Question about Invacare Supply Group Invacare Pronto M51 Power Wheelchair
Hi, I have a pronto m51. The yellow led in the
Hi I have a pronto m51. The yellow led in the joystick is flashing...
    New Friend:
    Problem Solver:
  • 5 Answers
By yellow light do you mean the yellow wrench at the bottom of the display. If that's the light that's flashing that's your service light. It will flash a specific number of times telling you what the problem is. If you count the number of flashes I can tell you what needs to be checked by a technician. If you can't count the exact number the first time you try that's ok the flashing will pause for a second then start over. It will flash 1-10 times depending on the cause.
Posted on Oct 29, 2011
  • Antoine Finch May 06, 2014
    mines flashes 9 times
  • 68 Answers
If it's the yellow battery light it will blink when the battery voltage is very low, too low to drive and lower than the red blink.
Posted on May 01, 2011
4 Suggested Answers
SOURCE: How do I charge My Pronto M51 motorized wheelchair?
I also have a Pronto M51 and use it daily. I have found though by leaving the charger plugged in over a weekend, it reduces the battery range and does not come back to normal until I use it for a week and charge it nightly. You can overcharge the batteries because the charger does not shut off entirely. I have monitored this with my meter.
Posted on May 13, 2009
SOURCE: pronto M51 ...the yellow light is blinks and dosen't stop
Take your drive units both out of gear and put them back in that will reset the computer and it started mine working again.
Posted on May 26, 2009
SOURCE: tool; light blinks 9 times battery is charged
the batteries were dead
Posted on Sep 07, 2009
Pronto power chair m51 will not engage
Sorry to read about your problem, 1st make sure the charger is unplugged, then restart, next make sure your free wheel levers located in the back left and right side are pushed into the drive position, if the joystick is scanning back and forth, turn off then on and push the horn button twice. The Joystick maybe flashing at you a code.Count the lights and how many are flashing, this is a flash code that can be looked up your manual that came with every Pronto. Strege Mobility
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
Sep 07, 2017 | Health & Beauty
How can I determine whether the on-board charger is working?
The m51 is notorious for failure of the on-board charger. An easy check would be to plug an off board charger into the 3 prong female charging receptacle at the front of the joystick to see if you can bring the voltage up. You can test the on board charger with a voltmeter at the battery connections or charger joystick port with the charger plugged in. Hope this helps
Jan 13, 2016 | Invacare Pronto M51 Power Wheelchair
Light come on controller no flashing code lights joy stick does not work
The M51 could have the motor clutch levers in the free wheel/push mode and the joystick will not blink if this is the case. Make sure that the chair cannot be pushed. If it can be pushed it means it is in free wheel and you need to lock the motors in gear.
If it is in gear and the joysticks green light does not change color or blink it could be that the joystick is bad. When nothing happens and the lights don't blink when you push the joystick knob the chairs controller basically isn't recognizing the joystick movement.
Time to have the joystick repaired or more. Have a technician look at it.
Jun 16, 2015 | Invacare Pronto M51 Power Wheelchair
Joystick lights flash red to green and repeat over and over. Just replaced batteries with new ones and can't operate joystick. Also the joystick yellow service light flashes at the same time. Do I need...
I hope you still have the batteries,as there is a service that can bring batteries back to life.Try contacting your nearest repair service for your product.There are charity run businesses that hire disability aids for getting around town for the day.Give them your question and ask about the battery service I refer to.I hope this helped you,Colin
Feb 27, 2015 | Invacare Pronto M51 Power Wheelchair
How do I adjust the seat height on a Pronto M51 with SPJ+ Joystick
The seat height can be adjusted by removing the seat and raising up the 4 seat pillars on the bottom frame. With the pivot seat model you can raise the center post seat pillar.
Feb 12, 2014 | Invacare Pronto M51 Power Wheelchair
My pronto m91 was flashing 5 times on the yellow led and after i resert it like you said it ran for a minuet and now it flashes 4 times on the bottom yellow led.
I am new to this request. Hope you have had your chair fixed by now, but in case not. If you still need help I really need more chair information. What joystick? Many different joysticks with different yellow lights. With a 4 or 5 blink it could be a motor or battery voltage problem.
Jan 11, 2011 | Invacare Health & Beauty
Invacare pronto m51 moving very slow. moves free and easy when in neutral
Check that the speed control on your joystick is set to high. If it is then you probably have a battery problem. Even with all the lights lit on the joystick you can have one battery of the two on the chair that is not charging fully. This will cause the M51 to creep and not work correctly
Aug 11, 2010 | Invacare Supply Group Invacare Pronto M51...
How do i know when my invacare pronto m5 is fully charged?
With an M51, a full charge will be indicated by all three joystick indicator lights lit- red yellow green. The green far right LED is the full charge light. Also the charger has indicator lights that go from red/yellow to full green at full charge. Hope this helps
Jul 11, 2010 | Invacare Pronto M51 Power Wheelchair
Control box on pronto m51 wheelchair don;t work
When you say "control box" I assume that you mean the joystick. If there is no power to the joystick be sure that the batteries are fully charged and be sure that they do not need to be replaced, also be sure that the cables were not put on wrong. If all that checks out then be sure that all the cables are tight.
If all these do not solve the problem then you need to have the joystick tested.
Oct 17, 2009 | Invacare Pronto M51 Power Wheelchair
Invacare Supply Group Invacare Pronto M51 Power Wheelchair Logo
662 people viewed this question
Top Invacare Supply Group Health & Beauty Experts
wcdoc1953
wcdoc1953
Robin Hill
Robin Hill
Are you an Invacare Supply Group Health and Beauty Expert? Answer questions, earn points and help others
