Question about Apple iPod MA446LL/A MP3 Player
IPOD Classic 80G apple icon then red x icon or restore in itunes
The IPOD froze up, showed a song was playing, and the count-down was stopped. I turned the IPOD off, and tried to turn it back on, and got the apple icon. I then tried to restore, and it told me to use ITUNES to restore. I tried that, and I got the red x icon. The IPOD does not show up on the computer or itunes, and all attempts to restore have failed. Ideas would be greatly appreciated!! Thx
  • 7 more comments
  • HERKYBIRD
    HERKYBIRD Mar 29, 2008
    I have tried that many times! It still does not work.
  • HERKYBIRD
    Unfortunately, when I looked through my "add/remove" programs, I did not see either the MMJB ipod plugin, orthe ipod manager. The problem first occured while the unit was plugged into a car adapter/FM transmitter. From that point on, it didnt work either on external power or ipod battery. The funny thing is, the apple icon will appear as soon as I try to reset, and sometimes it will come up with the red x icon, and other times it will show the "restore with Itunes". I have the latest version of Itunes as well. I am not the greatest at computers, is the firewire simply the USB to Ipod data xfer wire? Thx
  • HERKYBIRD
    I checked out the link, and I dont believe it will help. However,... I forgot to mention that my Ipod was already set to disk mode when the failure occured. I have tried to restore, and change to/from disk mode. Nothing. Thx!
  • HERKYBIRD
    Perhaps I mistook firewire for firmware. From what I read, perhaps I am wrong, the firmware for the ipod comes from the Itunes updates? If that is the case, I have not been able to connect to itunes at all, but I have the latest update. It seems to me (obviously) that the ipod freeze, and not being able to connect are interrelated. Do you have any additional ideas? Thanks!
  • HERKYBIRD
    SYNOPSIS: 80G Ipod classic, frozen while in disk mode. I have attempted multiple resets, to no avail. Most recently, I held the menu and select buttons at the same time for a reset, and continued holding. The hard disk activated three times before the "restore using itunes" screen came up. The ipod does not show up as a device on my PC nor in itunes (which as the latest update). Per bestdarngood's advice, I searched for the MMJB ipod plug in and the ipod manager in my "add/remove" programs, but they are not there. Any additional help will be appreciated! Thanks,....
  • HERKYBIRD
    I have tried that, several times. The thing refuses to restore at all.
  • HERKYBIRD
    Bestdarngood, I appreciate the help. I know I am grasping at straws here, but thanks anyways!
  • HERKYBIRD
    The Ipod does not show up on the PC or Itunes at all. I tried reseting and reformatting as well.
  • HERKYBIRD
    SYNOPSIS: 80G Ipod classic, frozen while in disk mode. I have attempted multiple resets, to no avail. Most recently, I held the menu and select buttons at the same time for a reset, and continued holding. The hard disk activated three times before the "restore using itunes" screen came up. The ipod does not show up as a device on my PC nor in itunes (which as the latest update). Per bestdarngood's advice, I searched for the MMJB ipod plug in and the ipod manager in my "add/remove" programs, but they are not there. Another tidbit of info.... when I select then deselect the hold feature, the restore using itunes screen pops up immediately. Any additional help will be appreciated! Thanks,....
    Sergeant:
    Champion:
  • 277 Answers
Ipod device is act like a usb device.. run device manager and removed auknown device specially usb storage, the restart your computer... its all reset the usb driver installlation
Posted on Mar 29, 2008
  • 111 Answers
Try the Pod classic Troubleshooting Assistant http://www.apple.com/support/ipod/five_rs/classic/ it will guide you through to a happy solution
  • 236 Answers
If you don't mind losing your songs,
Hold down the play and menu buttons (or play button and select button) at the same time for about 5-seconds.. That should reset the ipod...
  • Dave MacPhee
    Dave MacPhee Mar 29, 2008
    have you tried connecting it to another computer and see if it is recognized?? Perhaps your usb/firewire port has a problem, or needs a driver update.
    If you plug something else into that usb port on the system, does windows see it?
    Have you tried completely uninstalling Itunes software and re-installing it?
  • 3,037 Answers
I know you tried to fix it, but trying multiple times may work.
The message "go to www.apple.com/support/ipod" usually is preceded by, or followed by, the Apple logo or the sad face icon. It directs you to the Apple support site because either the iPod software is corrupted or their is a hardware problem. You should try to reset the iPod (try several times). If that doesn't right the iPod, then try to restore it (which will erase the entire iPod and reload the software.
Follow the links above and see if that gets your iPod working. You might want to see if you can update the iPod/iTunes software or try this troubleshooting guide. If it is really a hardware problem then your iPod needs to be taken in for service.
  • 5 more comments
  • Benjamin Patri
    Benjamin Patri Mar 29, 2008
    Here is what someone said might help.
    If the systray icon has a red X in it then the iPod isn't mounted. When
    you connect your iPod, and there's a red X thru the icon, then you
    probably won't see the iPod in Windows Explorer either i.e. it isn't
    mounted by windows and therefore nothing can be done with it.
    This means that there's something wrong with the communication between the iPod - firewire - Windows.
    Is the firewire properly installed? [check f.e. your hardware
    settings/device manager and check if there's no exclamation mark
    somewhere and/or if there's a IEEE1394 bus host controller; if there is
    check the device status by double clicking on it]
  • Benjamin Patri
    Very often the software that Apple blessed us with causes connection
    problems. The funny thing is, is that none of it's needed. Windows will
    by default register your iPod as an external hard drive w/o any
    software installed at all.
    Knowing that, when you run into problems, it's best to uninstall
    everything that came on the Apple CD and see if at least the iPod shows
    up as a drive in My Computer. If it doesn't, you can pretty much bet
    it's a firewire or iPod problem, if it does...well you're in business
    because you can use other programs to upload tunes.
    With that background, here is what I recommend:
    1. Uninstall the MMJB iPod Plugin from Add/Remove Programs.
    2. Uninstall the "iPod Manager" from Add/Remove Program.
    3. Reboot your PC.
    4. Connect the iPod.
    It should say "Do Not Disconnect" on it. And the iPod should appear as an external drive in My Computer.
    If you get that far. You might want to check the "Software Compendium"
    sticky on the Windows>Software board for recommendations of other
    programs to use. MMJB is pretty much known as the worst iPod uploading
    program out there.
    you can always try to reset it [hold the buttons menu+play simultaneously for 15 secs or so].
  • Benjamin Patri
    http://discussions.apple.com/thread.jspa...
    you can check out this link and see if it helps at all
  • Benjamin Patri
    http://www.techterms.com/definition/firm...
    not too difficult to understand-definition of firmware
  • Benjamin Patri
    alright, since I can't figure out any more solutions after searching all this time, I recommend contacting apple about this problem either by their website, email, or phone, if you need this info let me know, but if none of the above works, I would definitely contact them asap.
    Thank you and have a Good Day.
  • Benjamin Patri
    Let me know if you need anything else, I am glad to help but all of the known solutions that I know of are here.
  • Benjamin Patri
    Let me know if you can get it working but most likely you will end up calling apple and possibly sending it into them. Good Luck.
  • 813 Answers
Hummmmm
ok u have to do this
1. do u have itune software in your pc its spcilly use for ipod
2. if u have then plug ur i pod in ur cpu
3 take back up of all ur song in your pc
4. format your i pod
5 reinsatall all song in your ipod useing by itunes software
your problem will soves i have same prblem before few day ido this & my problem solve its may help u
& thnx for using fixya
My apple ipod classic froze half way through a song welst i connected it to a computer now its froze on the song and it wont charge
Press both the center button and menu until the circular spinning icon shows that the thing is rebooting.  Also, try holding play for 5-10 seconds to shut the thing off.  Then hold play for 5-10 seconds to turn it back on.
Nov 15, 2009 | Apple iPod classic MP3 Player
My Ipod classic 80G has stopped playing music. what happens is after I select and then press play it will have the play sign on the top, but the song wont starta and after a few moments it then starts to...
Make sure that you got all of your songs off of itunes, or that they have been converted through itunes correctly. This is caused by songs being the wrong format, or that the song itself is corrupted. Try restoring the unit through itunes, and loading the songs back on. If you are running with your unit while trying to listen music this can also cause the unit to freeze up when playing a song. Any type of continuous motion can cause your ipod to not play songs. This is because the ipod has a hard drive inside of it, and when you move alot with a hard drive it cant read correctly. If you want to run with your unit, i would suggest getting a flash drive based mp3 player (ie itouch). If you have any further questions feel free to contact www.wiredextreme.com.
Nov 14, 2009 | Apple iPod MA446LL/A MP3 Player
Ipod wont sync windows registers it but itunes wont and nothing will play on ipod either you press play on any song or video and it just stays at 0.00
Try restoring it, plug your iPod into your computer, open itunes, click the iPod icon and click "Restore." This will take a few minutes.
Aug 16, 2009 | Apple iPod classic MP3 Player
80g ipod classic won't unlock or charge,and itunes won't
My 80GB Ipod classic recently froze. I took it to Apple store and the guy press the Menu and Center Button. Hold them until the APPLE logo appears twice. Then release the button.
Voila, my Ipod work again, no missing data
Jul 22, 2009 | Apple iPod classic MP3 Player
It is locked up
Maybe i shud start by explaining why most Ipods freeze or crash. When you unplug you ipod improperly this may and usually causes the itunes software to crush and stop functioning. The softwares corrupts and cant function. So you probably cant enjoy ua music.
With the viruses in your computer its easily to infect your ipod since ipod is a mass storage device also. Some viruses have a way of freezing the itunes software.
When it comes to restoring your ipod you need a computer that is not infected with viruses. you need to format your ipod if it cant be restored directly from the internet. After the ipod is completely formated which means you have done away with the viruses/all the songs you can restore it with itunes.
But there is also a way of recovering songs from your ipod before formating or restoring since if you format you get to loose all ua files without recovering them.
But the biggest problem is when your ipod is not even recognized by your computer. But if your computer can recognize your ipod as a mass storage even if its not syncing your music, there is a possibility restore it to normacy. The only rist is loosing all your data, but with an expert you dont have to loose anything.
Jun 02, 2009 | Apple iPod classic MP3 Player
IPOD CLASSIC 80G WILL NOT SHOW UP IN itunes
Will your ipod show up in My Computer? If it does, you might try right clicking on the icon, select properties. Go to the Tools tab and perform a disk check. You may try www.ifixipodsfast.com He may be able to help you if it is a hardware problem/
Jan 22, 2009 | Apple iPod classic MP3 Player
Very serious problem with ipod classic plzzz, help me out!!
That is most likely because they are not in the right format for the ipod to play. For the songs, right click on them and click on convert to mp3. Then transfer the mp3 song on there and it should work then. For the videos, you will have to download a free converter for them and let them be converted that way. It should work normally after that.
Nov 21, 2008 | Apple iPod MA446LL/A MP3 Player
Please Help IPOD 80g Black
try reseting the ipod (menu and center button for ten secs) Otherwise, on itunes click restore my ipod under the general menu of the Ipods tab
Aug 07, 2008 | Apple iPod MA446LL/A MP3 Player
Apple ipod classic 160 gb
connect ipod to pc..........let itunes (make sure it the latest version) come up....your ipod icon shows up update (let itunes check if your firmware is up-to-date) if so this should do the trick.
Jul 13, 2008 | Apple iPod classic MP3 Player
80G Ipod Classic skips songs
Try converting the songs into a different format because the format that the song is in might not completely be played on the ipod. Right click on the song and click on convert to mp3. Then try transferring the mp3 format song onto the ipod and it should play right then.
Jun 24, 2008 | Apple iPod MA446LL/A MP3 Player
Apple iPod MA446LL/A MP3 Player Logo
430 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Computer Repairing
Computer Repairing
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
