Question about Ingersoll Rand - Rand Type - 30 Reciprocating Air Compressor - 5 Hp, 230 Volt 1 Phase, Model - 2340L5
What type of oil for ingersoll rand model 2475 air compressor could not find specs at Rand website
    Scholar:
  • 169 Answers
Ingersoll Rand likes you to buy their all season select oil for their air compressors, most piston air compressors use an R+O 100 oil it is equivalent to n SAE 30 wt oil.
Posted on May 12, 2010
    Master:
  • 507 Answers
Non detergent oil
Posted on Jul 22, 2017
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
All season select oil or any other alternative good quality synthetic oil
Posted on Jul 18, 2017
    Problem Solver:
  • 13 Answers
Yes ingersoll Rand T30 select is the oil for your air compressor Or you can use KELTEC synlube KOA1500C. Just email me.
Hope i can help you.
Regards,
rodciel
Posted on Sep 01, 2014
What level does the coolant need to be in the sight glass?
About 31,000 results (0.83 seconds) Search Results
    [PDF]IRM-G-8780 2-25hp US - Ingersoll Rand Air Compressor
    www.ingersollrandproducts.com/...
    Ingersoll Rand Industrial TechnologiesIngersoll Rand compressors are not designed, intended or approved for breathing ...does not approve specialized equipment for breathing air applications and ... unmatched service to meet your needs. ... drain, and low-oil-level .... Oil Sight Glass ... Value Package (5, 7.5, 10 & 15hp) An economical choice in a dependable ...
    [PDF]Owner's Manual - Air Compressors Direct
    www.aircompressorsdirect.com/.../irmanual2340_2475_2545_7100_15t...
    installation, operation and maintenance of your Ingersoll-Rand air ... An air-cooled aftercooler, low oil level ... for Models 2340, 2475, 2545, 7100, 15T & 3000 ... Ifcooling of the discharge air is required, .... motor does not have this button and the unit does not have a ..... l Drain compressor oil and clean oil sight glass.
    [PDF]XF 7.5 - 15 EP 7.5 - 15 HP 7.5 - 15 XP 7.5 - 15
    diagramasde.com/.../Manual%20comp%20ingersollrand%20SSR-15.pdf
    EP 7.5 - 15. HP 7.5 - 15. XP 7.5 - 15 ... The Ingersoll-Rand Company Rotary Screw Air Compressor that has been filled prior to its ... after shall have its AIREND warranted for twenty four (24) months from the ... comes first, when using ULTRA COOLANT.Coolant ...... check coolant level in the sight glass on the separator tank.
    Ingersoll Rand Air Compressors - About Air Compressors
    www.about-air-compressors.com/Ingersoll-Rand-air-compressors.html
Feb 08, 2016 | Ingersoll Rand 15 Horsepower Rotary Screw...
WILL T21 SELECT OIL WORK IN A MODEL 2475
The solution was easier than I expected. Ingersoll Rand "Select" oil is a synthetic oil recommended by Ingersoll as better than mineral oil. T30 (mdl 2475) and T21 are different styles of compressors. So, yes "select" oil can be used in the Model 2475 compressor.
Jun 25, 2014 | Ingersoll Rand - Rand Type - 30...
I need a manual to rebuild a Type 30 Model 2475 ingersoll rand air compressor. Thanks
Dear Joe Bell,
This is Rodciel L. Camacho of VISMIN compressed air care center we are specialize in ingersoll rand air compressor.
You mean a overhauling kit?The part number of that is 34319469.
Hope i can help you..
May 07, 2012 | Ingersoll Rand - Rand Type - 30...
Hello. I have a Ingersoll Rand air compressor, model 2475. I was wondering if there was a way to adjust the pressure gauge to create a larger differential. It is currently running between 150 and 160...
You can adjust almost all pressure switches
Compressors,Well Pumps,etc
Take off the cover & there should be a screw
to do just what you want to do,lower the cut out
pressure
Good idea, as the compressor will last many years
longer, the less it runs
Jun 29, 2011 | Ingersoll Rand - Rand Type - 30...
I believe that the motor starter circuit on my Ingersoll Rand 2475 5 hp 80 gallon compressor is incorrect. It's a 30 amp single phase compressor
You should not be pulling over 30 amps. If you are you may have low voltage, incorrect wire size or to long of a run for wire size. I would use a hand held meter and check the amps at full load.
Nov 14, 2010 | Ingersoll Rand 2340/2475 Electric Air...
My compressor 2475 ir (5hp) has no dip stick or oil level glass;only oil cap.how much oil is needed for proper level?
In the owners information your compressor takes the 1 bottle of IR oil that comes with it. If you have a local tractor supply company or another company who carries IR you might check with them, it is the only oil i would recommend for your unit.
Jul 19, 2010 | Ingersoll Rand - Rand Type - 30...
I have a ingersoll rand type-30,model#2475 7.5 hp,3 phase.need a wire diagram or how do you wire up the low oil and pressure switch? this is a used compressor with wiring still conected, has 3 leads to the...
from what you are describing it sounds like you are missing a couple wires somewhere or you do not know what you are looking for. The pressure switch, low oil switch motor starter coil, and overload relay should be wired in series to provide a control circuit for the motor starter. I would highly advise seeking the help of a certified electrician if you are not experienced in working with these machines. You can not only risk personal injury, but also damage a lot of expensive electrical item's real quick if it is not done correctly.
Dec 04, 2009 | Ingersoll Rand - Rand Type - 30...
I have a Ingersoll Rand Type-30, Mod#2475
when you remove the pressure switch cover,there is a screw on the top screw clockwise means increasing air pressure and anticlockwise means decreasing the drlivery air pressure
Sep 11, 2009 | Ingersoll Rand - Rand Type - 30...
Correct rotation of copressor
Checked all the IR compressors in stock and all turn counter-clockwise facing pulley, however you could check the pump for fan angle on pulley. The fan on the compressor pulley blows air towards the pump. Generally, pumps turn CC because that would allow for the use of gasoline engines which all turn CC. Please email you questions, and Good Luck.
Jan 27, 2009 | Ingersoll Rand 2340/2475 Electric Air...
Ingersoll Rand - Rand Type - 30 Reciprocating Air Compressor - 5 Hp, 230 Volt 1 Phase, Model - 2340L5 Logo
2,094 people viewed this question
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
