Question about Measuring Tools & Sensors
HAVE A ACR 2000 THAT WONT TURN ON,CHECKED POWER AT
Have A acr 2000 that wont turn onchecked power at breakers and switch have 120 volts
    President:
  • 180 Answers
You can try the following: 1# Check the main power cable & make sure it has 110V (Do not run the machine with long extension cable).2# Check all harness connection.3# Check keyboard cable connection on back of control board.4# If all the cable connection is good then you may need to replace the control board.
Hope this will help you to solve the problem.
Posted on May 13, 2010
Domestic duo therm gets 20volts everywhere I checked. I have yet to check the switch on top of the compressor. Neither fan nor compressor turn on or make noise. Get 120 at breakers.
If you don't have 120 volts at the power connections at the unit, you have an open fuse or wire someplace between the breaker and the unit.
Jun 24, 2014 | Heating & Cooling
Why wont my Splendide washer/dryer wont turn on?
check outlet for power if ok bad switch or transformer make sure on 120 volts
Jun 13, 2014 | Splendide Washing Machines
Ruud troubleshooting
do you have the lower door in place tight ?? because there is a door button switch. so if its not pushed in all the way you would have no power at furnace. also make sure nobody turned off the on off service switch usually above furnace or sometimes one at top of stairs and one down by the furnace .if those suggestions don't work you might want to turn each breaker off then back on incase one is tripped. if that don't work check for 120 volt at your fan timer board also it may have a automotive style fuse on the board which if blown it wont do anything. if there is 120 volt at board and the 24 volt circuit fuse is good its probably the fan timer board.
Jan 17, 2014 | Water Heaters
Subs go in and out all other speakers work and kicker amp still has green light on
unplug ur acr wires if it stops plug the red one in an wait to see if it does it , if not then un plug it an plug the white one in an wait , if one of the in put on the amp is gone then it will let u know what one ,say the white acr wire made the noise when u pluged it in ,unplug it from the white acr input an put it in the red acr input if it stopped makeing nosie then its ur acr input on the amp . but if not then it could be in ur acr wires or cd deck , if u know its not the deck or its new then make shore ur ground is good an the power wire is almost the same size wires because the amp will draw more power if power wire is bigger then ground an if grounds bigger then the power its not goin to get enuff power , i hope this was helpful an please votes for me
Jul 11, 2011 | Kicker KX250.2 2 Channel Car Amplifier...
DEWALT DG6300B NO POWER OUTPUT
Hello avid.....
If there is no power to the receptacles:
1. Turn the circuit breaker switches off and disconnect all electrical loads from the generator.
2. Turn the circuit breakers on and test the GFCI's by following the procedures in this manual
on page 1 -
TO TEST A GFCI:
Start the generator. Turn the auto idle switch off. Push in the TEST button (A) on the receptacle.
The RESET button (B) will pop out. Power is now off at the receptacle.
If the RESET button does not pop out, the GFCI is not working. Do not run
generator until the problem can be corrected. To restore power to receptacle,
push the RESET button in. If the RESET button pops out during operation,
stop the generator and check the generator and equipment for defects.
3. Place the voltage selector to the 120 Volt only positions (unless you are using a tool that
requires 240 Volts).
4. Turn the idle control switch off.
5. Turn the circuit breaker(s) off and reconnect the electrical loads. Be sure that the plugs are
securely connected to the receptacles.
6. Turn the circuit breaker(s) on.
7. If there is still no power at the receptacles, take the generator to an authorized DEWALT
service center. To locate a DEWALT service center nearest to you, call 1-800-4-DEWALT
Joe
Thanks for choosing Fixya!
Nov 27, 2010 | Garden
Will not shut off will not heat
check for 240 volts if its electrically heated,if you lose one leg of power or 120 volts on the timer side it wont turn the timer to shut off and only 120 volts wont operate the 240 volt heating element
Nov 16, 2010 | Kenmore 62602 Electric Dryer
HAVE A ACR 2000 THAT WONT TURN ON,CHECKED POWER AT BREAKERS AND SWITCH HAVE 120 VOLTS
Please try the following: 1# Turn on the main power switch(ON/OFF) & press 15amp & 3amp circuit breaker at the same time to re-set the breaker.2#With line voltage is present at ''Main'' 15amp circuit breaker,Check connection between circuit breaker & power switch(ON/OFF).3# Verify line viltage is present at the power supply input connectior 44,(Brown=hot,Buue=neutral).4# Check connection between power switch & 15amp circuit breaker.Hope this will help you.
Mar 17, 2010 | Measuring Tools & Sensors
Fuse labeled ACR & Power assist trunk '90 Firebird
I had the same thing happen...the clamp bearings were shattered in the bottom receiver.
Nov 06, 2009 | 1990 Pontiac Firebird
Dryer has no power
do you have 240 volts to the dryer, if you lose 120 volts on one side it wont heat fully
Sep 30, 2009 | Dryers
I have a briggs and strattan 18 horsepower engine on my craftsman mower and it wont start, i replaced the starter and it still wont start! It wont even turn over, in fact it binds the starter, but if I...
Have the battery tested at an auto parts store to ensure there is enough power in it. Sounds like it's strong enough to turn the motor with no compression (spark plug removed) but too weak to turn the motor with compression. Also check for loose or corroded wires.
Sep 20, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Measuring Tools & Sensors Logo
302 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
