Question about Pool & Spa
Jandy Actuator Troubleshooting. One of my actuators turns 180 as it should but when I flip the switch to the other position it does not turn back. I'm no electrical genius but I tested each microswitch by isolating them and checking continuity and they both seemed to function correctly. There was water in the actuator when I opened it. I let it dry out and checked all connections. I don't want to fork out $200 for a whole actuator.
  • 22 Answers
There are tightening nuts that have notches and grooves which sit 2.3 down the shaft these can become lose then when actuator moves the knob that is suppose to trigger the contact just spins. if you watch the movement of the valve when you switch the forward and reverse switch you should be able see how it operates and then using the tips of your fingers you can adjust the position of one or two of the adjustment rings. they are kinda close soo you can move both at the same time just take your time and study the flow. you may want to take the pump lid off the pump so no water is flowing thru the pipes if water pressure or loss is an issue while making adjustments. the idea is to make the system think it is is working propertly and then you can trouble shoot. rarely is there any additionally pressure contact sensors that will make trouble shooting more difficult its usually the water flo and back up or overflo of water in the pipes that make you stress out while attempting to make the adjustments
Posted on May 14, 2010
I have a Jandy Aqualink pool system. When I turn on the spa and heater, the spa drains..I've never had this happen but don't use the spa much. What should I check?
His is not typically a control panel issue but more likely a valve issue.
Your valves are set as follows wih a few minor variations.....
Pool mode- sucks from pool skimmer and or pool vac line and returns water to both the pool and spa.
Spa mode - self contains the spa , meaning water is sucked from the spa and returned only to the spa.
If your spa is draining then most likely one of your electronic valves is failing...most likely it's the return valve so what is happening is the water is sucked from the spa and returned to the pool instead of self containing the spa.
Easy check is to be next to the equip when spa mode is selected and two valves should move and align properly, the return side valve is most likely not moving or it is not moving into the correct position.
The fix is either adjusting the valve acuator or buying a new valve acuator.
Another thing to check is on the main panel circuit board to ensure the return and auction 3 pin plug ins are still connected.
Apr 05, 2015 | Jandy Aqualink Rs4 One Touch Control...
LG Tone HBS-730 won't turn on. I charge it and the red light comes on but when I flip the power switch it doesn't turn on. any help?
First a couple of questions:
  • How old is the unit?...Battery could be spent and can no longer hold a charge.
  • Is the switch working properly? You should feel a discernable "click" when you turn on the unit. If you don\'t, the piece that moves the on off switch within the unit has probably broken.
    • Fix for broken switch:
      • Get some quality small screwdrivers (flat head and Philips), a small, single color, Terry cloth (to catch small screws), a cutting blade (utility knife), small needle/pin, and a well lit work area.
      • Place Terry cloth on to work area
      • Find rubber stopper just above switch and adjacent to speaker wire that covers the Philips screw.
      • Use needle/pin to remove rubber stopper. Chances are it will fly off once freed from unit, so prick it with needle to attain a firm hold.
      • Use small Philips screw driver to remove screw. Terry cloth should catch screw and keep from rolling off into oblivion.
      • Use utility knife to pry open plastic casing at the seam. It may be best to start at top near the screw hole and work your way down. Use small flat head screwdriver to place between opened area to assist in helping your progress downward. Eventually the entire casing will pop off.
      • Examine the on off switch actuator to determine if this is the problem by moving it back and forth. The actuator should move a small black switch on the circuit board. If the actuator is broken, the switch will move back and forth w/o moving the black switch.
      • If it is determined that the actuator is not moving the switch, use small screw driver to move black switch to "on" position and look/listen for activity, to verify that switch is working.
      • To fix broken actuator, remove it from casing and place on Terry cloth. From examination, you will notice that tab(s) at the bottom have bent or broken off. To repair, a simple solution was to flip the actuator and cutout a the middle section of the tab opposite of the broken end using the utility knife. Be careful to cut too much so that it would not be able to move the switch.
      • Replace the actuator back on the sliding mechanism and test to see if the actuator moves the switch properly. If you cut too much, all may be lost! Perhaps some super glue and a tiny spare plastic piece to attach to actuator may work.
      • Replace plastic covering and replace screw and stopper. (Be careful to return speaker wire knot inside unit to its proper place)
      • Again, check switch to verify that it is working properly.
      • In future, take care when turning on and off the unit. Perhaps too much pressure or faulty plastic may have been the cause of it failing.
May 19, 2014 | Radio Communications
My controller says it is in spa mode - trying to heat only spa- but water is spilling into pool. I have 2 jandy valves, only 1 moves when I change from spa/pool mode. Any suggestions?
The valve actuator on the suction side is either bad or the toggle switch on the back is in the wrong position. There are 3 positions for the switch on/off/on. It should be in either be all the way up or all the way down. In spa mode move the toggle switch. If it still doesn't move then you have a bad actuator. If it moves someone has moved the switch.
Oct 21, 2013 | Jandy LAARS VALVE, PRESSURE RELIEF 75PSI...
The Spa Mode emptied the spa water into the pool so the pool level is too high and I cant get the spa to refill.
You RETURN side valve actuator has malfunctioned and did not move into the spa return position. Most actuators have a toggle switch on them where you can over ride the system.
The 3 positions are; normal, off, and reverse. You can check to see how the valve is moving by flipping the toggle switch. If the actuator is more than 10-12 years old it may need to be replaced. Actuators are standardized between manufacturers and new ones will run about $120, easy to change out.
Aug 06, 2013 | Jandy Pool & Spa
Valve actuator stay in spa position
Actuator might be bad, not getting 24 volts, bad switch, or needs maintenance and grease.
Manual with troubleshoot on following link:
http://waterheatertimer.org/Digital-control-centers-and-manuals.html#PE24
Apr 21, 2013 | Pentair CVA-24T Valve Actuator 2 port 24V...
Spa won't heat unless in spa mode, and if it is in
On the automated valves there are tiny switches on one end or under the valve actuator. When you switch to the spa mode the suction valve should should move to fully block pool drains. The return valve should fully block the pipes to the pool returns and spa fountain. If one or both of these valves is not fully blocking the pipes to the pool then the tiny switch on that valve is in the wrong position or an operator is defective. The middle position of either of these switches turns the operator completely off so it cannot move. That is the position to avoid unless you want to operate it manually. One of the other switch positions caused the valve to move in one direction and the other switch positions causes the valve to move in the other direction. If you set the switches so when in the spa mode water is circulating only in the spa then you have the valves in the right position. Next, place the system into the pool mode. Both valves should move to the other position. If not then the valve operator that doesn't move has a problem. It could be the operator, the wiring, the control panel or a stuck valve in that order. All of this sounds complicated but once you know how the operators should act when you flip those tiny switches and how the valves should act when in the spa and the pool mode then getting the switches set right is simple. I hope this helps.
Aug 07, 2011 | Jandy Pool & Spa
How do i replace the ignition switch
FIRST TURN OFF RADIO.DISCONNECT THE NEGATIVE BATTERY CABLE,THEN THE POSITIVE BATTERY CABLE.WAIT 20 MINUTES. UNTIL AIRBAGS DISCHARGE.TURN THE IGNITION KEY LOCK CYLINDER TO THE RUN POSITION.REMOVE THE CENTER TRIM PANEL AND THE DRIVER SIDE KNEE BOLSTER.UNPLUG THE IGNITION SWITCH ELECTRICAL CONNECTOR AND REMOVE THE SWITCH RETAINING SCREWS. DISENGAGE THE IGNITION SWITCH FROM THE ACTUATOR PIN AND REMOVE THE SWITCH FROM THE VECHICLE.MAKE SURE THE ACTUATOR PIN SLOT IN THE NEW IGNITION SWITCH IS IN THE RUN POSITION.A NEW REPLACEMENT SWITCH WILL BE SET IN THIS POSITION.PLACE THE NEW SWITCH IN POSITION ON THE ACTUATOR PIN AND INSTALL THE RETAINING SCREWS IT MAY BE NECESSARY TO MOVE THE SWITCH BACK AND FORTH TO LINE UP THE SCREW HOLES.WHEN CENTER TRIM AND KNEE BOLSTER BACK IN PLACE.CHECK FOR PROPER OPERATION OF THE IGNITION SWITCH IN THE LOCK, START AND ACCESSORY POSITIONS.
Feb 14, 2011 | 1999 Ford Expedition
1984 ford f-150. when turning the key to start it does not spring back to the run position. i've replaced the ignition switch located on top of the lower end of the column. when turning the key you can...
The actuator rod has a spring and block the returns the actuator to its normal position. Sounds like one of the three parts are broke. If this is a tilt steering column there is a two piece actuator rod. I am in the process of replacing the upper actuator rod, the pin that connects it to the lower actuator broke off. Never had any ignition problems, one day it just won't turn off due to broken actuator rod. Hope this helps you.
Jan 01, 2011 | Ford F-150 Cars & Trucks
JVA 2440 rotates continuously in spa mode
If you remove the handel and open thr top of the actuator you will see a set nut on the center of the shaft that you use to set where the valve stops. If this is tight then you may have a bad micro switch in the unit and you should replace the actuator. Good luck.
Jan 07, 2010 | Jandy Aqualink Rs4 One Touch Control...
I have a Compool lx220 control for my pool solar
Check the valve actuator toggle switch. It is 180 degrees out. If the toggle switch is in the up postion flip it down or vise versa.
Aug 26, 2009 | Pool & Spa
Pool & Spa Logo
247 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
