Computers & Internet Logo
A
Anonymous Posted on May 10, 2010
I keep getting the error message that the installer can't find an appropriate file when I try to connect.
Anonymous
Level 1:
Problem Solver:
  • Contributor 9 Answers
  • Posted on May 17, 2010
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
9
Questions
0
Helped
5177
Points
17
2answers
Paper jam error
One of the Common error for (Papper Jam) in printer is Error 0x000003eb.
Error code 0x000003eb indicated printer connectivity or printer installation error. If you are trying to install a printer driver but keep getting Error 0x000003eb prompted, make sure you have logged in as the administrator of the computer and then try installing the driver. If the problem still happens, try the below solution steps to solve this problem. The error message doesn't give you much information as it just says unable to install the printer and gives you the error code 0x000003eb.
The Error Message shows you: "Unable to install a printer. Operation could not be completed (error 0x000003eb)"
The printer connectivity or installation error 0x000003eb occurs because the drivers are somehow got corrupted or incompatible.
We know the printer is a very important part of our day to day life. We all need a printer to get hard copies of our important files and documents within a few minutes.
WINDOWS ERROR MESSAGE
boot from the CD copy of your windows XP. enter in console session and manually replace the file. if the file is corrupted this should fix it
3helpful
2answers
Keep getting this message <window
  • "Windows could not start because the following file is missing or corrupt:
    <Windows root>\system32\hal.dll.
    Please re-install a copy of the above file."
  • "<Winnt_root>\System32\Hal.dll missing or corrupt:
  • "Cannot find \Windows\System32\hal.dll"
  • "Cannot find hal.dll"
The "missing or corrupt hal.dll" error displays shortly after the computer is first started. Windows XP has not yet fully loaded when this error message appears. CauseCauses of the "missing or corrupt hal.dll" error include, naturally, a damaged hal.dll DLL file or a hal.dll file that has been deleted or moved from its intended location.Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged hard drive.
    Please let me know you have any further questions or concerns.
Thanks.
Could not create this file.Shall I try again?
Click Start
Click Run
Type CMD and press ENTER.
Enter CD \ and press ENTER.
Enter CD "program files" and press ENTER.
Do you get an error-message?
If not, that's good. If so, what's the error-message?
Enter CD "PrintMaster 2.0 Gold" and press ENTER.
Enter CD "Components" and press ENTER.
Enter CD "Clip Art" and press ENTER.
Enter CD "Travel" and press ENTER.
Enter CD "Europe" and press ENTER.
Enter ECHO Y > "Rusty Fence.jpg" and press ENTER.
2answers
The file cannot be opened. EITHER IT IS NOT SIGNED WITH A TRUSTED CERTIFICATE OR ONE OF ITS COMPONENTS CANNOT BE FOUND. IF THE PROBLEM PERSISTS, TRY REINSTALLING OR RESTORING THIS
Check the file extension.
This occurs when you don't have a program which can support the type of file trying to open.
Try opening with some program or chage the extension of file if it is not proper or install appropriate software supporting the filetype.
I can't get into my folders, applications, etc.
The error message you are getting is a result of a trojan virus that embedds itself in WININET.DLL.
Two simplest solutions:
1. If there is nothing important on the laptop that isn't already backed up, use your Dell install disks to re-install the computer.
2. If you have important files on the drive which are NOT backed up. Take it to a pro, or buy a 2.5" Hard drive enclosure, put your drive in the caddy and connect it to another computer that has an up to date virus scanner. Scan the drive for viruses and allow the virus scanner to clean all virus' it finds.
When that's done copy the files you need to the other computer and then Restore the laptop as per step 1. When it's up and running again, install a good virus scanner, then copy the files back to it from the other PC.
Hope this helps,
Chris
2helpful
2answers
Gtalk Error 1
that's a problem with software...
try downloading google talk again and install it... even then if you are getting the same problem... its a problem in the Operating system... some file must have corrupted... so re-install OS and install gtalk...
or simple way.. juz login to your gmail id... u have an internal gtalk available... in inbox itself.. hahaha..
Sep 17, 2008 • Google Talk
2answers
Error messages,
Go to Control Panel, Administrative Tools, Services and make sure that Windows Installer service is set to manual or auto and click Start to start the service.
Error message during installation of motorola 4.0 phone tools
your DLL - direct library link file seem to be corrupt....you may need to install over the pervious version.
Epson V350 Install Error
what is the exact error message and extension error?
Top Citrix Computers & Internet Experts
xxxxxx xxx
john h
Are you a Citrix Computer and Internet Expert? Answer questions, earn points and help others
