Question about Samsung BD-P1200 Blu-Ray Disc Player
When hdmi cable is plugged in bluray player stops
I have a Samsung bluray player that when the hdmi cable is plugged into the back of the tv ( hitachi ) the player stops reading the disc ... or you can have it in the tv first and plug it to the bluray and get the same effect.
any idea why this is? i had to replace the hdmi cable because it broke from stretching it ... now it won't feed to the tv any signal.
  • 98 Answers
Since it was stretched check the ontacts on the acutal HDMI connector on the tv and the bd player a pin bent or touching another pin will cause a vast amount of issues
Posted on Oct 02, 2008
SOURCE:
When my blu ray player is on no matter what I do screen still says resolution mismatch, how do I fix it? Pushing play and stop does not help
Unplug HDMI cable. Connect Bluray to tv using composite video cable. You should then be able to access the bluray players menu to set the hdmi output to a setting that is compatible with your tv (see your TV manual for compatible resoloutions. Once set disconnect the composite video cable and reconnect the HDMI cable.
Aug 02, 2014 | Televison & Video
How can I connect a samsung bdf5900 to my hitachi rear projection tv
Your TV is probably older and has Component, Composite and DVI connectors. HDMI is a newer connector that integrates sound. If your RPTV does not have HDMI but DOES have DVI, you can get an HDMI to DVI adapter on eBay or a computer store pretty cheap. You will need another way to get the sound from the Blu-Ray player, either external speakers connected to the player, or stereo RCA cables from the player to the TV (there will be a set of RCA audio plugs with the TV's DVI port).
Apr 30, 2014 | Samsung BD-F5900 Smart 3D Blu-ray Disc...
Have lg 55ls5700 tv trying to connect samsung hw-f450
I suspect that the TV you have does not support the ARC function that the sound bar has. What you may have to do is use the Optical In from the sound bar to the TV and you should be good to go. You may have to change the TV's settings to use the Optical In though. So you should end up with the BluRay Player connected to the TV via an HDMI cable, the sound bar connected to the TV via the Optical In using a fiber optic cable. Hope this helps.
Mar 19, 2014 | LG 55ls5700 55 Edge Led Smart Tv 120hz...
I have a VR-6025Z 60"
unplug TV and Bluray power cords from wall socket, replug HDMI cable in both units, replug power cords back in, turn them On and check.
Let me know how it worked. it seems Bluray player set its display resolution bit higher that TV doesn't support.
Please connect Bluray in TV by usual AV cable (yellow-red-white) and go to BD player setup menu and reduce HDMI Out resolution like 1080p to 1080i, then check it in TV HDMI input.
May 14, 2017 | Westinghouse LVM-42w2 Television
How to tune in for blu ray dvd
You do not tune in your Bluray player but connect using an HDMI cable or Composite cable. If you have a HDMI cable connect the Bluray's HDMI out to the TV's HDMI in at the back and using the TV's remote switch the Input source to HDMI. You will see the image from the Bluray player in high definition.
If you don not have a HDMI cable connect the composite out of the Bluray player using the Yellow/Red/White cable to the TV's composite input ( same three color sockets ) and switch to AV input on the TV. Using this connection won't give you high definition image but will work OK.
Apr 23, 2011 | Sanyo DP32746 32 in. LCD Television
Player turns on ok,display shows menu that disc is playing but tv says there is no signal, not seeing home screen with net flixs or the other apps.player has been working great we used it 2 day earlier...
The "handshake" between the television and the blu ray player has been lost. This happens a lot when connecting with hdmi. Sometimes a hot swap will work to remedy this. That is turning off and unplugging both your television and bluray player while removing the hdmi cable from both for 30 seconds to one minute. Reconnect the bluray player to the hdmi cable and then to the television. Plug them both back in and turn the television on first then the bluray player. Your television may need a factory reset going into the service menu or the board the hdmi ports are located on might need to be replaced if all of the hdmi ports are not responding. You can connect with component if possible in the meantime.
Apr 14, 2011 | LG BD390 Blu-Ray Player
I cannot get a new samsung bluray disc player toconnect to my hit
HDMI is the current digital standard for interfaces, but component (Red, Blue, Green) still gives a good method for passing HD. The only thing you might be giving up is some control functions. Use a good quaility RGB cable if this is the route you choose.
Dec 29, 2009 | Hitachi UltraVision 42HDS52 42 in....
HDMI and or Receiver problem
While Bluray pluged into the TV change the resolution from AUTO to 720P then plug Bluray back to the receiver and see if it solve your problem.
Nov 27, 2009 | Hitachi 51F59 51" HDTV Projection...
I have a 51UWX20B TV. I want to get a Blu-Ray DVD
Yes there are a few options for you to make the link between your TV and the BluRay DVD player, first there are adapter cables made with HDMI plug on one end and DVI plug on the other end, remember that with this cable you will have to link the audio signal with another cable because DVI only passes video. Second if you cannot find the adapter cable in your area you also can use the component video(red,blue,green)instead of the other adapter cable,that is if your TV has component video ports, and again audio will have to be linked with another cable because component video only passes video signal. Good luck !
Nov 27, 2009 | Hitachi 53UWX10B 53" Rear Projection...
HDMI connection with Panasonic DMP-BD35K Blu-Ray Disc Player
Try hooking the Panasonic up straight to the tv without going through the receiver. If it displays a picture its obviously not the blu-ray player. May also be a problem with the HDMI cable itself. Hope this helps.
Jan 04, 2009 | Onkyo TX-SR506 Receiver
Samsung BD-P1200 Blu-Ray Disc Player Logo
118 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
