick up chanel 10 here for some reasion says no signal.works ok on all of the other chanels. Now if you have the orginal remote you should be able to go into the menu and go to add/delet and add that chanel to the scan if it has been deleted for some reasion.
Feb 21, 2009 | Televison & Video
Sony Bravia KDL 52 keeps turning itself OFF
i had prob where my sony would switch off for a few secs thenh come back on . The solution was in menu / tv settings / sleep timer . Go into that and make sure its set to off. there are opions for off , 5 min 20 min 30 min etc... mine was set to nothing just blank.
Apr 06, 2008 | Sony BRAVIA KDL-52W3000 52 in. LCD...
Problem with chanels on Magnavox LCD 20in TV/Monitor
check the tuner or the IF circuit they could be defected.good luck.
Apr 19, 2007 | Philips 20MF605T Television
Uniden BC60XLT Handheld Scanner Logo
90 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
AnyMHz.com
AnyMHz.com
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
