Question about Lucent Big Button 953 Corded Phone (21069)
How do you program speed dial buttons? - Lucent Big Button 953 Corded Phone (21069)
Edit and existing speed dial
  1. Press the Function (FNC) button.
  2. Press the speed dial button you want to program.
  3. Dial the number.
  4. Press the Function (FNC) button to set the number.
  5. The message Speed Dial Set (SPD SET) displays, indicating that the speed dial button is now programmed.
NEC telephone user guide Thunderbird School of Global Management IT Help
Nov 10, 2014 | NEC Electra Elite DTU 16D-2 Corded Phone
Speed dial button says incoming call
Check the programming on all of your buttons by using Feature *0 and press any button to see what is programmed on that button. It sounds like something else is programmed on your speed dial button. To set a speed dial button press Feature *3 then the button you want to be speed dial. Press Feature 0 to program it.
Feb 07, 2014 | NorStar M7310 Corded Phone
I need instruction manual to program speed dial
I was unable to locate a user manual for that particular device, however the basic instructions for programming speed dial functions are normally very similar between most phones.
Generally there are ONE TOUCH Speed Dial buttons labelled something like M1, M2, and M3 on the dial pad somewhere.
There should also be another button labelled PROG or STORE on the keypad as well.
Normally to program a number into a ONE TOUCH speed dial memory location you carry out the following procedure:
Lift the handset.
Then press the PROG (or STORE) button.
Now just use the number keypad to dial the full telephone number that you want to store in a Speed Dial location.
Once the full telephone number is dialed, then push the M1 button to store that phone number in the M1 One Touch Speed Dial location.
The phone may or may not show some kind of confirmation that the M1 location was just programmed, then just hang up the handset.
Now when you lift the handset and press the M1 button, the phone should automatically dial the phone number you programmed into it.
Now just repeat the same process for the M2 and M3 One Touch Speed Dial buttons with other phone numbers if necessary.
To change one of the Speed Dial numbers, just carry out the normal programming procedure for that location using the new phone number and the old number will simply be overwritten.
I truly hope that was helpful to you.
Good luck and take care.
Joe.
Dec 02, 2011 | Southwestern Bell FM-480 Corded Phone
Forumla for adding speed dial numbers
Personal speed (the 12 F buttons on the right) depend on whether you dial "9" to get an outside line. Then the buttons are programmed by pressing PROGRAM the button and dialint the speed dial number with a 9+ then STORE. System speed dial number sare programmed in SYSTEM programming 001 and they have "9" also in front of them.
Carl
Jun 18, 2011 | Panasonic KX-T7730 Corded Phone
Hoi have got speed dial on the main switchboard, so how do i do speed dial from other extensions
There is system and personal speed dials. System is programmed from the main phone and is dialed by using the AUTODIAL button and dialing a 2 or 3 digit code, depending on which system the 7730 is connected to. The other is PERSONAL speed dial, programmed on the 12 buttons on the right side of the phone. Those are programmed at each phone by using PROGRAM pressing the button and dialing an access code (usually 9) and the number then STORE.
Carl
Oct 23, 2010 | Panasonic KX-T7730 Corded Phone
How to program speed dial for various customers
1) To program a personal speed dial number, leave the handset on-hook. Press ALM/SD followed by the DSS button where you want to store the number. Dial the telephone number to save, up to 30 digits (press HOLD to insert a 3-second pause or MSG in insert a hookflash). Press ALM/SD to store the number.
2) To dial a speed dial number, select an outside line. Press the ALM/SD button. Dial the desired speed dial code 10-98 (system speed dial) OR press the desired speed dial button on your phone (personal speed dial).
3) System speed dial numbers may only be programmed by the system administrator.
Jun 02, 2010 | Samsung Prostar DCS-24B-LCD Corded Phone
I push the feature button it turns red as soon as i enter the phone number the light goes out press feature and does not program
Why are you pressing the feature button?
Press feature then answer. You envoked ringing line pick up.
Press feature then speed dial button, dial a number like your dialing out, then feature again. You've just set a speed dial button.
Press feature, then 3 and you've changed your ringtone on a series i phone.
Mar 16, 2010 | NEC Dterm DTP 16D-1 Corded Phone
How to program speed dial on sony spp-a946 cordless phone
  1. Press 'PGM'- "program" button.
  2. Press "speed dial" button.
  3. Select "station # " i.e. any button from 1-9 for speed dialing.
  4. (make sure to make a note of this selected # against the corresponding tel # and /or the person's name)
  5. Dial the complete (incl. 1 for USA or country code for other country tel. #s) telephone number to be stored for the selected speed dialing station #.
  6. Press "PGM" button again to complete the storing of the tel #.
  7. Test, after dial tone, by just pressing the selected station #
Mar 13, 2009 | Sony SPP A946 Cordless Phone
Program speed dial buttons
To program a speed dial for an outside line: Pick up the handset, press #00, press the button to be programmed, press *21, then enter the number to be dialed (including any dial out number and areacode).
To program a speaad dial for in internal extension: Pick up the handset, press #00, press the button to be programmed, press *22, then enter the ext to be dialed.
(Once you hit #00, you can also follow the screen prompts).
Jan 21, 2009 | Avaya 4412D Corded Phone
NorStar T7316E Corded Phone Manual
1 you can but it must be done via log on to switch with lap top (you may use handset but very tricky)
2 use feature *4
Speed dial -
using
FEATURE 0
Dial an external telephone number using a two- or three-digit code. There
are two types of speed dial codes: system (01-70 or 001 to 255) and
personal (71 to 94). System speed dial codes can be used from any
display telephone in the system. System speed dial codes are assigned by
your System Administrator.
Personal speed dial codes are used exclusively at your telephone.
To make a call using a speed dial code:
1. Press FEATURE 0.
2. Enter the two- or three-digit code for the number.
Speed dial -
programming
To program personal speed dial numbers:
1. Press FEATURE *4.
2. Enter a two-digit code from 71 to 94.
3. Specify the external line by pressing a line button, a line pool button, or
the intercom button. If you do not specify the external line, the system
automatically chooses a line for the call.
4. Dial the telephone number you want to program (up to 24 digits).
5. Press HOLD.
6. Record the code and number you have just programmed.
Note: You cannot program personal speed dial numbers while another
user is programming your system.
May 15, 2008 | NorStar T7316E Corded Phone
Lucent Big Button 953 Corded Phone (21069) Logo
Top Lucent Lands Phones Experts
Paul C.
Computer Repairing
Computer Repairing
Michael Galve
Michael Galve
Are you a Lucent Lands Phone Expert? Answer questions, earn points and help others
