Question about Gateway FPD1975W 19" LCD Monitor
My monitor just died. No picture no nothing. Whats going on is it fixable or thats all I'm going to get from it.
  • 11,361 Answers
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed Gateway monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on May 12, 2010
My Sony HMD A200/L 17 In.CRT Conventional Monitor is completely black.
the clicking sound inside the monitor says that there is a signal coming from the computer. but if the computer video card is bard you never get picture. Yes this is fixable , sometimes some capacitors busted inside your desktop and have to be replaced or the video card is bad. depending of your computer tech experience , replacing capacitors is easy for experienced tech as me. if the video card is died there is a way to put in another video card.Go ahead check with your local computer tech,He will help you
Mar 16, 2012 | Sony HMD A200/L 17 in.CRT Conventional...
The top part (about one third) of my SyncMaster 920LM screen is brighter than the rest and seems to retain simultaneously the new and the previous picture for 2 to 3 seconds before it gradually fades out...
This is usually do to a section of your controller chips dying. This is not fixable by the end user, the only thing I could say to try is to try different resolutions to see if you can reduce the issue.
Mar 15, 2011 | Samsung SyncMaster 920LM 19" LCD Monitor
When i turn my computer on all my monitor does is show an Ember light iv tried all the basics like leaving it for awhile and unplugging everything and then putting it back in but nothing makes it turn on...
IT may have dying power supply due to bad caps as shown in my pictures here:
http://s807.photobucket.com/albums/yy352/budm/Dell%201704FPT/
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Replacement board: http://www.lcdrepair.us
Oct 21, 2010 | Dell 1704FPTt 17" TFT LCD Flat Panel...
No picture/power
It is fixable. Contact the service center for assitance.
Apr 06, 2010 | Hitachi 50UX58B 50" Rear Projection...
My monitor just died. no picture no nothing. whats going on is it fixable or thats all i'm going to get from it.
franccoperez
I would try your monitor on another computer to see if it works and/or try a CRT monitor on your computer and reinstall the video card drivers. I have seen a big issue with this lately where the video card drivers are getting corupted. When this happens the computer sends a signal out of range to the monitor causing it to turn off so it does not get damaged.
If your monitor does work on another computer and you need help reinstalling your video card drivers let me know.
Issken
Mar 18, 2010 | Gateway FPD1975W 19" LCD Monitor
Dell E173FP shows nothing
The backlight may have died. LCD monitors work by shining a light through the active diodes.
Feb 20, 2010 | Dell E173FP 17" LCD Monitor
Power light blinks but the screen is black and won't come on.
is it an LCD monitor?
if so then it's more than likely the backlight tubes or the backlight tubes inverter supply has died is it fixable but i am not sure how much it will cost you at your local repairer and monitors are so cheap these days its probably not worth it!
hope this helps,ben
Aug 13, 2009 | Computers & Internet
The monitor turns off and on repeatedly.
does sound like a power supply issue... they are fixable but it's somewhat involved.
Robert
Aug 28, 2008 | Acer AL1715 17" LCD Monitor
Gateway FPD1975W 19" LCD Monitor Logo
89 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
