What type of cable do I get to extend a dongle from pc into a corridor so that it picks up the signal from the router?
  • lamajciredor May 13, 2010
    do you use a wireless network?
  • 374 Answers
Hi there, you must use UTP cable ; 2meters, 5Meters, 10Meters is available in all PC Sale and Service center. at both end of the cable there is RJ jack 45 degrees.this jack use to connect to your PC and routher.
Posted on May 14, 2010
Linksys wifi droping suddenly
What i would suggest is get another wifi receiver dongle if that one fails its probably your laptop needs repairing if you have a friend that has one you can borrow from or you can get them cheap on ebay i had the same problem with a laptop and i just plugged in a dongle i got on ebay and it worked it doesn't have to be a lynskys it can be any wifi dongle receiver if tht fails your router might be damaged your ISP provider may be able to help you determine the problem for free they can run tests with you over the phone too see if the signal is reaching the router or maybe you could try hard wiring the laptop to router with an ethernet cable see if that picks it up if tht does its either the router or dongle or you might have broken the wifi built into your laptop... Hope some of this helps..Sean
Jul 02, 2014 | Acer C7 Chromebook
Is there a slot on a hp pavilion where i can place a belkin wireless card? because my labtop is not picking up a signal
yes, you have 2 options, you can use a USB wireless dongle or use a wireless express card, check amazon.
You can pick up either for about £15
Sep 30, 2010 | HP Pavilion DV9700Z notebook PC
Have a new Acer Aspire 5517, when I move the computer more than 7-10' from the router the signal goes from Execellent to poor/lost connection. 5 other computers on this Verizon Fios network run great with...
Take both excuses out of the equation. Buy a wireless N dongle off ebay (you can pick them up dirt cheap).
Router would pick up dongle using it's own software (Acer's excuse) and would not know or care the make of notebook (verizon's excuse)
Sep 05, 2010 | Acer Aspire 5100-3825 Laptop Computer...
How to go wireless on laptop
You need three things
1) An Internet service provider. Once you sign up and agree to pay the fee they will provide the internet service.
2) A wireless router. This is a unit that receives your internet service by through a connection to your telephone line. Then it transmits a radio signal (wireless signal) that your laptop can receive.
3) A Wifi card in your laptop or an external USB Wifi Dongle. This is a radio or wireless receiver that picks up the signal from your router.
The router is usually security protected with a keycode. All you need to do is set up your Wifi card or dongle with the same keycode and you will be able to receive the internet wirelessly.
To check to see whether your laptop has a Wifi card already installed, do the following:
Click Start>Programs>Accessories>Communications>Network Connections> and look for "Wireless Network Connection." If you have this, then your computer has a Wifi card installed and ready to go.
Aug 27, 2010 | Computers & Internet
My router routes to my laptop within my house and
The possible cause is the router is not able to extend the signal to that range. Try using a range extender to boost your wireless signal. Signal strength depends on the router. So adding a range extender should solve this issue
Jan 16, 2010 | Linksys Wireless-G Broadband Router
I have a verizon westell 7500 gateway router. Will I be able to use a netgear WG111 2v wireless adapter to get a stronger signal from it for my laptop?
I'm not sure what you are trying to do. Is the signal too weak?
You could use the router to extend the range with the proper configuration. Either that, or purchase a wireless extender that does just that.
You won't get a stronger signal. A router does not boost a signal. It can pick up the signal and rebroadcast it using a different IP.
Jul 23, 2009 | Computers & Internet
No comunication between router and cable modem.
this is because your PC is picking up the WRTG54G which is an internal signal booster (internal gateway) to the ROUTER ITSELF.
WRTG54G is in the middle like an interpreter.
The WRTG54G is not connect to ROUTER>
thus the laptop is not connected, like sprinkler attached to the end of a hose but the HOSE not attached to the water faucet.
turn OFF laptop. RESET WRTG54G (there is a small hole you can stick a pencil in there and hold down for 15 long seconds; UNPLUG power.
PLUB back in and hit auto config button.
let WRT54G pick up a new IP ADDRESS from router. once that is done turn on laptop and it should pick up a new signal with new IP address assigned to it by the WRTG54G.
Apr 26, 2009 | 2wire HomePortal 1100 Router...
Can't connect with 2nd computer...
1st.  What brand and model # of your router? 2. The router cd should be run only on the computer u have connected to the router with a network cable. Your vista laptop. Is it connected with to the router with a cable? 3. If so, it will be the one used to configure your router for wireless setup. When you ran the setup it should have gone thru Wireless Setup. It will ask you for an SSID. That is a name you will give your wirless network. It can be anything you want. just remember it.  It will also ask you to setup security for your wireless network. follow the instructions to setup a password. write it down. This is an important step so anyone cannot just logon to your wireless signal an start using ur internet connection or gain access to your computers. 4. when u setup your dongle on your kids computer it will search for wireless signals in the area. you will look for the one u setup in the previeous step. you will select it and it should ask you for the passkey you setup. once connected you will have access to the internet.
Think of your router as a private radio station and the wireless usb dongle is the radio. The only way your computers can tune to it is using the dongle and if you know the name of the station (your SSID) and the passkey.
Mar 26, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Usb adapter
if the router is already set up the usb dongle software will need to be used to connect to the router to allow a connection without the need for a cable as the dongle will see the wireless signal
Aug 31, 2008 | D-Link ADSL2/2+ Modem/Wireless Router...
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
