Question about Onkyo TX-SR500 Receiver
When power button turned on, receiver powers up
When power button turned on receiver powers up then shuts off immediately
I have had the same problem with my new Onkyo HT-S 5305B (A/V Receiver + 5.1 speakers). To solve this, try to follow "Troubleshooting" guide that came with your system. I followed it 2-3 times. In my final attempt, when system was not shutting down but stayed-n with no sound, I played with the setup and tried changing audio adjustment, input, dimension etc. and slowly I was able to get speakers up one after the other. It's working fine now.
However, I am little concerned that why such a high-class Onkyo system failed in less than two days, forcing me to troubleshoot. - Apurva
Posted on Jul 06, 2010
Onkyo ht r 340 working for only dvd
Posted on Apr 25, 2015
My receiver just shut off while watching a movie and won't turn back on. I checked the only fuse i could find. Where to go from here.
Press and hold the "straight" and "Tone control" buttons and press power. This should release the protect lock that the receiver is in. If it shuts back off immediately, then you most likely have a blown amp that will need to be repaired.
Apr 16, 2015 | Yamaha RX-V373 5.1 Channel AV Receiver
Onkyo AV Receiver TX-SR503 While sleeping with earphones connected, the receiver shut down and the standby light blinked. I unplugged the power cord, reconnected power and the receiver shut down...
Have you provided adequate ventilation?
May be your receiver is running hot and when there is loud volume it is obviously getting overloaded. There are no fans inside 674, the only way to provide good ventilation is to keep the top of receiver clear for atleast 6 to 8 inches.
Hope that helps.....
Jul 03, 2008 | Onkyo Audio Players & Recorders
Onyko tx nr616 receiver keeps shutting off. Only stays on for approximately 3 seconds. Can you help?
The amp protection circuit has been activated. Remove the power cord from the wall outlet immediately. Disconnect all speaker cables and input sources, and leave the AV receiver with its power cord disconnected for 1 hour. After that, reconnect the power cord and reconnect an input and a pair of speaker wires onto the unit. If the receiver still does not turn on than you will have to bring it in for service. Turn up the volume and if the receiver doesn't shut down, power off the receiver and add another pair of speakers. Power up the unit again and turn up the volume. If it doesn't shut down, power off the unit again. Now connect all your input sources and turn on your receiver. If the unit shuts down again, your unit will need to be further serviced at an authorized Onkyo service center.
Sep 30, 2014 | Onkyo Tx-nr616 7.2 Thx Certified Network...
How do i check to see what is causing my receiver to shut off
Sep 25, 2014 | Onkyo Audio Players & Recorders
When i push power button clicks on immediately
I had this problem also and discovered an easy way to trick it into powering on: Click the power button, then within 1 second of the receiver powering off, click the power button again. The receiver should stay on this time. This works with both the button on the receiver and the remote control.
I would like to know what causes this problem and whether or not I should be concerned about damage being done. I assume this is a power protection. I haven't tried plugging this receiver into a different power socket to test, but I don't think the power plug is the problem. Note: I have the subwoofer plugged into the power plug on the back of the receiver.
Feb 23, 2010 | Onkyo HTR500 Receiver
My STR-DE835 receiver will not stay powered on
Most likely bad output transistors and a couple of resistors. mp1620 and mn2488 are the part #s for the transistors. If you take it to a repair shop you are looking at spending $100-$130
Nov 16, 2009 | Sony STR-DE835 Receiver
Onkyo receiver always shuts off
power output shuts ......send to service
Oct 02, 2009 | Yamaha RX-V596 Receiver
My rxv 1800 wasnt used for probably a year but was left plugged to a wall outlet during that time it wasnt used. when i came home last week, i switched it on but immediately shuts off after a second. when...
r this one: Switc off your receiver using the main power button on the front face. Hold the the Effect button and the Direct button, and turn the main power ON.f it ain't working, try this one: Turn your receiver ON and, while holding down the [VCR1] button, press the [STANDBY/ON] button. "Clear" might appears on the display and your receiver might enter Standby mode.
Hope it does.. With your receiver in the Standby mode, hold on STRAIGHT (EFFECT) on the front panel and press STANDBY/ON.
* The ADVANCED sETUP menu appears in the front panel display.ress STRAIGHT (EFFECT) to select the desired setting.
RESET = To reset your receiver to its factory presets.
CANCEL = To cancel without making any changes Press STANDBY/ON to confirm your selection.
* If you selected "RESET", your receiver is reset to its factory presets and switches to Standby mode good luck
shaun
Aug 24, 2009 | Yamaha RX-V1800
Power will not stay on
www.eserviceinfo.com/downloadsm/28790/Onkyo_HT-R500.html
Jun 03, 2008 | Onkyo HTR500 Receiver
Immediate shut
Unplug all the speaker wires first, then unplug the unit from the wall for at least 24 hours, The plug back in without the speaker wires or anything else plugged in. Then see if it goes to the protection mode. If it does not, plug in each speaker at a time, and see if any speaker, when hooked up, makes the receiver shut down. If it does shut down, My friend, I'm afraid you will need to take this unit into a repair shop, OR get a new unit. Good Luck
Jun 06, 2007 | Yamaha RX-V630 Receiver
Onkyo TX-SR500 Receiver Logo
661 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
