Gibson front load washing machine will not spin
Hi Tech 17. Following up on your reply - Well it turns out that the machine will stiil not spin with water in it. After putting the pump back in (after finding the nickel in it), the machine went into the spin (with all water drained from the basket from my taking out the pump). To confirm that it would spin I put it into a full wash cycle. At the end it would not spin and all water remained in the basket with the clothes. I'm wondering now if it will not spin because the water is not being pumped out and it is not being pumped out because the pump impeller was damaged by the nickel and therefore the pump needs to be replaced?
  • 1 more comment
  • contactakm May 13, 2009
    Just hooked up my brother's gibson front loader after moving it from across town. Had sat unused in his basement for quite some time. Now goes through cycle but won't spin and leaves clothes wet with water left in tub.
  • hollyjean712
    hollyjean712 Jul 27, 2012
    I am having the exact same problem. My sister sold me hers, it worked when she sold it to me. I moved it to my home across town, and got it into the basement. I was doing a test load and to clean it, as it had sat with stagnant water in the pipes, and drain, and smelled. The washer washed the clothes, and rinses, from what i could tell, it agitates through these cycles but then when it gets to spin it just sits there. I adjusted the basket and it started to spin out BUT no water was draining. Then the next time I put it on spin it didnt spin again. Didnt know if it could be a clogged drain tube that would prevent the washer from spinning? Will the washer not spin if the water wont drain? I am going to unhook the drain tube from the back of washer and see if anything is clogged in there, then I guess I will check the pump. I am just wondering if the washer wont go to spin mode if the water doesnt drain? I know the basket agitates, and it moves freely so its not that, so the motor that turns the basket should be good. BUT The Million Dollar ? is, will the washer not spin if the pump isnt working or if there is a clog?
  • hollyjean712
    President:
  • 1,314 Answers
Are you sure the pump is plugged up and was the impeller damaged
Posted on Mar 29, 2008
  • robert samples Mar 30, 2008
    look something may be jamming the pump again that boot that connects to the pump is called a sump and when you clean the pump you need to reach in the boot and clean that out too my bad i just assume everybody does that anyway but the impeller could be damaged
My front load washing machine agitate but won't spin
If your machine is rather old or used quite frequently, you should check out the motor brushes. Go to youtube for details on washing machines brushes.
Mar 06, 2015 | Washing Machines
The washer will not spin
It could have an object in the pump. Your tech sheet will help. Remove the kick plate to find the the tech sheet and clean out the pump filter. Here's How
If yours is an affinity model then you might have a clogged hosethemobilian_903.jpg
Affinity service manual
If it is a duet click here
Jan 16, 2011 | Kenmore HE2 Plus Front Load Washer
Whirlpool 6AWM8143 Front Load not starting spin cycle
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 04, 2010 | Whirlpool AWM8143 Front Load Washer
LG WM-2277HW will stop at the rinse cycle and flash te code. Manual says to unplug and call tech. Is there anything else that can be done?
heatman101
Jun 01, 2010 | LG WM-2277HW Front Load Washer
Front loader, will not spin at high speed drain
Drain strainer on output side of pump could be clogged a little.
Sep 11, 2009 | Frigidaire ATF6000ES Front Load Washer
WASHING MACHINE WORKS UP TO DRAIN/SPIN CYCLE AND STOPS
Hi, this is just a faulty timer control module. you will need to replace this failed control device asap. you can purchase it on line if you choose below by clicking on the link provided.
CLICK HERE
May 25, 2009 | Washing Machines
Drum won't spin and water won't drain
No spin unless drains. Check pump and hose leading to it for blockage; if none then replace it. I cannot see your reply due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Nov 28, 2008 | Frigidaire FTF530FS Front Load Washer
Maytag lat8840baw washing machine.
Belts. Underneath machine. Replace both. Also make sure motor slides back and forth easily. Take off front to check that. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Nov 28, 2008 | Maytag LAT3600A Top Load Washer
Gibson front load washer will not spin
well lol thats what i was going to tell you to do if you didnt hear the crunching sound with the power off but good for you
Mar 28, 2008 | Washing Machines
Washing Machines Logo
871 people viewed this question
Top Washing Machines Experts
