Question about Refrigerators
I have a GE side by side refrigerator model#LSS25XSW
I have a ge side by side refrigerator model# LSS25XSW. The ice maker does not produce ice. The light green light is on when I inser the the tray but begins shortly after that.
4 Suggested Answers
tborn6
  • 700 Answers
SOURCE: ice maker not working
you need to check the inlet screen on the solenoid down below for blockage, also make sure that the freexer is cold enough
Posted on Dec 26, 2008
MNTECH
  • 1543 Answers
SOURCE: GE Profile Fridge Model No. PSC25MSWA SS not making ice
Check to see if there is any obstruction (object of any kind) in the ice cube mold area. If nothing found, you will have to replace the icemaker, as individual repair parts are not available.
Posted on Aug 04, 2009
iwillfixforu
  • 619 Answers
SOURCE: I have GE LSS25XSW side by side refrigerator which
The ice solenoid located behind the control for the water and ice has gone bad. Inexpensive to replace. Thanks.
Posted on May 16, 2010
How to trouble shoot GE ice maker that is not producing ice
Here is some information for you to study
  • GE Refrigerator - Ice Maker Not Making Ice - Easy Fix and ... www.youtube.com/watch?v=fPeZ29XdX5U
    • BY DIGITALPIMPLE
    • 4 MIN
    • 295K VIEWS
    • ADDED 2013-05-15
    Video embedded ยท How to fix your GE Refrigerator if it stops making ice. Easy quick Ice Maker fix if your ice tray suddenly stops filling. Check for this issue before going ...
  • How To Fix Refrigerator That's Not Making Ice ' Fridge Repair www.partselect.com/Repair/Refrigerator/Not-Making-Ice Find out how to repair a refrigerator ice maker that's not making ice by troubleshooting common ... can cause a refrigerator's ice maker to not ... GE Parts ...
  • Icemaker Not Producing Ice - products.geappliances.com products.geappliances.com/appliance/gea-support-search-content?... Icemaker Not Producing Ice. To minimize the possibility of electric shock, unplug this appliance from the power supply or turn the house circuit breaker/fuse to the ...
  • New Icemaker Not Producing Ice - GE Appliances products.geappliances.com/appliance/gea-support-search-content?... New Icemaker Not Producing Ice. If the refrigerator icemaker has just been installed, there are a few things that must happen before it can produce ice:
  • Jan 02, 2016 | GE Refrigerators
    Why am I getting water but its not making ice?
    this model has the double valve. one for drinking water and second to fill ice maker to freeze
    and produce ice. Possible one coil for ice maker is not operating.
    Check also supply tube to ice maker It is possible frozen and plugged.
    Jun 23, 2014 | GE GSL22JFPBS Side by Side Refrigerator
    Ice maker not working on GE side by side
    Here is a tip that I wrote about the reasons why ice makers do not work.
    Ice Maker Problems and Ice Maker Troubleshooting
    heatman101
    iyooyi76
    Jun 01, 2010 | GE GSL25JFPBS Side by Side Refrigerator
    Refrigerator cannot produce ice
    First you need to list the model number of your GE to get correct answers. The problem is either you water control valve or the ice maker itself. If filling the ice maker with tap water and it freezes and dumps without the ice maker refilling then I would point to water control valve for the ice maker side and if the ice maker when filled does nothing the the ice maker is defective. Thanks, Merry Christmas, Sea Breeze
    Dec 23, 2009 | GE Refrigerators
    The ice maker on our GE refrigerator does not make ice
    1 -Ice maker arm must be down(on position)2-Make sure the water supply line is connected to the fridge3Check if the ice maker is plugged in4The freezer must be working fine for the ice maker to produce ice. After the ice maker stars and calls for water and doesn't get any , the water valve is bad.And if everything above is ok the ice maker needs to be replaced.
    Apr 26, 2009 | GE Refrigerators
    New ge fridge ice maker stopped producing ice
    check filter or waler valve may be is the icemaker call service
    Apr 01, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
    GE model GSH25JFTACC ice maker not working
    When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
    First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
    Mar 24, 2009 | GE 25.0 Cu. Ft. Side-by-Side Refrigerator...
    Dec 26, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
    Kenmore Side By Side Refrigrator ICe Make Not working
    Is the icemaker producing ice and it's just not coming through the door? Or is the icemaker not even producing ice???
    Mar 01, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
    Refrigerators Logo
    96 people viewed this question
    Top Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
