Question about Toys
I have a traxxas 2216 micro receiver and need to know how to hook it up.
I have traxxas slash 2 wheel drive with a traxxas XL5 ESC EZ SET Receiver.wich transmitter would be compatible with this receiver?
Personally I would just go on Ebay and buy a transmitter and receiver setup. Will likely be as cheap as trying to buy one part plus if your current setup is the older crystal type you can upgrade to a 2.4ghz setup and then you have no worries about interference and the antennae are much shorter or internal.
Dec 27, 2014 | Toys
CANNOT GET GREEN LED ON 2218 TRAXXAS RECEIVER
Hi I am having problems with my 4x4 slash 1/10 scale
When I turn on the vxl-3 and that turns green but the traxxas link goes red for 3-4 sec then starts blinking red can anyone help please
Jul 07, 2012 | Traxxas Link 2.4 Ghz 5 Channel Receiver...
Traxxas bandit vxl doesn't work i left my traxxas bandit vxl for 1 day and came back and drove and when i got outside and drove pass my sidewalk to go on the road the esc started flashing red slow
Are you running a lipo or nmhi? You could have the lipo cut off turned on and the battery is too low. Or it could have a bad motor. Try hooking up another motor an see what happens. Or try to turn off lipo mode.
Mar 13, 2012 | Traxxas Bandit Vxl Brushless Buggy
Need to by pass security code
hi, you can call the service center at 1-800-233-2216....they will charge $25 to assist in removing the code. this worked for my friend's unit.
good luck,
Feb 21, 2011 | Eclipse CD3422 CD Player
I need to know what the specs would be for the case cooling fans so I can replace them.
40mm fans 5v bearing type. or you can change them to 12v fans same size and hook them up to the hard drive power leads. 2w fans only.
Dec 13, 2010 | Dedicated Micros Digital Sprite 2 RS Video...
My nitro rc traxxas truck is not turning what do i do?
Check servo saver to make sure it has not loosened up. If the servo is not trying to turn at all check the connection at the receiver. If it is okay, you can always switch the steering and throttle servos at the receiver to rule out the possibility of a faulty servo. They can fail if they get too wet or get hit hard enough.
Dec 27, 2009 | Traxxas T Maxx 3.3 Monster Truck
Need code to unlock eclipse deck 5440 or customer service number please
800-233-2216(not open on weekends).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 20, 2009 | Eclipse 5440
Toys Logo
470 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
