Question about HP 48gx Calculator
How do i restore the directory - HP 48gx Calculator
  • HP Master
  • 8,073 Answers
If you want to restore the directory hierarchy that contains the examples and sample programs that shipped with the calculator
  • Press [alpha][alpha] to lock the alphabetical keyboard.
  • Press [TEACH] then [ENTER).
  • The programs and examples will be restored.
If you want to create a directory (from scratch)
  1. Press [Right Shift Cyan key] and [HOME] to get back to the main directory.
  2. Press [Right Shift Cyan key] [VARS] to access (MEMORY) management
  3. Press the [D:New] tab
  4. The new variable screen opens
  5. Use the DownArrow twice to move cursor to the third line (_Directory)
  6. Press [C:Chk] to put a Check mark to the left of Directory
  7. The screen will change to show [Name and Directory]
  8. Use Up Arrow to move cursor to the first line (Name)
  9. Press [A:edit]
  10. Enter the name and then press [F:OK]
Once the directory is created you can use the Memory management to copy OR Move objects from other directories to the new one.
Posted on Jun 16, 2010
Directory services restore modesafe
Start, Run "services.msc"
Right click on Active Directory Domain Service, Left on Start.
If Started then Smile. If Not Started then Read Error Message.
Nov 28, 2013 | Computers & Internet
May 25th my CISnet computer would not start Windows, a file was missing. I did not have my Windows CD so I let the CISnet do the Restore. Can I undo the change after my CISnet computer restore to original...
Try the following;
1. Press "Start" on your Cisnet computer's desktop screen. Scroll up to "Accessories," then hover over "System Tools." Click on "System Restore."
2. Click the option that allows you to select a different restore point, rather than using the default restore point. The program will display a calendar.
3. Select a specific point to restore your Cisnet computer to by choosing a date from the calendar display. Click the "Next" button to confirm, then click "Finish" to close out system restore. Your Cisnet computer will restart and open with the selected settings.
Be sure that you do not unplug your Cisnet computer while running system restore because it will need sufficient battery life to complete the program.
Jun 02, 2011 | Computers & Internet
WE have upgraded a sage program on to new computer. However we cannot restore the backup due to an "unsupported version "error
hi dmatharu667
this happens when you take a backup of a company that has a accdata folder in the accdata folder and it reports version as v9. To correct this go to data directory go into accdata directory and in that director move or delete the second accdata directory, repeat your backup and it should then restore perfectly
Nigel
May 22, 2011 | Sage Instant Accounts 8.0 (013604ug)
In RPL mode, put the object on the stack. Enter the name you want for the directory (must not conflict with an existing object) between ticks and press STO.
Mar 18, 2010 | HP 48gx Calculator
What happens if we delete hidden directory system volume informat
Hidden directories most often serve to hide important operating system-related files and user preferences. This is mostly to protect the files. But malicious programs (malware, viruses, trojans) can also use this functionality to hide their presence.
The System Volume Information folder is a hidden system folder that the System Restore tool uses to store its information and restore points. System Volume Information (SVI) is the name of the data store where Windows XP and Windows Vista keeps its System Restore files and registration databases. System Restore not only saves copies of critical system files, it also performs automated registry hive backup.
There is one SVI folder per drive being monitored by System Restore. You can not view/access the SVI folder by default but there is a way to make them visible. You might need to gain access to this folder for troubleshooting purposes.
Basically, if you delete the System Volume Information folder, you will no longer have the files and data needed to restore your system to a previous state. For example, if Windows crashes or is stuck in a continuous boot cycle, you can use System Restore to restore your system to a previous "healthy" state. However, if there are no files or registry backups available, this tool is then no longer available to you. Also, if you ever decided to use System Restore, you would need to re-create the foler in the same path so that the system files can be stored there again.
Hopefully, you backup your system and keep good backups often...
Apr 13, 2009 | Microsoft Computers & Internet
How to repair dsa.msc it is not working
Reboot your DC in Directory Services restore mode and then try again. If you have a backup, then restore the backup.
Let me know if you have any queries.
Regards,
Abhay.
Apr 08, 2009 | Microsoft Windows Server Standard 2003 for...
Restore
Within the interface there are 2 options. one for backup and one for restore. using the restore, you can select the files that you need and complete the restore
Aug 08, 2008 | Veritas Backup Exec 10 for Windows Servers...
I'm trying to uninstal AVG, but it says there is 1 problem and will not uninstal the program. can you help me uninstal this program?
Hello darrinmoen,
You Havn't specified, What is the problem exactly. I mean you have not specified the error Description.
But still The problem could arose while uninstalling Antivirus Program would be:
1. Any *.dll file missing from antivirus directory.
2. system file of antivirus missing from System32 directory of windows.
3. Any file that belongs to antivirus are not able to load while installinfg like uninst.exe.
4.Windows installer 3.0 is not installed on ur system
(Check out all the above including reviewing ur antivirus directory for uninst.exe file)
To solve this error you must do the following:
1. Run AVG antivirus setup program to repair. some times it doesnot give you the option if half of installed program have been removed from system.
2. Go to run type "regedit" and press enter
3. go to hkey_local_machine ->SOFTWARE -> and select AVG
expand trees of AVG.
4. Check for data path and its contents in AVG directory of program files, and also For UninstPath to varify that the uninst.exe in avg directory of program files is not missplaced
5. After doing the specified solution 60% are the chances that ur program would be uninstalled. else if it doesnot uninstall the program and gives the same error then Choose system restore tool.
For restoring do the following:
1. Go to Start -> All Programs -> Accessories ->System Tools
and select System Restore
2. Go to next window, Choose the restore point that was before installing of ur AVG Antivirus.
3. Select that restore point by reading the description.
4. Click next to restore.
Note: Your system will restart after choosing the restore point and clicking next. It takes some time to restore.
Most probably this tool will help you to remove this antivirus.
Remove it's entry from registry by Going to run type "regedit" and press enter
go to hkey_local_machine ->SOFTWARE -> andright click AVG
and select delete option to delete.
Gimme acknowledgement after removal
Romy
Aug 03, 2008 | Microsoft Windows XP Professional With...
How to get more restore point fron corrupted windows 98 registry. my friends move all directory to d: drive. how to bring back to C :
Hey there
The first thing that you should aware of is you cannot move the system file that are currently being used by another program to any of the directory. If it is so then you wont be able to log on to ur computer. because it will give you a lot error of missing system files.
For restoring your system do the following:
2. Go to next window, Choose the restore point that is available remembering ur system was exactly what you wanted for.
for creating the restore point, follow the same step specified above except the second one. you need to select create new restore point insted of choosing restore point to restore.
Type a restore name and click next to create.
Gimme ur acknowledge by rating me
thanx
Romy
Jul 05, 2008 | Microsoft Windows 98 for PC
Backup DHCP,AD of win 2000 .
How To Use the Backup Program to Back Up and Restore the System State in Windows 2000 var sectionFilter = "type != 'notice' && type != 'securedata' && type != 'querywords'"; var tocArrow = "/library/images/support/kbgraphics/public/en-us/downarrow.gif"; var depthLimit = 10; var depth3Limit = 10; var depth4Limit = 5; var depth5Limit = 3; var tocEntryMinimum = 1; .toc{display: none;} SUMMARY loadTOCNode(1, 'summary'); This article describes how you can optionally back up the system state in the Windows 2000 Backup program to back up and restore critical system data. When you choose to back up the system state on a domain controller, the following items are included: • Active Directory (NTDS) • The boot files • The COM+ class registration database • The registry • The system volume (SYSVOL)When you back up the system state on a non-domain controller, the following items are included: • The Boot file • The COM+ class registration database • The registryWhen you back up a member server or domain controller with Certificate Server installed, the following additional item is also included: • Certificate ServerWindows 2000 Backup can back up and restore Active Directory on Windows 2000 domain controllers. You can perform a backup operation while the domain controller is online. You can perform a restore operation only when the domain controller is booted into Directory Services Restore mode (by pressing the F8 key when the server is booting).
uparrow.gifBack to the top
How to Back Up the System State on a Domain Controller loadTOCNode(2, 'summary'); 1. Click Start, point to Programs, point to Accessories, point to System Tools, and then click Backup. 2. Click the Backup tab. 3. Click to select the System State check box. (All of the components to be backed up are listed in the right pane. You cannot individually select each item.)
NOTE: During the system state backup, you must select to back up the Winnt\Sysvol folder. You must also select this option during the restore operation to have a working sysvol after the recovery.The following information applies only to domain controllers. You can restore member servers the same way, but in normal mode.
If any of the following conditions are not met, the system state is not restored. Backup attempts to restore the system state, but does not succeed. • The drive letter on which the %SystemRoot% folder is located must be the same as when it was backed up. • The %SystemRoot% folder must be the same folder as when it was backed up. • If sysvol or other Active Directory databases were located on another volume, they must exist and have the same drive letters also. The size of the volume does not matter. uparrow.gifBack to the top
How to Restore the System State on a Domain Controller loadTOCNode(2, 'summary'); 1. To restore the system state on a domain controller, first start the computer in Directory Services Restore Mode. To do so, restart the computer and press the F8 key when you see the Boot menu. 2. Choose Directory Services Restore Mode. 3. Choose the Windows 2000 installation you are going to recover, and then press ENTER. 4. At the logon prompt, supply the Directory Services Restore mode credentials you supplied during the Dcpromo.exe process. 5. Click OK to acknowledge that you are using Safe mode. 6. Click Start, point to Programs, point to Accessories, point to System Tools, and then click Backup. 7. Click the Restore tab. 8. Click the appropriate backup media and the system state to restore.
NOTE: During the restore operation, the Winnt\Sysvol folder must also be selected to be restored to have a working sysvol after the recovery process. Be sure that the advanced option to restore "junction points and data" is also selected prior to the restore. This ensures that sysvol junction points are re-created. 9. In the Restore Files to box, click Original Location.
NOTE: When you choose to restore a file to an alternative location or to a single file, not all system state data is restored. These options are used mostly for boot files or registry keys. 10. Click Start Restore. 11. After the restore process is finished, restart the computer.
Dec 02, 2007 | Microsoft Windows Server Standard 2003 for...
HP 48gx Calculator Logo
100 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
