Question about Plantronics DSP-400 Headset
DSP-400 Headset: Hello and thanks for helping with this issue. We u...
Hello and thanks for helping with this issue. We use Cisco ip Communicator ver 2.1.3.0 with the Plantronics DSP-400 usb Headset. There are six of us using this headset and we all experience the same problem which is the phone drops out while you're talking you can still hear the other person but they cant hear you. And the only way around this problem is to dial again and again after 5 to 10 mins same issue. Can you help with this problem. thanks
Cisco 7972 use headset
You can use a standard PC or cell phone headsets with Cisco phones. With help of our adapters, you can convert computer headset, smartphone headset or cordless phone hands-free into Cisco compatible headset.
Cisco IP Phones
Feb 06, 2014 | Cisco Computers & Internet
Tip
Cisco IP softphone - one way audio - fix
Using the Cisco IP soft phone via VPN can sometimes cause audio to drop. To fix this:<br /><br />Right click the Cisco IP Phone and select Preferences...<br />Select the Audio tab<br />Click on the Network button<br />In Audio IP Address select Use this address<br />then set it back to Detect Automatically<br />Click OK and OK again.<br /><br />Give it 5-10 seconds and this will auto reset the audio on the IP phone and will correct the issues with one way audio.<br />
on Mar 08, 2011 | Cisco IP Communicator (SWIPCOMME1CH1)
Cisco expert
I think you're confused. IP Communicator is the unified communications client (IM and Phone) It is looking for a capatible headset so you can use your softphone. This software is not your VPN client. There are two different cisco product: one for your VPN and one for your phone. If you're trying to ocnnect to an old-style Cisco VPN, your IT dept will have to configure that with a certificate.
Solution from Cisco: http://www.cisco.com/en/US/products/sw/voicesw/ps5475/products_tech_note09186a00809b6c40.shtml
This behavior is observed when a user attempts to install or use the IP Communicator on a system that has different names for the Playback (wave out) and Recording (wave in) devices.
In order to overcome this problem, perform one of these tasks:
-Use a USB headset that is recognized by the IP Communicator.
-Upgrade to the latest version of the IP Communicator
Nov 07, 2013 | Arris SURFboard SBG900 Wireless Router...
I have a CISCO IP communicator phone and a logitech h800 phone. I can't pick up and end calls
I know this is a bit late answer, but i got these headphones a few days ago and found a solution for it :)
You can check my post here:
http://www.autohotkey.com/board/topic/90056-hotkey-logitech-h800-with-cisco-ip-communicator/
Good luck! :)
Apr 13, 2012 | Logitech H800 Wireless Headset Microphone...
My Cisco IP Communicator screen is blank
Is the phones
registered to CallManager or CME?
if CM, then it could be because of partitions and Calling Search Spaces. PTs are placed on the line and are restricted by CSSes. http://cisco.com/en/US/docs/voiceipcomm/cucm/admin
/413/ccmsys/a03ptcss.html#wp1020642
If it is CME, then it could be a configuration issue
http://cisco.com/en/US/docs/voiceipcomm/cucme/roadmap/itsph.htm
Jul 16, 2010 | Cisco IP Communicator Full Version for...
When I call people hear me but I cannot hear them
Jun 19, 2010 | Cisco IP Communicator (SWIPCOMME1CH1)
Using Cisco IP Communicator- works to call out & receive calls, but I can hear them-they can't hear me. Also have 3 question marks next to headset icon at the bottom - headset has been tested &...
One way communication is usually a routing issue. Make sure that you have two-way routing to and from the subnets that are trying to contact you... could also be the reason why you have the question mark on the buttons too.
Hope this helps!
Jun 05, 2010 | Cisco IP Communicator (SWIPCOMME1CH1)
Having issues with logging into the cisco softphone from home via vpn
Make sure that the subnet for the call manager is available over your VPN if you have locked the tunnel down. Also make sure that the IPC is allowed to bind to the VPN virtual network card.
Hope that helped!
May 19, 2010 | Cisco IP Communicator (SWIPCOMME1CH1)
Do I need a driver for plantronics USB DSP v4 audio interface
Yes you would need a driver for your Platronics headset if you intend to connect it to your PC
Could you please describe the model of your plantronic headset so that i can get the required drivers for you.
Thanks.
May 21, 2009 | Plantronics DSP-400 Headset
Plantronics DSP-400 Headset Logo
88 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
skiffy99
skiffy99
Level 1 Expert
shaun taylor
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
