Simple drive 160gb external USB drive made by simple tech is not working when plugged into my computer. Do not know how to set up
  • 2 more comments
  • Clifford Hardy
    Clifford Hardy May 11, 2010
    are running windows xp
  • david872 May 11, 2010
    What OS is your computer? If it's an older version of windows you may have to manually install drivers for the hd.
  • Clifford Hardy
    is the power for the drive pluged in
  • Joash Boyton
    Joash Boyton May 11, 2010
    What is not working, is there any indication on either device that they recognize each other? Light etc: Does the drive appear under my Computer?
  • 68 Answers
Hay Amigo !
No problem just download and install this utility. Also check your connecting usb lead.
Thaks and don't forget me to vote ok.
Here is the link
http://files.extremeoverclocking.com/file.php?f=197
Posted on Mar 29, 2008
How to solve simple tech 160GB EXTERNAL USB HARD DRIVE
I was having a problem on Windows 7 with the SimpleTech 160GB drive not being recognized, went to the SimpleTech site and could not find any drivers - Went to MajorGeeks and found a driver update program - watch when you install it, do custom install so as not to get new homepage or toolbar. But it scanned and found where my drivers were deficient. Updated driver and drive is now recognized
Jul 14, 2014 | SimpleTech SimpleDrive 160 GB External USB...
What cable do i need for my simple tech 160gb hard drive. I lost mine.
You will want to purchase a USB Mini B to USB A such at this listed below
Link
Feb 03, 2012 | SimpleTech SimpleDrive 160 GB External USB...
I own 2 160gb external Pininfarina drives and this one always gives me a pop up window in the task bar saying that the device would work better if plugged into a 2.0 usb port. Every computer I own has a...
Try to reformat the driver using your computer to resolve the problem...after reformatting it...try re-plug it again to the usb port. If the notification still exist...that will be version incompatibility...you need to update the usb port driver...
Go to the website of the motherboard name and download the new updated version of the usb driver...If your motherboard is msi...go to msi website...something like that
Sep 21, 2011 | SimpleTech Signature Mini 160GB External...
Hello , Are there drivers for Vista available for the Simple drive 160gb external drive Model number 900000-40479002 FV-U35/160
Once plugged into your computer, Automatic Update should find the drivers automatically and install them for you.
May 02, 2011 | SimpleTech SimpleDrive 160 GB External USB...
I just recently bout a 250gb simple tech external drive. I came home installed but it wont show in my computer
You might try a different cable or use a USB "Y" cable to supply enough powere for the drive to work, as some computers have difficulty providing enough power from a single port. If you need more help, please call HitachiGST Tech Support M-F 8AM to 6PM PST at 1.888.426.5214 and a technician will be happy to help you.
Feb 02, 2011 | SimpleTech Signature Mini 160GB External...
I have a mini simple tech 160gb hard drive that when I plug it in an error message about power surge on the USB port. What can I do to get the data off of the drive
Probably not the right answer for your problem. Mine is an external 1 TB Simple Drive. Mine wouldn't respond at all. I unplugged the power cable from the back of the hard drive and replugged it in and instantly it worked (with the computer and hard drive plugged in). I had tried rebooting the computer, plugging/unplugging over and over into the computer and that didn't work.
Jun 17, 2010 | SimpleTech Signature Mini 160GB External...
Simple Tech external memory 1.0 tb not registering all the sudden
First of all make sure that the USB port that you are using to connect it to your PC is a USB 2.0 port, and not USB 1.0.
Also if it came with an external power, connect it to the external power before putting on your PC.
This is because the voltage supplied by USB 1.0 is lower than that of USB 2.0 and therefore might not be enough to power up your USB Drive.
After making sure about this, power up your system, and plug the external drive, then Right-Click on my computer icon, select manage, then go to Disk Management Option.
On the Disk management option Page you should see ALL the drives installed on your system, including the hidden ones, so what you will just do is, try and locate the one representing your external drive, and right click on it. then select "Change Drive letter and Paths".
Give the drive any new, unique letter (i.e alphabet) different from the ones already on your system, and click on OK.
This should make your external Drive to be detected automatically.
Hope this helps you out.
Nov 21, 2009 | SimpleTech 160GB USB 2.0 / FireWire...
Simpletech 160mg pinifarina wont work
sounds like a corrupt driver. Go to device manager, and see if the USB tree has a yellow exclamation, if yes, uninstall USB driver and reboot.
Jul 25, 2009 | SimpleTech SimpleDrive 160 GB External USB...
External HD not recognizing USB ports as being Hi-speed ports
I have the same issue. I have 4 Simpletech Signature 250GB drives. They all worked fine at first. After about six months two of them started connecting at USB 1 speeds. It occurs on 4 different computers!!! The post about it being the computer assumes is wrong. How can it work fine for six months and then suddenly change. Also it occurs on different computers. I have submitted a tech support request with simpletech and will post the results.
Jun 14, 2009 | SimpleTech Signature Mini 160GB External...
Problems
One thing to remember is the some of the Simple drives requires the USB mini to conect to the drive and the TWO USB connects to be plugin to the computer.
Jan 15, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Computers & Internet Logo
David Payne
David Payne
