Question about Acer Aspire 6920 Notebook PC
On starting my laptop i keep getting the "Windows Recovery Error" screen with the option to select 1. Start windows repair (reccommended) 2 Start windows normally However selecting either of these results in it trying to load then restarting and returning to the same screen. I do not have the disc. However I do not have anything important on my laptop and just need to get it working again. If anyone knows how i can fix it that would be great. Thanks
  • 3 Answers
You need a Recovery Disk and will probably have to re-install windows again. If you don't have anything on it, fine. You will need the drivers which you can download from acer support
Posted on May 19, 2010
Have you gotten any help yet? Check to see if it's a bad driver (or incompatible driver). The prob you're having is common with a new driver that isn't compatible with your system.
Posted on May 17, 2010
I cannot get passed the Windows Error Recovery screen. If I select Launch Startup Repair nothing happens. If I select Start Windows Normally it goes to starting windows screen momentarily and returns to...
First try starting your computer in safe mode. Power down, then hit power button and tapping F8 will get you to this option window. You can also choose safe mode with networking. While in this mode check for any new updates. If you installed new software or hardware uninstall these. Try restarting computer. If this doesn't work and you have a recovery disk put it in while computer is on and then restart.
Apr 27, 2013 | Gateway NE56R10u Laptop
Error Oxc00000e9 when i turn on aspire 5741, no external devices plugged in.
try this below
First please refer to the following thread to see whether it helps.
http://forums.microsoft.com/TechNet/ShowPost.aspx?PostID=796452&SiteID=17
I know that you are unable to start the current vista operation system and getting the error 0xc00000e9; the issue can be caused by the damaged system files or hardware device. You might first follow the steps below to exclude the possibility of system corruption.
Method 1: Use the Windows Recovery Environment (WinRE) to run System Restore
1. Insert the Windows Vista installation disc into the disc drive, and then start the computer.
2. Press a key when the message indicating "Press any key to boot from CD or DVD ...". appears.
3. Select a language, a time and currency, and a keyboard or input method, and then click Next.
4. Click Repair your computer.
5. In the System Recovery Options dialog box, choose the drive of your Windows installation and click Next
6. At the System Recovery Options Dialog Box, click on System Restore.
7. Follow the System Restore Wizard instruction as usual and choose the appropriate restore point.
8. Click Finish to restore the system.
Method 2: Startup Repair from the Windows Recovery Environment (WinRE)
5. In the System Recovery Options dialog box, choose the drive of your Windows installation and click Next.
6. At the System Recovery Options Dialog Box, click on Repair your computer.
7. (Click the operating system that you want to repair), and then click Next.
8. In the System Recovery Options dialog box, click Startup Repair.
Feb 14, 2011 | Acer Aspire 5050-3371 Notebook
My asus f5rl keeps coming up with boot error 0xc000000f when turned on. How can i restore it please?
Before going any further, please help to confirm the following three points:
1. Does any other error message appear when starting the computer?
2. Did the computer start properly before?
3. Have any changes been made on the computer recently, such as an installation or upgrade?
The issue can be caused by many factors, such as incorrect BCD entries and incompatible hardware or software.
Based on the current situation, I suggest trying the following methods to troubleshoot the issue.
Method 1: Startup Repair from the Windows Recovery Environment (WinRE)
2. Press a key when the message indicating "Press any key to boot from CD or DVD ..." appears.
7. Click the operating system that you want to repair, and then click Next.
Can the computer be started now?
If the issue persists, I would like to confirm if System Restore was enabled before.
If so, we can try to restore the system to a state when your computer worked properly in WinRE.
Method 2: Use the Windows Recovery Environment (WinRE) to run System Restore
1. Instert the Windows Vista installation disc into the disc drive, and then start the computer.
Jan 16, 2011 | ASUS Computers & Internet
A disk read error occurred Press Ctrl+Alt+Del to restart
Step 1: Shut down your PC completely.
Step 2: Turn on the Power button.
Step 3: As soon as you turn it on start hitting the F8 key on your keyboard until you get to a black screen called "Windows Advanced option". (If you don't get to that screen but you end up reaching the Blue/Black screen than that means you have delayed in hitting the F8 key. start again from step 1.)
Step 4: As soon as you reach "Windows Advanced option" use your down arrow keys to choose an option called "Last know good configuration".
Step 5: Select that and HIT ENTER
if this fails then try repairing it from recovery console.
  • Insert the OS CD and boot from CD.
  • During Startup, select Recovery Console from the startup options menu.
  • When you are prompted, type the Administrator password.
  • Type the Command chkdsk /r
Dec 07, 2010 | Acer Aspire 6920 Notebook PC
When i switch on my Asus G1 it comes up with windows error recovery amd gives me two options : 1) Launch start up repair (recommended) 2) start windows normaly when i press enter on question 1 it just...
TRY TO REPAIR THE SYSTEN BY ITSELF, IF IT IS VISTA IT WILL PROGRAM BY ITSELF, JUST FOLLOW THE INSTRUCTIONS, SEEMS TO BE WIN 32 FILE SYSTEM IS DAMAGED, OR RUN YOUR OPERATING SYSTEM DISK AND SELECT TO REPAIR YOUR SYSTEM
Oct 16, 2009 | ASUS G1 Notebook
Laptop won't starup (Black screen displayed) Help me please!!
Try this.
Turn the computer on and immediately press and hold the F8 key.
On the Advanced Boot Options menu, choose Repair Your Computer.
When you reach the System Recovery Options menu, choose Startup Repair. You already did that, but try it again.
If that doesn't do the work, go back to the System Recovery Options menu and do a System Restore.
You can use the Bootrec.exe tool in the Windows Recovery Environment (Windows RE) to troubleshoot and repair the following items in Windows Vista or Windows 7:
  • A master boot record (MBR)
  • A boot sector
  • A Boot Configuration Data (BCD) store
Note When you are troubleshooting startup issues by using the Windows RE, you should first try the Startup Repair option in the System Recovery Options dialog box. If the Startup Repair option does not resolve the issue, or if you must troubleshoot more steps manually, use the Bootrec.exe tool.
To run the Bootrec.exe tool, you must start Windows RE. To do this, follow these steps:
  • Put the Windows installation disc in the disc drive, and then start the computer.
  • Press a key when you are prompted.
  • Select a language, a time, a currency, a keyboard or an input method, and then click Next.
  • Click Repair your computer.
  • Click the operating system that you want to repair, and then click Next.
  • In the System Recovery Options dialog box, click Command Prompt.
  • Type Bootrec.exe, and then press ENTER.
Note To start the computer from the Windows DVD, the computer must be configured to start from the DVD drive. For more information about how to configure the computer to start from the DVD drive, see the documentation that is included with the computer or contact the computer manufacturer.
Thank you Sir, Have a nice day.
Sep 20, 2009 | Toshiba Satellite Pro L300 Notebook
Windows error recovery
Hello!!
enter the repair the console by inserting the Xp cd.. and try the command FIXBOOT .. and then restart!!:)
Cheers!!
May 31, 2009 | ASUS G1 Notebook
Black screen on laptop, will not boot in safe or normal. no back up disk, tried f11 sys recov did not work
2. Press a key when the message indicating "Press any key to boot from CD or DVD …". appears.
May 15, 2009 | Compaq Armada E500 Notebook
Windows failed to start !...
if you had the recovery disk it would not clear the c drive it would just set it back to when you got it but the programs would still be there this computer i a,m on know had trhe same thing done to it and i was able to recover it without losing any info if you can get into bios and set it back to defaut or fail safe options you may be able to get going from there
Feb 17, 2009 | Acer Aspire 5920-6727 Notebook
Acer Aspire 6920 Notebook PC Logo
46 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
