Question about Amcor AM-40 Air Purifier
Fragrance cartridge I have an amcor am-40 and would like to get replacement fragrance cartridges but can't locate them anywhere. Can you tell me where I can buy them.
Scent cartridges
I'm not sure where you can get scented cartridges, but I know that home- made scent packs can be made using aromatic oils. There's dozens of scents. just place some on a piece of cotton and place in the container where the cartridge would go.
Mar 30, 2014 | Amcor Air Purifiers
Need new filters
You may need to order the filters directly from Amcor unless you can find a local source
May 02, 2013 | Air Purifiers
I need a filter for Amcor Ficus Tree Air purifier
If the activated charcoal filter, take your old one apart and trim down a larger on from a competitve machine to fit yours. The same if it is a HEPA filter you want to change as well.
Otherwise metal and plastic filters can be washed. Spray with a grease cutter like 409, which will also lightly etch the metal without reacting with the plastic.
Jan 31, 2012 | Amcor Ficus Tree Air Purifier & Ionizer...
I need to know where to purchace the fragrance for the oreck air 7?
Below is a link to Oreck's website where you can order fragrance packets for your air purifier. If there's an authorized Oreck repair facility in your area, they may carry these as well.
Oreck Parts&Accessories
Jan 13, 2012 | Oreck Super Air 7 Air Purifier
Can you use other Fragrances
I have used other oil based fragrances and have had no problems.
Jun 06, 2009 | Rainbow Rainmate Air Purifier
I just set up my new rainmate in my son's room with the eucalyptus scent (he has a cold/cough), and I needed to know how safe is it to leave the unit running overnight, and how long does it take for the...
Hey im a dealer for Rainbow. RockyNR1 is correct but let me just add that you can fill it to over the line if you want as long as the 'misting' still happens, be careful that the bowl is not near the edge of the surface as the spinning water might make it fall off the side. How long the water lasts is also very dependent on how large the room is that its in. Lastly you should be able to leave it run for 24/7
Jan 27, 2009 | Rainbow Rainmate Air Purifier
Cloudy looking water
Does it do this when you DON'T add any of the fragrance oils???? If so, it's yuck from the air. BUT, the fragrance oils are OIL and they don't mix with water, so as it swirls it tries to emulsify the oils into the water and that causes it to become cloudy.
I would still clean it at least every other day....every day would be preferable....especially if you live somewhere that mold flourishes like I do (Central Texas)
-D
Oct 10, 2008 | Rainbow Rainmate Air Purifier
Amcor AM-40 Air Purifier Logo
63 people viewed this question
Top Amcor Air Purifiers Experts
Are you an Amcor Air Purifier Expert? Answer questions, earn points and help others
