Question about Sony KDF-E55A20 55 in. LCD Television
KDF-E55A20 where is the thermo fuse and,where can it be purchased
    Champion:
  • 208 Answers
As I responded last night the replacement of a thermal fuse is a very difficult task. The component is mounted on the lamp cage and require a great deal of disassembly. If you pull the back and the pull the center brace you will see a harness of wires. From the lamp cage you can follow either two black wires or a black and gray wire to where it has a coupling plug in said harness. Suggest a qualifier servicer to perform this task. The part can be purchase from Andrews Electronic.
Posted on Mar 30, 2008
Sony KDF-E55A20 55" 3LCD TV Purchased
Hi This is most likely the inverter panel that drive the CCFL's (Backlight tubes) or the backlight tubes themselves, I'm afraid I can't help with the diagnostic test or service menu.
hope this helps
Midge.
Feb 10, 2011 | Sony KDF-E55A20 55 in. LCD Television
My Sony Grand Wega KDF-E55A20 will not turn on with the remote or manually. The red light flashes 6 times then off.
6 times is the lamp thermal fuse or lamp. its a thermal that sits on the bottom of the lamp area.
remove the fan and you will see the siler disk with black base cut the wires and slide the new one in on the side secure it on the old thermal and your fixed.
Nov 04, 2010 | Sony KDF-E55A20 55 in. LCD Television
Need instruction for KDF-E55A20 lamp replacement
Click Sony Support to download user manual of KDF-E55A20 that has lamp replacement procedure in details.
Sep 24, 2010 | Sony KDF-E55A20 55 in. LCD Television
The sony model KDF-E55A20 has no sound or picture. The power led flashes red six times consecutively after being turned on.
Your thermal fuse has popped and needs replaced. This TV has a service bulletin regarding this issue. You should contact Sony for the replacement part/kit.
Mar 14, 2010 | Sony KDF-E55A20 55 in. LCD Television
Need to reset lamp hours for KDF-E55A20
This model does not require lamp timer reset, put new lamp securely and power up TV for picture.
Jun 06, 2009 | Sony KDF-E55A20 55 in. LCD Television
Sony kdf e55a20 picture goes black sound stays on
Thanks for updates.
Its time to replace Lamp. Please buy original Sony Lamp for Sony TV and avoid aftermarket or compatible parts for good performance of TV.
You can purchase original Lamp form Sony Accessories Store. Just type TV model in search box and see details by click search.
Good Luck
Jan 17, 2009 | Sony KDF-E55A20 55 in. LCD Television
Were is the thermal fuse on a sony KDF E55A20
The CORRECT way to replace the thermal fuse is to pull the optical block out so you can get to the thermal fuse mounting plate. I would NOT suggest just letting it "float out in the open cool air" as some have suggested as this is a safety part and not installing properly could be a safety hazard
Sep 19, 2008 | Sony KDF-E55A20 55 in. LCD Television
KDF-E55A20 55inch lcd tv
There are two senerios to this. It is not possible to tell which one is the true one without investigating in to the set and doing some checks for the cause.
There may be a cold solder connection on one of the boards. When disturbing the TV set from any kind of vibration you made it temporarily make contact.
The other thing that can happen is that there is a part that became thermo sensitive. When turning off the set it cooled down a little and then was able to work until it warmed up again.
The set would have to be properly troubleshooted to locate the exact fault, and then service it. You should take the set in for repair.
Jerry G.
Apr 17, 2008 | Sony KDF-E55A20 55 in. LCD Television
SONY KDF-E55A20
No it sounds like the thermal fuse.
Apr 14, 2008 | Sony KDF-E55A20 55 in. LCD Television
Sony KDF-E55A20 55 in. LCD Television Logo
255 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
