Question about Garden
Hello. I've an older mtd Gold series tractor 14/42 model 133M660G513 serial # (mf code) 1A22313-0177. Last year near the end of the season I noticed it running great but having a bit less power going up hills. Just didn't quite have the speed it used to have in the higher gears. I just went to cut the grass for the 1st time this year and again the motor runs superb initially when I put it into gear and released the clutch/brake pedal.. Nothing happened. But by working the clutch/brake pedal I could make the tractor very slowly creep ahead. No power at all but a creep. Barely enough to get the tractor to crawl on the flat. The pedal had to be pushed down an inch to even make it do that. If I didn't press in the pedal an inch nothing moved. If I pushed the pedal in 2'' then again nothing moved. The pedal when untouched but in gear would bounce a bit. Never ever had a problem with this old girl and have never had to do any belts etc or anything on it. Does this unit even have a clutch? Is it shot? Is it a
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Garden Master
  • 915 Answers
Check and be sure there is no oil leaking from the engine on the belts and the belts are not oily. inspect the drive belts. as they get older they crack and stretch and don't work as the should. replace the belts as you said it is a older machine. there is nothing wrong with a older machine they just need attention every now and then.
Posted on Mar 09, 2017
2 Suggested Answers
huffman49
  • 235 Answers
SOURCE: Hello. I've an older MTD Gold series tractor 14/42
sounds like you will need to take it in somethings worn out in your trans. like perhaps the pressure plate..good luck
Posted on Apr 14, 2010
How to replace the cable that engages blade on an MTD 42" cut riding mower
Utube or ur library...has shop manuals. Do it slow n safe...dont endup the er
Sep 12, 2015 | Mtd Garden
MTD model number 13RL771H029. I purchased it in 2008 with 46" deck. Are all 3 spindles the same part number
I have an operator's manual for an MTD Model Series 760-770 Lawn Tractor. This Manual seems to indicate two different part numbers for the spindles on a 46" deck. One spindle is a Double Pulley, part number 618-04134B. The other two spindles are single pulley, part number 618-0240A.
However 760-770 is a series number. So this does not necessarily match your machine. The first question is what year is your Lawn Tractor? Following is a discussion of MTD serial numbers from 1997 till now. Pre 1997 is a different discussion.
The second question is what is your actual Model Number?
Locating Your Model and Serial Numbers
The model and serial numbers are essential to find correct MTD® genuine factory replacement part numbers for your outdoor power equipment. Once you know these numbers, you can use either the illustrated parts look-up tool or the operator's manual download to easily search for the correct part numbers needed.
What should my model and serial number look like?
MTD's current (1997 and later) model and serial numbers are generally 11 characters in length. A character could be a number, dash or a letter. If 0 represented all numbers and/or dashes and X represented all letters, the model and serial numbers should appear as follows: 00XX000X000.
These are made of both letters and numbers, and typically look like this: 11AA111A111.
Apr 11, 2015 | Garden
Can i have a mtd pro 800 series drive belt diagram please
Cant find the diagram without more info but if you go to the link I have here and enter your model and serial number it will supply you a manual and it will be there. If you need further help please contact me. thank you.http://manuals.mtdproducts.com/mtd/Public.do
Jun 07, 2011 | Mtd Drive Belt 42"
I need a manual for a 1998 or 1999 gardenway lawn tractor by MTD troybuilt Model #13AI617H118 Serial #1A082H10211 can you help? It's a 21H tractor 46SDIt's up above
Most of the MTD product manuals are available here: http://manuals.mtdproducts.com/mtd/Public.do?BrandCode=10001 . Just fill in the model and serial numbers.
I found two separate manuals listed: lawn tractor owner's guide and the engine operator's manual. I found the manuals only opened in IE (Windows OS) after clicking the I Accept button. The direct links are: http://manuals.mtdproducts.com/mtd/Safety.do?pid=152292&model_num=13AI617H118&serial_num=1A082H10211&filename=770-10317b.pdf and http://manuals.mtdproducts.com/mtd/Safety.do?pid=152290&model_num=13AI617H118&serial_num=1A082H10211&filename=274794.pdf .
I hope this helps.
May 14, 2011 | Mtd Garden
Have a MTD LavmFlite - model: 136-630-656. I need a manual
Hello. In order to obtain a manual for a MTD product, a complete serial number and model number is required. To save you the middle steps, here is the link to the Canadian Products Manual Download site:
http://www.mtdcanada.com/model-search.asp
... and the European Downloads site (just in case):
http://www.mtdproducts.eu/Corporate_Manuals.aspx
I'm confident you will find what you require at one of these sites.
Apr 12, 2011 | Mtd Garden
Garden Logo
63 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
