Question about Sanyo DVW-7100A DVD Player/VCR
Cannot remove progressive scan mode
I have a Goldstar 6711R1PO72J DVD / VCR remote control I pressed the wrong button. I'am now in progressive scan mode. the Screen has PROGRESSIVE SCAN MODE only. I can hear the DVD playing , but I have No image. What key sequence do I use to remove and/or reset The progressive scan. Thanks. I have the progressive light on and I can get sound but no image on the tv set. How do I turn off the progressive? I have tried to unplug the dvd and it still won't shut off.
  • Anonymous Jan 11, 2009
    ya but play didnt fix mine
I turned on the dvd player and pressed down on the play button and counted to 10, but before I got to 10 the progressive light went of and the image on my tv set came back on.
Posted on Mar 29, 2008
2 Suggested Answers
SOURCE: Cannot remove progressive scan mode
press stop and keep hold of the stop button while you eject the dvd, it worked for me, i played around with it and found pressing stop and holding it while ejecting works
Posted on Feb 12, 2008
How to get it off progressive scan mode
As with Goldstar and some JVC machines, the way to get progressive scan OFF is to do this:
with the unit on, but no discs inserted, on the front panel (not the remote) press and hold STOP button for 10 seconds, then release. This should revert the unit's video output back to normal interlace and switch progressive off. I hope this works for you.
Apr 16, 2011 | Zenith XBV443 DVD Player/VCR
DVD/VCR Combo - Zenith XBV342 Stuck In Progressive Scan
mi zenith xbv342 solo queda la pantalla azul y dice progressive scan mode como salgo de hay
Jun 14, 2009 | Zenith XBV442 DVD Player/VCR
Issues with my goldstar
Goldstar dvd/vcr combo was stuck in progressive scan. I used the posted solution and now it is out of progressive scan but it continuously reads the dvd and I cannot get the dvd to play. "Reading" conitues to appear on the screen. Any suggestions?
Thanks!
Patsy
Dec 29, 2007 | Goldstar GBV241 DVD Player/VCR
SD-K530SU - Turning Off Progressive Scan Mode
Once the setting for Progressive Scan output is entered,
an image will only be visible on a Progressive Scan compatible
TV or monitor. If you set Progressive Scan to On in
error, you must reset the unit. Pointing the remote at the
player, press the STOP (x) button to stop any disc that is
playing. Next, press the STOP (x) button again and hold it
for five seconds before releasing it. The video output will
be restored to the standard setting, and a picture will once
again be visible on a conventional analog TV or monitor.
Nov 06, 2007 | Insignia NS-DVDR1 DVD Recorder
Sep 30, 2007 | Televison & Video
MY DVD / VCR PLAYER MADE BY GOLDSTAR IS STUCK IN A MODE THAT SAYS PROGRESSIVE SCAN MODE ,HOW CA I GET OUT OF THIS MODE I HAVE A GOLDSTAR MDL #GBV441 THANKS
Stuck in Progressive Scan Mode??? Remove the disc(s) from the changer, make sure TV is on Blue Screen...should say "Progressive Scan Mode".......Simply press and hold the stop button for 5-10 seconds and it will reset.
Apr 29, 2007 | Goldstar GBV241 DVD Player/VCR
GoldStar DVD/VCR-progressive scan mode problem...``
Remove any DVDs from the disc player. You should be in Blue Screen mode on the TV...If it says "Progressive Scan Mode" ....make sure there is no DVD in it...close the disc changer and push and hold the "Stop" Button on the player, not the remote, for 5 seconds or longer. This has been proven to work every time!!!
Apr 10, 2007 | Goldstar GBV241 DVD Player/VCR
GOLDSTAR DVD/VIDEO PLAYER
Remove any discs from the unit. Make sure your tv is on the blue screen. It should say "Progressive Scan Mode"....After removing the disc(s) from the disc changer, close the changer, press and hold the stop button on the unit, not the remote, for 5 seconds or more and it will reset to normal playing mode. Progressive Scan is typically only for TVs that use Progressive Scan....most normal TVs do not use progressive scan mode. Hope this helps...It worked for me!!!!
Jan 20, 2007 | Goldstar DV7411N DVD Player
GBV441 Goldstar DVD Player / VCR Combo
this is the right solution, the solution in the User Manual doesn't work
Nov 04, 2006 | Goldstar GBV241 DVD Player/VCR
Turn off progressive scan mode
If you set progressive scant On by accident,you must reset the unit. Remove any disc from the unit and close the disc tray. See that "disc" is displayed on the display window. Now press STOP and hold it for more than 5 seconds before releasing it. The video output will be restored to the standard setting and picture will once again be visible on a conventional analog TV or monitor.
Sep 05, 2006 | Zenith XBV443 DVD Player/VCR
Televison & Video Logo
716 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
