Question about Measuring Tools & Sensors
Looking for a blue point multimeter eedm509a manal it was sold by snap-on
Looking for a wiring diagram to fix an open in a wire going to my fuel evap valve at rear of truck. Engine code pointed me in that direction. I checked the valve manally and it is fine.
If you run a wire directly from the battery to the valve and it works, then you will know the valve is ok. That will mean you have a wiring problem or a power supply problem. I would imagine that the valve is operated via the ignition system somehow. You will need to trace the wire all the way to its supply. Sorry but I cant help with a diagram.
Sep 17, 2015 | Cars & Trucks
How do I get a manal fo a #9000102?
http://www.homedepot.com/catalog/pdfimages/58/58e31e3d-c24a-4669-945f-37d09afff509.pdf
Sep 28, 2014 | Kidde 9000102 Night Hawk Combination...
IAM LOOKING FOR OPERATING MANAL
Check in this links:
- usersmanualguide.com/sharp/microwave (select your right brand)
- manuals/device/microwave_oven
Hope this helps (remember to rate this answer).
Jun 16, 2011 | Microwave Ovens
Window on my side of my 1995 nissan maxima won't go up.
Possible that the power to the winder has snapped at the hinges of the door, open the side flap and check. If there is power but the motor does not respond then the motor must be checked, the circuit to trigger including the door switch must be checked using a multimeter for measuring the voltage at these points.
Apr 06, 2011 | 1995 Nissan Maxima
I have a 2002 Suzuki Swift 1.3 and I need the colour coding for the car stereo. This is how it looks like looking from the back of the connector. The top colour is the main colour and the bottom is the...
why post non usa cars to USA forum>????
hint, we dont have M13 here. (EPA ******* here)
then not telliny your county.
why"?
my guess is you think all cars same, all suzuki same world wide and all suzuki have 1 radio.
sorry that don't fly.
but most posts here are just like this, hopeless.
wild guess 1:
here is our last swift, sold USA.,(not a m13 for sure)
wires
MAin set; and speakers last.
wht/blk, = ign. on. power 12v
white = memory , hot all time to battery via fuse, station memory
black = ground
red-green = illumination
red-yell = park lamps on, lighting,.
and below is speaker.
this is year 2000 last car sold here,
Mar 13, 2017 | 2001 Suzuki Swift
I have 2 blue point air ratchets that dont seem to work
Blue Point® is kinda-sorta a Division of Snap-On® Tools, however being labeled "Blue Point", Snap-On only gives them a 90 day to one year warranty, so Snap-On will not help you there. Since you got them at an auction, they may be frozen up as you suggested. I would place both the ratchets in ATF (Transmission Fluid) for a week or so and then try the air line to them again. Transmission fluid does wonders. We used to use it to clean our hands at Dealerships in the Winter to keep our hands from cracking and bleeding. It will loosen up most everything. In fact that's what I currently use in ALL of my air tools as the "few drops of oil" they suggest, before use. If they don't start working after a long soak, then to be cost effective to you, I would find a Harbor Freight® or another such store and buy a new one for as low as $15.99.
I hope this helps you.
~00 Buck~
"Still living on the Right Side of Dirt.,.."
May 12, 2010 | Craftsman 3/8" Pro Air Ratchet Rapid...
English Instruction Manal for Tevion DBS2400 Steam Generator Iron
Hi. I am looking for an English Instruction Manual for Tevion DBS2400 Steam Generator Iron. Can anyone help please. Thanks very much Regards
Mar 21, 2010 | Irons
Measuring Tools & Sensors Logo
54 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
