Question about IBM (DTNA-22110) (DTNA22110) 2.1 GB Hard Drive
I have hooked up a ibm DTNA-22110 harddrive from old think pad to my windows 7 hp via sata/ide to usb cable. Os says that usb mass storage available but the ibm driver does not load. Can i find driver? Why is the hd not docking to my computer?
  • 450 Answers
Try a computer with Windows XP SP2 operating system installed.
You will have all the drivers in SP2.
This will work! Please vote!
Posted on May 12, 2010
Find socket for hard drive
HP part number 5188-5473 brings up the Asus A8N-LA motherboard, made especially for HP,
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00647121#N413
The rest of the number/letters do me no good.
I will elate some information based on the above, and see if it does you any good;
1) The Asus A8N-LA has connectors for two types of Harddrives;
A) IDE. Also known as PATA.
This type of Harddrive uses a flat ribbon IDE(PATA) data cable,
http://en.wikipedia.org/wiki/File:Nappe.svg
Another look,
http://en.wikipedia.org/wiki/File:ATA_cables.jpg
(The Asus name probably won't be on it. These two IDE data cables just happen to be made by Asus )
The connectors on each end have 40 socket holes. One socket hole will be blocked off. (Or should be) ONLY 39 socket holes are used.
http://en.wikipedia.org/wiki/File:PATA-cable.jpg
A look at the connector on the motherboard;
http://en.wikipedia.org/wiki/File:ATA_on_mainboard.jpg
Looking at the motherboard illustration, look at the Bottom/Right corner. There are two IDE connectors. They are marked as IDE 1, and IDE 2.
Scrolling down a little bit to the motherboard photo, you will see IDE 1 connector is Black in color, and IDE 2 is Blue in color.
The IDE (PATA) harddrive's data cable goes to IDE 1.
Optical drive/s (CD/DVD drive) goes to IDE 2.
This is the type of power cable from the Power Supply, that goes to an IDE (PATA) harddrive,
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
NOTE*
There is usually a square, or rectangle, or two bumps; used on the IDE ribbon cable connector, to line up with the connector on the motherboard, or harddrive, or optical drive.
It is called a Locating Lug.
This particular IDE data cable connector, has two raised bumps, for a Locating Lug.
It lines up with a Cutout in the motherboard's connector, or the harddrive's connector, or the optical drive's connector.
IF, there is NO Locating Lug, use the faint Red stripe on the side of the IDE data cable.
The red stripe is on the same side as Number 1 wire.
Number 1 wire goes to number 1 pin.
On a harddrive, or optical drive, number 1 pin is ALWAYS closest to the power cable connection,
Looking at the photo number 1 pin is on the Right side. It is closest to where the 4-pin Peripheral power cable plugs in.
B) SATA:
Looking at the motherboard photo, the Yellow, and Blue, and Black, and White connectors; to the left of the Blue IDE connector, and Black IDE connector; are SATA connectors.
SATA 1 is Black. This is where the SATA harddrive's data cable, is supposed to plug in.
The BEAUTY of SATA though, is that you can plug the harddrive into ANY of those SATA connectors on the motherboard, and BIOS will find the harddrive. (Or any other peripheral device)
An example of a SATA data cable, and it's connector,
http://en.wikipedia.org/wiki/File:SATA_ports.jpg
The red SATA connector shown below the SATA cable example, is just a different style of SATA motherboard connector; than what your motherboard uses.
Note the L-shaped opening in the SATA data cable's connector.
Lines up with the L shape on the motherboard connector, or harddrive connector, or optical drive connector.
Most SATA data cable connectors, also have a Lock on them.
Sometimes it's a Lock you can easily see.
Most times, it is a small depression you depress with your thumbnail, or a little 'bulb' you depress.
Depress/unlock to plug the cable in, or remove the cable.
The 90 degree angle connector end, (As shown), plugs into the harddrive, or optical drive. The Straight connector end plugs into the motherboard.
This is an example of a SATA power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#sata
Between it, and the SATA data cable connector, it is the larger of the two.
SATA power cable connector has 15-pins.
SATA data cable connector has 7-pins.
Also note the rectangular depression on the SATA power cable's connector. That is where you depress to unlock the connector.
The SATA power cable's connector also has an L-shaped opening.
2) IF, you are trying to hook up a laptop harddrive to this motherboard, you need to determine if the laptop harddrive is an IDE (PATA) type, or a SATA type.
How?
Easy.
There is a label on the laptop harddrive. It has the manufacturer code on it. Type the number/letters in your browser search bar, and click on the search icon. (Magnifying Glass)
Now purchase an external enclosure.
The external enclosure opens up, and the laptop harddrive goes inside, and plugs into an interface.
Close the external enclosure, and plug it's USB cable into any available, open USB port on your computer.
It will be a 2.5 external enclosure.
Harddrive's are measured across their width.
A desktop harddrive is 3.5 inches across in width.
A laptop harddive is 2.5.
Example of a 2.5 IDE (PATA) external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1086960&CatId=2782
Example of a 2.5 SATA external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3195233&CatId=2783
For additional questions please post in a Comment.
Regards,
joecoolvette
Jan 28, 2013 | HP Compaq Motherboard
55274-OEM-0011903-00107
http://uk.answers.yahoo.com/question/index?qid=20080820061943AANsZGh
IBM Thinkpad? Then post the MODEL NUMBER.
It's on the bottom.
Thinkpad T42?
http://support.lenovo.com/en_US/product-and-parts/detail.page?&LegacyDocID=MIGR-50075
This is an example of one of the harddrives in the list.
An Hitachi 08K9834 ATA 40GB harddrive,
http://www.shopping.com/IBM-HARD-DRIVE-40GB-5400RPM-08K9834/info
Hitachi - Manuafcturer
08K9834 - Model Number
ATA -100 - This is an IDE (PATA) harddrive
http://en.wikipedia.org/wiki/Parallel_ATA
It is NOT a SATA harddrive.
The answer is NO.
The laptop will not use a SATA harddrive.
Regards,
joecoolvette
Jan 16, 2013 | Computers & Internet
Can not get computer to recognize hard drive any more?
You could try using another USB port on your computer. Perhaps that USB port you have the IOmega external harddrive plugged into is bad.
More than likely not, though.
The problem is usually inside the IOmega's case. (External enclosure)
Inside that IOmega external harddrive's case is a regular harddrive as used in a desktop, or laptop computer.
To explain;
Harddrives are physically rated in width, as well as type, and size.
A laptop harddrive is 2.5 inches across in width. (2 and a half inches)
A desktop harddrive is 3.5 inches.
The larger desktop harddrives are usually used in external harddrives that are 500GB, and larger.
(Not always the case when it comes to the 500GB size)
Harddrives have two technologies, or types.
IDE (PATA) or SATA.
You didn't state the Model Number so I can't even hazard a guess at this point.
The harddrive inside the case plugs into an Interface.
The Interface may be separate, and connected via a cable to a small circuit board, or the Interface may be soldered directly to the small circuit board.
It is this Interface, and circuit board which go bad.
The solution is to remove the harddrive inside, purchase an inexpensive external enclosure, and install the harddrive into it.
The external enclosure has a USB cable just like the IOmega external harddrive did.
As stated the harddrive inside is just a normal harddrive. Made by a harddrive manufacturer.
Could be a Western Digital, or Seagate, or Hitachi, or Maxtor, or Fujitsu, or IBM, just to name a few.
(Seagate bought out Maxtor)
On the harddrive will be a decal with it's specifications.
You will also be able to physically measure the width.
This external hookup will support harddrives that are 2.5, or 3.5 inches in width, (And 5.25), plus will support both IDE (PATA) or SATA harddrives,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=7220658&CatId=3770
This external enclosure is for a desktop sized harddrive, 3.5 inches, and will support either IDE (PATA) or SATA harddrives,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1951866&CatId=2780
This external enclosure example is for laptop sized harddrives, 2.5 inches, and will support either IDE, (PATA), or SATA harddrives,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=7041055&CatId=2783
Just one example of how to disassemble an IOmega Select Portable harddrive,
http://www.youtube.com/watch?v=NvUvz5Qb4vw
Other styles are listed in the Suggestions column down on the right.
Not a good source for information on disassembling an IOmega external harddrive, but there is very little info available.
(It isn't that tough for any external harddrive enclosure. The screws are usually hidden under labels, and the case pops apart in two halves. Just a little different design here, and there)
Regards,
joecoolvette
Jun 14, 2011 | Iomega Computers & Internet
My ibm r40 2682 has problems staying on windows. it can go threw the stages of getting to the main screen but it only stays on for 60's or less. i dont know what's wrong. if you can help me i...
Here is how to use the recovery for the thinkpad
http://www-307.ibm.com/pc/support/site.wss/MIGR-4UFUYK.html
Check disk is very good fix for all computers and hard drive fixes most problems and repairs the drive...
Using a windows install disk...Start the computer press F1 to start from the cdrom
when you turn on the thinkpad, press F1,This goes to your bios..
This is the link to tell you how to get to your bios http://www.ehow.com/how_6284327_boot-ibm-thinkpad-r40-cd.html
Start the computer press any key to start from disk and then press R for repair when prompt this will go in to DOS command prompt Press 1 and the enter for C: Windows.. If there's a password press enter..
Type ....CHKDSK C: /P /R ......... C: Is your O/S hard drive...don't turn off the computer it may take hours 20 gig hard drive not long...when finished checking disk type exit remove install disk and restart the computer....
After run Malware bites
(http://www.filehippo.com/download_malwarebytes_anti_malware/download/d1b4a4e1bd839ee3d9a605e7f89c061e/ ) you could try and install and run this in safe mode...
Sorry it took so long I had to research.. I have a think pad e600 I fixed mine with the installtion disk because the type of harddrive.. It would not go in any of my other computers SATA or IDE even though it is an IDE HDD but IBM is different..
May 15, 2011 | Computers & Internet
IBM THINKCENTRE A51p WIN XP PRO/SP3 1GB RAM ALL MICROSOFT UPDATES ARE CURRENT BOOTS QUICKLY WITH 1 SATA HARDDRIVE (1.5 MINUTES) BOOTS SLOWLY WHEN 2ND SATA IS ADDED (5 MINUTES) ONCE WINDOWS...
it seems as they are conflicting this u usually caused by jumper settings you need to download the utility program from the hdd manufacture the utility allows you to change hdd priority you need to change the settings on the second hdd to slave and the first hdd to master but like i said unlike ide which has jumpers sata has digital jumpers the utility from products website is needed for this
Sep 02, 2010 | IBM ThinkCentre A51 PC Desktop
My hard drive is failing on an IBM NetVista 8305. Is there a specific hard drive that needs to be put in to replace the failed one, and where would I find that drive? I've run into compatibility issues...
I've had a quick look a a photo of your motherboard and it looks like it supports both SATA and PATA IDE devices.
Have a look inside the tower, if you current HDD is connected via a fairly broad grey ribbon cable, its using a PATA IDE interface - the older fashioned one.
If its connected with a fairly narrow flat red coloured cable, then its a SATA interface.
Remember to set the jumper settings on your new drive to match those on your old one.
Mar 14, 2010 | IBM NetVista 8305 PC Desktop
I have an old ibm aptiva with usb port nad trying ot transfer files to external hard drive, however it doesnt recognize the harddrive, what can i do?
Depending on the external drive (try it in another computer first) the case may be bad. You can purchase an IDE cable at your local computer store, take the hard drive out of the case, plug it in directly, and voila!
Jan 13, 2010 | IBM Aptiva E 240 (2158240) PC Desktop
IBM Think Pad TDD
reinstall the OS, but first back up you files. you can remove the HDD located at the bottom of the Laptop. buy a cheap 2.5 inch usb to ide/sata enclosure and place your hdd on it. use a PC to transfer your files. then format the HDD. reinstall the HDD to your laptop and install the OS.
Jul 06, 2009 | IBM ThinkPad T22 2647 Notebook
How to install bigger HD in IBM 300GL GL PC? Any limitations?
Is it IDE or SATA? Put the Hdd in your pc, on IDE, the wide ribbon cable is for data, it can only go in one way, and power is the molex connector. 4 power points, ussualy 4 wires. orange, black, red, black, yellow. can only go in one way. thats it. Make sure that if you are running cd/dvd roms and you have 2 hdd's, that the two hdds run on the same ribbon cable, and the cd roms on their own cable. also put the new hdd to slave. (you change it via jumper settings, ussualy printed on the hdd itself)
SATA is easier. you need two cables. sata power, and data. they can also only go in one way. google sata connectors if you don't know how they look. though, if i is a PIII board, i doubt it'll support SATA, so you'll need to buy an IDE hdd.
Goodluck
Jan 05, 2009 | IBM PC 300GL PC Desktop
Computers & Internet Logo
97 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
