Whenever I bot my laptop it shows message "Windows could not start because the following file is missing or corrupt
/system32/hal.dll. Please re-install a copy of the above ile.
im having this problem on my desktop computer how to fix problemcorrupt file: <windows root>\system32\hal.dll
You can't post conmments that contain an email address.
To repair missing or corrupted system file/s, boot up with the Windows installation CD then - Press R to repair when instructed. Press 1 or Enter to repair the C:\Windows folder. Then type chkdsk /r and then press Enter. The repair process will take quite a long time.
Boot to the WIndows XP CD (Press spacebar when prompted to press any key) at first prompt in setup, press R to enter recover console.
At the C:\Windows\System32\> prompt type bootcfg /rebuild then press enter
http://support.microsoft.com/kb/330184
reboot see if error resolved.
If not then try running diagnostics by pressing Fn plus power button, see if there is a HDD malfunction
Time to get out that restore disc you made when you first got your laptop. The boot sector has errors. Boot with your rescue disc and run CHKDSK/F to clear the errors. Hope that helps.
Windows could not start because the following file is missing or corrupt: /WINDOWS/SYSTEM32/CONFIG/SYSTEM You can attempt to repair this file by starting Windows Setup using the original Setup CD-ROM Select “r” at the first screen to repair
So then i click r at the first screen and nothing happens...It keeps on repeating to repair on and on with the same message after i clicked r. I can't even access to the window...what can i do???
"Windows could not start because the following file is missing or corrupt: <Windows root>\system32\hal.dll. Please re-install a copy of the above file."
"<Winnt_root>\System32\Hal.dll missing or corrupt: Please re-install a copy of the above file."
"Cannot find \Windows\System32\hal.dll"
"Cannot find hal.dll"
The "missing or corrupt hal.dll" error displays shortly after the computer is first started. Windows XP has not yet fully loaded when this error message appears.
CauseCauses of the "missing or corrupt hal.dll" error include, naturally, a damaged hal.dll DLL file or a hal.dll file that has been deleted or moved from its intended location.Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged hard drive.
Please let me know you have any further questions or concerns.
Thanks.
ok..sounds like an operating system mismatch...you may need to remove the software entirely, go to www.hp.com and get a fresh edition of the print manager..sometimes that file gets corrupted..
corrupt file:\system32\hal.dll
