Question about Palm Z22 Handheld
My palm z22 won't allow me to pass the calibration screen (clicking the bullseye target) I've tried removing debris from the edges removing and putting back on the screen protector and turning it on and off
2 Suggested Answers
KingDWS
  • 1606 Answers
SOURCE: My palm z22 won't allow me to pass the calibration
take the protector off and do a reset. Also make sure you don;t have any crud around the 5 way that is tyring to move things. The protector can be slighlty too big and cause this. It may look like it fits perfectly but causes this.
Posted on Mar 23, 2010
How do I reset my palm z22 to factory settings?
If you've set a password on your handheld, any hard reset will automatically become a Factory Reset. With this method, you'll enter a password and then perform a hard reset.
  1. On your handheld, launch the Prefs application. Under General, select Security.
  2. If the Password box says "Unassigned," tap the box and create a password for your handheld.
  3. Once the password has been set, remove the stylus. Disconnect your handheld from the AC charger, if connected.
  4. On your handheld, hold down the Power button.
  5. While holding down the Power button, use the stylus to press the RESET button on the back of your handheld.
  6. While still holding Power button, the screen will show the Palm logo and a progress bar. Then the circular Palm Powered logo will appear. Release the power button when you see the Palm Powered logo.
    887_palmlogo_progressbar.gif spacer.gif 887_poweredcircle.gif Keep holding the Power button during this screen. spacer.gif When you see this screen, you can release the Power button.
  7. A message will appear warning that you are about to erase all the data stored on your smartphone. Press UP.
  8. You'll see a series of Palm logo screens, then a prompt to tap onscreen targets. The Factory Reset is complete.
Apr 15, 2010 | Palm Z22 Handheld
My palm z22 won't allow me to pass the calibration screen (clicking the bullseye target) I've tried removing debris from the edges, removing and putting back on the screen protector and turning it on and...
Mar 17, 2010 | Palm Z22 Handheld
Touch screen would not respond
HI,
Here is a link to get you to the Palm support page. You can do a phone call to the but it will cost you $25. There is also a chat feature and that looks like it is free so hopefully that will help.
Best wishes.
http://kb.palm.com/wps/portal/kb/na/zire/z22/unlocked/supportservices/page_en.html
Aug 16, 2009 | Palm Z22 Handheld
My Z22 touchscreen does not respond to the stylus
This shows the OS is corrupted. Try to flash the device
Jul 25, 2009 | Palm Z22 Handheld
Tungsten e2 is always looping on the stylus calibration screen
actually ur Digitizer is faulty u can replace it urself cost around 25 $ or so do u want to proceed let me know , unless u change the touch panel digitizer u will be stuck at align screen thing
let me know if i can help more
RATE ME WELL !
Jun 02, 2009 | Palm Tungsten E2 (Multilingual) Handheld
I did a hard reset on a Palm Z22, can't get past targeting
Bad news....its dead. Same thing happened to me. Had to get a new one.
Mar 17, 2009 | Palm Z22 Handheld
PALM Z22
Your problem might be a simple one. Hopefully so:
Run a business card around the edges of the screen between the screen and the plastic housing to see if there is any trapped dirt or other debri. If there is, it will hold down that point of the screen and prevent any further input. Be sure to remove anything you find.
Also, sometimes the screen protectors themselves will shift just enough to cause the same issue. Be sure it is not wedged tightly between the screen and case.
I hope this is it and helps!
Aug 29, 2008 | Palm Z22 Handheld
Palm z22 touch screen screwed up
clean the touch screen and go under the edges w/ a bankcard to remove any dirt.
then do a hard reset -- worked for my z22
c boekema
Jan 14, 2008 | Palm Z22 Handheld
Screen problem
Sometimes 3rd party apps that don't work so well with the palms can freeze them up.
http://kb.palm.com/SRVS/CGI-BIN/WEBCGI.EXE/,/
?St=2,E=0000000000825403011,K=4996,Sxi=18,Case=Obj(26419)
You could do a hard reset and when you initially sync the palm, when it asks you for a profile choose a new one and see if this method removes your problem.
Diagnosing problems by 3rd parties link- http://kb.palm.com/SRVS/CGI-BIN/WEBCGI.EXE?
New,Kb=PalmSupportKB,ts=Palm_External2001,Case=obj(27908)
More info-
Does the calibrator keep looping or not seem to work?
If you can access the calibrator, but it loops through the target sequence (repeatedly asking you to tap the targets), there may be a physical problem that's causing your touchscreen to be confused:
  • Do you use an adhesive screen protector? A screen protector which is trapped under the screen edge may interfere with touchscreen calibration. Occasionally, just having the screen protector on the screen can cause the issue. Try removing the screen protector.
  • You may have debris trapped under the edge of the screen. Use the corner of a piece of thin, stiff paper (copier paper works well) to very gently slide all around the edge of the screen. Don't let the corner of the paper travel more than an eighth of an inch under the screen edge frame. By doing this, you may be able to dislodge small particles of debris trapped under the frame.
  • A heavy impact or scrape to the touchscreen can cause permanent damage. If your touchscreen is damaged, you may need a repair
Jan 08, 2008 | HP iPAQ RX3715 Pocket PC
Can't get past the calibration page, keeps shutting off
Did you install any 3rd party apps?
Diagnosing problems by 3rd parties- http://kb.palm.com/SRVS/CGI-BIN/WEBCGI.EXE?
Aug 31, 2007 | HP iPAQ RX3715 Pocket PC
Palm Z22 Handheld Logo
51 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
