Question about APC Silcon UPS System
Power failure I'am PAUL,I work at HILTON QUEBEC ,on last power failure my boss realise that we had a fration of a second delaid before the contactor reacted,he think that the contactor coil is no plug properly.the coil is energised from an emergecy panel.he sugested that I energysed the cotacter coil from the emergency panel located after the contacter.I sugested that we supply power to the coil from a regular non emergency panel.can you help me by sending a wiring diagram of a typical connection for a APC SILCON MODEL:SL10KB1    SERIAL:EE0136000220 with   SBP10KF1M1 tanks a lot. PAUL
  • Anonymous May 16, 2008
    the contacter on my coleman ac does not work automaticly only when i manually push it in
    Problem Solver:
  • 5 Answers
Dear,
Tell me your problem in short words then i can resolve your problem...
[email protected]
Regards
Posted on May 14, 2009
SOURCE:
Find manual for hugo boss watch HB25.1.14.2037
hello paul :
try with this document : http://i.nordstromimage.com/images/default/shop/image/misc/watch-manuals/hugo-boss/hugo-boss.pdf
Jan 04, 2015 | Hugo Boss Watches
Indoor unit powers up indoor fan runs, has call for cooling outdoor unit will not run, has coms issue
Good. When it calls for cooling the wire conncets to a contactor in the outdoor.
Unscres the center of contactor and then check the contactor by pressing thr' ur screw driver maually. Just only for 5 seconds.
If it works, the contactor coil is defective.replace contactor
Feb 03, 2014 | Midea Heating & Cooling
I have the Mr Steam MS Super 1 T steam unit with the Tempo Plus accessories and auto flush. The unit has worked great for about 2 years but for some reason yesterday the unit light comes on at the...
You would need a multi-meter or voltmeter to trace the power path. Turn on the generator and wait until you hear the water feed solenoid stop. This means the water has reached the satisfied level and the pc board should have sent 24v to engage the contactor. On the actual pc board there is a section label "cont" which is what sends the 24v to the contactor the engage the heating element. Verify that you have 24v on the spade terminals going out to the contactor, if not then you may have a pc board issue. Second possibility is the contactor, if it is recieving 24v and it is not engaging then it's simply a bad contactor. Check the load side of the contactors with the blue wires. Lastly if these two steps check ok, then perform an ohm reading with a multimeter on the actual heating element(with the power off, put your two test leads on the two flathead screws that hold down the blue leads the go to the heating element). If you get an open reading then this may indicate a failed heating element. Pulling the heating element out on the left side panel will confirm any element failure.
Nov 08, 2012 | Mr Steam Ms Super 1e Steam Shower...
I have a Boss GT -10 and its great. When I plug in my Gibson les paul into it and play it, there is sound. When I plug in my Other les paul with emgs in it, no sound comes out. I plugged them both into...
The half-way cord is the clue. Read up on unbalanced and balanced lines and TRS connectors.
One of these requires TRS connections and the signal is being carried on the RING of the TIP-RING-SLEEVE connector. Plugging in half-way the TIP touches the ring pickup contact. The emgs one MAY use TRS type cables and there may be a reason the signal and hot of these are reversed. If I could find schematics on all this equipment I could unravel the exact cause. You could make an adapter with a Stereo 1/4 inch plug and a 1/4 inch jack by wiring it to swap the tip and ring between them to use for connecting to the emgs guitar. ALSO verify you are using the SAME type guitar cable for both.OFTEN a TRS cable will NOT turn on the electronics when plugged into a guitar. Use an unbalanced instrument cable unless you have the XLR type output. Use of an adapter from the XLR type cable into the Boss will usually not work.
Apr 24, 2011 | Roland Boss Gt-10 Guitar Effects Processor...
I have an Intertherm S3BA-048KA Split AC system which has stopped blowing cold air. Indoor blower is working fine. Outdoor fan is not working. I have reset breakers (indoor/outdoor) without success. I...
First thing I would look at is to make sure you have power at the disconnect 110 coming
in on each leg to unit. Second, I would look at the capacitor for obvious bulging or leaking
Third I would check to see if the contactor has burnt points or bugs in it. Your disconnect
may have fuses in it which may have failed as well .
(All checks of the unit with power off to all breakers as there will be more than one
double breaker supplying power to the unit).
The hum you hear indicates that the contactor is pulled in on the outside unit but still may
be burnt or have ants or earwigs especially in between the contacts
. The capacitor can hold a charge even after equipment is off so discharge it to the chassis
before removal. Replace only with same Microfarad rating and equal voltage or higher
Remember to mark the wires as to which came off the HERM / C/ FAN terminals or take a
cell phone picture.
I have just replaced my intertherm condensing unit after it had it's 3rd compressor failure.
It was more cost effective than buying a compressor and hoping all the other components
were going to last.
Feb 26, 2011 | Heating & Cooling
Hello Gents, BM 450 situation: filled all ingredients inside, selected programme, pushed start/stop button - working. Butafter 15 min i realised that i choosed the wrong programme and i wanted to stop the...
By unplugging your machine you probably engaged the power failure safety device. You need to clear your programs by pushing the "stop" button until it beeps or the readout changes, (this usually only takes about 5-8 seconds. Then push program, choose the program you originally wanted and push "start". Please let m know if this works for you.
Nov 26, 2010 | Kitchen Appliances - Others
Power to condenser contact engages nothing happens no sound nothing coming out no power out of it and i tried 3 different contactors and capasitor thanks
Do you have power going into the contactor? When you read the voltage, read it accross the 2 power in wires, if you are not reading 220 volt, nothing will happen, and means that you have one dead power leg,,,,, bad fuse, breaker???
If this helps, please rate the new guy :)
Thanks,
Paul
If I can help you more, just contact me with more information.
Apr 04, 2010 | Heating & Cooling
Garmin NUVI 300. Unit keeps powering off. Battery life seems to have shortened. Satnav approx 18 months old.
help please
i cant get into my second hand garman 300 sat nav to to a unknown pin number ,ive brought it second hand at a car boot market and didnt realise that it was blocked until i got it home and charged it up
can you please advice me on how to get it unblocked or wot i can do
paul
May 04, 2008 | Garmin GPS
Channels Not Playing
i had afriend who is atechnician. his boss amplifier stopped working on one channel,so what he did is openened the amp,tested the mosfet transistors and it showed signs of failure.then he went shopping for same type of mosfet transistors and with no luck in buying the right type, he put the amp away for acouple of weeks. then one day he hooked it up and strangely it worked again. he told me that while it was hooked up itwent into protection mode and for some reason it worked later. so i would not open it because of static discharge i would disconnect the amp for maybe acouple of weeks then hook it back up.... its worth a try & good luck
Nov 10, 2006 | Boss C350 Car Audio Amplifier
APC Silcon UPS System Logo
102 people viewed this question
Top APC Computers & Internet Experts
Shawn DuRee
Alun Cox
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
