Question about Canon FAX-JX200
Same fax and phone number
Voice mail picks up on the telephone after 2 rings and the fax is set to receive after 4 rings. But  fax keeps ringing and does not receive. Are my settings wrong? For how many seconds should the fax ring??? How difficult and inefficient is it to use the fax and telephone number on the same line?
  • RAJKUMAR RAJU May 11, 2010
    are u put receive mode to fax tel mode ?
    Problem Solver:
  • 25 Answers
Check the setting in the receive mode button. set it to fax
Posted on May 26, 2008
SOURCE:
Hooking up fax to KX TG7871 Panasonic Phone
There is excellent support here on basic fax setups. You have what is known as "Distinctive Ringing Service". There are pros and cons to the various setups. I assume you recognize the rings and answer only when the ring for the landline talk comes on. The fax will pick up the faxes, and the answering machine will pick up the voice.
Need model number of your fax - google that!
Service manual for your phone.
http://service.us.panasonic.com/OPERMANPDF/KXTG7841-MUL.PDF
This link shows various configurations of setting up your phone/fax/answering machine or using an answering service.
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&docname=c00059780#Dist_ring
Distinctive Ringing Service setup While it is not available everywhere, a distinctive ringing service can be purchased from most telephone companies. With this service, more than one phone number is assigned to the same phone line. Each phone number will ring differently. The main number will ring with a normal single ring and the additional number will ring with a distinctive ring pattern assigned by the phone company.
When a distinctive ringing service is used, set the Rings to Answer to 2 and then follow the steps below to set the distinctive ringing pattern:
  1. Press Setup , press 4 , and then press 1 to enter the Answer Ring Pattern setup of the Advanced Fax settings.
  2. Use the Right Arrow to scroll through the available settings. When the ring pattern assigned by the phone company displays (double or triple rings), press OK .
Mar 06, 2014 | Lands Phones
Canon mf5770 not receiving faxes
Most fax machines allow you to set the number of times the phone rings before it automatically answers the phone. So if you phone goes to voice mail after 4 rings and the fax machine is set to start the fax after the 5th ring it will never receive the faxes because the call went to voice mail. Good Luck
Dec 05, 2013 | Office Equipment & Supplies
Can lexmark x4650 be set to recognize fax?
For more details on how to setup your Lexmark X4650 printer for faxing, please refer to the User's Guide found on the Lexmark website.
Additional info:If you have an answering on the same line as your fax:
To make sure the printer picks up incoming faxes, set Auto Answer to On, and then set the printer to pick up after a greater number of rings than the answering machine. For example, if the answering machine picks up calls after four rings, then set the printer to pick up after six rings. This way, the answering machine picks up calls first and your voice calls are received. If the call is a fax, then the printer detects the fax signal on the line and takes over the call.
If you have a voicemail feature associated in the same line as your fax:
Voice mail and fax can share the same telephone line if you subscribe to a distinctive ring service offered by your telephone company. This feature allows you to have multiple telephone numbers on one telephone line. Each telephone number has a designated ring pattern (single ring, double ring, triple ring, or double and triple ring). The different ring patterns let you know which telephone number was dialed, and which device you should use to answer the call.
If you do not have distinctive ring service, then set the printer to receive faxes manually (Auto Answer Off). This setting lets you receive both voice calls and fax calls, but works best if you use voice mail more often. You need to turn off voice mail whenever you are expecting a fax.
Feb 16, 2012 | Lexmark X4650 InkJet Printer
Fax won't answer
If you have an answering machine connected to the same line as your fax:
If you have a voicemail feature associated to the same line as your fax:
I hope this helps.
Should you need further assistance, please contact Lexmark Technical Support Center.
Feb 14, 2012 | Lexmark Pro901 All-In-One Inkjet Printer
How do I increase the number of rings on my Brother MFC-780n fax/printer before it picks up?
Setting the Ring Delay
The Ring Delay sets the number of times the
MFC rings before it answers in Fax Only or
Fax/Tel mode. If you have extension
phones on the same line as the MFC or
subscribe to the telephone company’s
Distinctive Ring service, keep the Ring Delay
setting of 4.
(See Operation from extension telephones on
page A-4 and Easy Receive on page 4-3.)
1 If it is not illuminated in green, press
(Fax).
2 Press Menu/Set, 2, 1, 1.
3 Press ▲ or ▼ to select how many times
the line rings before the MFC answers
(00 - 04).
Press Menu/Set.
(If you select 00, the line won’t ring at
all.)
4 Press Stop/Exit.
Initial Setup
1.Receive Mode
Current Receive Mode
Fax : Fax Only
F/T : Fax/Tel
TAD : External TAD
Mnl : Manual
Setup Receive
1.Ring Delay
Apr 02, 2010 | Brother MFC-7820N All-In-One Laser Printer
IT WILL RING BUT GOES TO ANSWERING MACHINE DOES NOT RECEIVE FAX
>first run fax test, press set up go to tools menu then select run fax test,all entries should be pass
>then check your connections, do you have one line or number for your fax and phone?or a separate line or another number for fax and another number for phone?
>let me assume you only have one number for fax and phone..
>check connections, this should be downstream connection, the fax machine using the black phone cord provided by hp should be connected directly to the phone jack using line 1 at the back of the fax and the answering machine or the telephone should be connected to ext 2 or line 2 at the back of the fax...there should be no other devices phone or answering machine connected directly to the phone jack.
>next set rings to answer on the fax machine higher than the answering machine...if your rings to answer on answering machine is 4 rings, set the fax to 6 rings...if it is a voice call the answering machine will pick it up at 4 rings then if it detects that it it a fax tone then it will transfer the call to fax.
>also check if auto answer is on in your fax
>you can check auto answer and rings to answer by pressing set up or menu button on your machine look for it in basic fax settings or advance settings
>also check if your voice prompt for your answering machine is not too short there should be like at least 5 seconds after cutting your message to allow the machine to transfer the call to the fax if it is a fax tone.
Sep 14, 2009 | HP 1040 Plain Paper Inkjet Fax
Canon MP530 receive fax issues
Receive Mode Settings Select from the following receive mode options to suit your needs. Once you've decided on which receive mode to use, follow the below instructions to set the receive mode using the operation panel. Receive Mode Setting
  1. Press the <FAX> button to enter Fax mode.
  2. Press <Menu>.
  3. Press the right or left arrow button to select [Receive mode settings], then press the <OK> button.
  4. Press the up or down arrow to select the receive mode that best suits your needs, then press <OK>.
Types of receive mode
Select the receive mode according to your needs.
Receive mode
Purpose
FAX/TEL AUTO SW When you want to receive faxes automatically as well as voice calls. FAX ONLY MODE When you want to receive only faxes automatically with your machine, or have a dedicated telephone line for FAX use only. DRPD When you have subscribed to a DRPD service with your telephone company. MANUAL MODE When you receive mainly voice calls and sometimes faxes, or want to receive faxes manually. ANS.MACHINE MODE When you want to receive voice messages on your answering machine and receive faxes automatically. FAX/TEL auto switch
FAX :
The machine does not ring but will receive the fax automatically. Voice call :
The phone attached to the machine will ring. Pick up the handset to answer the call. Note:
  • Ring start timing and Telephone ring length can be specified in FAX/TEL auto switch in the Receive mode settings.
  • If you want the telephone to ring when it receives a fax, connect a telephone to your machine and enable the Incoming ring settings in RX settings.
  • The phone attached to the machine may not ring depending on the telephone type you are using.
FAX only
FAX * :
The telephone does not ring. The machine will receive the fax automatically. Voice call :
You will not be able to answer the call. * If you want the telephone to ring, connect the telephone to your machine and enable the Incoming ring settings in RX settings menu.
DRPD
FAX :
Your telephone line will ring according to the ring pattern you have chosen and receive the fax automatically. Voice call :
Your telephone line will ring according to the ring pattern you have chosen. Pick up the handset to answer the call. Note: Specify the FAX pattern in the DRPD: Set FAX ring pat. in RX settings menu.
Manual RX
FAX :
The telephone attached to the machine will ring. Pick up the handset and if you hear a beep tone, press the <Color> or <Black> button on the machine to receive the fax. Voice call :
The telephone attached to the machine will ring. Pick up the handset to answer the call. Note: If you are far from your machine, you can use the remote receiving function to receive faxes. Pick up the handset of the telephone connected to the machine and press 25 (the remote receiving ID).
Ans. machine connect
FAX :
First the answering machine connected to your machine will respond to an incoming call, and then the machine will receive faxes automatically. Voice call :
The answering machine connected to your machine will respond to an incoming call. Note:
  • Set the answering machine to answer on the first or second ring.
  • The entire message should be no longer than 15
Nov 24, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Same Number for Fax and Telephone
The fax is designed for use with an answering machine, the greeting for which must be no longer than 15 seconds. If voice mail in this case is referring to answering machine, be certain that the message is as indicated.
If you need further assistance, please post back. Otherwise, thank you for using and rating FixYa!
Mar 29, 2008 | Canon FAX-JX200
Setting personalized ring
Its called distintive Ring. This is the instructions from the manual -
VERY IMPORTANT
If you have Voice Mail or a TAD (Telephone Answering Device) and want to keep
one of your phone numbers dedicated only to fax calls, you must leave the fax machine
in MANUAL mode at all times while using the distinctive ring feature. Here’s why:
Manual mode will never pick up a call by itself, since it is «Neutral ». When the fax
machine is in this « neutral » mode, the Distinctive Ring Feature can be activated. The
distinctive ring feature is actually an answering mode. So, do not activate FAX ONLY
mode or FAX /TEL mode while using distinctive ring; otherwise, the fax machine will
answer calls for all the numbers.
Registering the Distinctive Ring Pattern
Set the fax machine to MANUAL mode.
2 Press Menu/Set, 0, 1.
3 Press to select DISTINCTIVE:SET?, and then press Menu/Set.
4 Press to select the prestored ring pattern you want to assign, and then press
Menu/Set. (You will hear each pattern as you scroll through the four patterns.)
Be sure to choose the pattern assigned by the Telephone Company.
5 Press Stop/Exit.
and a link to the manual if you need it -
http://static.tigerdirect.com/pdf/brother-IntelliFax-775-Manual.pdf
Feb 21, 2008 | Brother IntelliFAX 775 Plain Paper Thermal...
To recieve fax on brother
Press the 'RECEIVE MODE' button on the right side of the control panel, its next to the large 'FAX START' button. Here are your options :
Select Receive Mode
MANUAL
—You must answer all calls yourself. If you hear fax tones, press
Fax Start
to begin receiving the fax, then hang up. You can use this mode with
Distinctive Ringing. (See
Distinctive Ring
, page 8-1.)
FAX ONLY
—The fax machine automatically answers every call as a fax call. You
cannot receive a voice call, but you can dial out and make a voice call.
FAX/TEL
—The fax machine automatically answers every call. If the call is a fax, it
prints the fax. If the call is not a fax, it signals you with a double-ring (ring-ring),
different from the phone company ringing, to alert you to pick up the call. If you select
this setting, you’ll need to set the Ring Delay and F/T Ring Time features (on the
following pages). If you have extension phones on the same line as the fax machine,
set Ring Delay to 4. (See
For FAX/TEL Mode Only
, page 5-5.)
TAD:ANSWER MACH.
—This is the only setting in which you can use an external
answering machine. Your telephone answering device is connected to your fax
machine, and answers every call. Once the TAD answers, the fax machine listens for
fax tones. If it detects fax tones, it prints the fax.
The TAD setting works
only
with an external telephone answering device (TAD); it
does not work with telephone company Voice Mail. Ring Delay and F/T Ring Time
do
not
work in this setting.
Nov 27, 2007 | Brother IntelliFAX 775 Plain Paper Thermal...
Canon FAX-JX200 Logo
206 people viewed this question
Clive
Clive
old marine
old marine
Ekse
