Fisher and Paykel Smart Drive 608 wont spin
My fisher & paykel smartdrive MW608AU wont spin, it gets to the end of the rinse and becomes very slow for around 25 minutes then eventually just stars beeping.... The error or diagnostic code is 00101000 Any suggestions or should i just get a new one.All otehr cycles work fine.I am not sure about where the filter is and also the best way to clean out the drain pipe , though it appears to be draining most of the water but not all.
Thanks for your help.
  • Anonymous Apr 01, 2008
    I am having the same problem, did anyone try the solution mentoned here?
Smartdrive 608 very slow to fill up. Have removed hose, not blocked put back on still got problem
Posted on Jul 30, 2010
    Sergeant:
  • 351 Answers
Remove the pump from underneath front right move whith clip forward the twist pump out.but you will need to remove all the water first you may a ball of lint stuck in the pump.hope this helps.
Posted on Mar 29, 2008
Fisher paykel washing machine fuse smartdrive
All Fisher & Paykel top load washers have 4Amp fuse for 240vac.
Apr 05, 2014 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paaykel Smart Drive 708 not working once filled with water.
You need to check your lid switch & out of balance switch for
corrosion and replace if faulty.
Your out of balance switch is under the big yellow motor controller
OOB switch Is where the grey plate is on this picture.
Mar 03, 2013 | Fisher and Paykel Washing Machines
Fisher & Paykel smartdrive 053 fills really slow
Your cold valve could be faulty & need replacing.
Try swapping hot & cold valves to see if it fills faster.
Jul 12, 2012 | Fisher and Paykel Washing Machines
My Fisher Paykel top load aqua smart washer won't
it wont spin if there is water remaining in it,check pump for restrictions or anything jamming it if good replace pump
Apr 27, 2012 | Fisher and Paykel Washing Machines
Fisher Paykel washing machine Smartdrive 703 Advance, Power and Start buttons are non responsive when pushed. Is there a part that can fix this. Does the control panel have to be replaced?
Fisher & Paykel Smart Drive beeps and stops during rinse cycle. If I hit pause and wait and restart it eventually continues. It seems like it has problems detecting water level.
Apr 13, 2011 | Fisher and Paykel GWL11 Top Load Washer
Fisher & Paykel Smart Drive 7.5 washing machine.
Unplug the machine have someone tilt the machine back and look under the machine for a little fan on a motor give it a turn to see if it spins it might just be sticky or it may need replacing.
Jan 07, 2010 | Fisher Paykel Eco IWL16
My fisher and paykel smartdrive 708 stops at rinse/spin cycle with machine still full of water
with no error code ... I would check you drain pump or drain hose... you first may want to try a shop vac connected to the end of a drain hose .. let me know if it helps
Dec 15, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
My fisher paykel eco smart is GWL11 not GWL15
00110001 CODE 49 COLD VALVE FAULTY
1 FILTER IN HOSE AT TAP END CLOGGED OR FILTER IN VAVE AT MACHINE END OF HOSE CHECK THESE FIRST .
2 SOLENOID OPEN CIRCUIT OR BECOMING OPEN CIRCUIT WHEN HOT.
3 CONTROLLER NOT SUPPLYING VOLTAGE TO SOLENOID.
TRY THINGS IN THIS ORDER AND GOOD LUCK
Jun 27, 2008 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel Smart Dribe 608
not familliar with that exact model number ( we dont have that over here in the US) we have simalair f&p gwl10- gwl11) that problem sounds as if either the pump is bad and overheating before pumping all the water or a diverter valve is not fully closing allowing water to remain in tub.
Mar 29, 2008 | Washing Machines
Washing Machines Logo
1,698 people viewed this question
Top Washing Machines Experts
