Question about Canon PowerShot A560 Digital Camera
Lens error not opening - Canon PowerShot A560 Digital Camera
    Sergeant:
  • 420 Answers
Problem: dust in the gaps near lens which makes it jammed. Effect: the sceen shows blk color. Solution: just blow over it or vaccum it.
Posted on Sep 11, 2010
How do I fix lens error problem on the described camera?
hi,
lens error occur normally when it fell or the lens shaken, if so open the camera, take the lens unit out, disassemble the lens unit, then fix it again properly. example below:
(this is not the told model)
Dec 10, 2015 | Nikon Coolpix S3000 Digital Camera
My Coolpix camera lens won't open, says lens error, any ideas how to fix.
Hi Connie:
Lens stuck, is common defective that need new lens unit replacement or just repairable.
Causes of a Lens Error: There are a number of ways with which a lens error can be caused. Particulates might have managed to get into the mechanical bits that allow the lens to retract, a purely physical interference with the lens mechanism. If the camera was dropped, especially while the lens was extended, there's a pretty good chance something might have been knocked loose, such as the guide pins upon which the lens withdraws and retracts.
How to Repair a Lens Error: As scary as a lens error might seem, there are some easy fixes. Before trying any of them out, however, first take a good long look at your camera warranty and maybe have a chat with the company. If the lens error will be covered under the terms of the warranty, go for it. Even some of the simple fixes mentioned below might void the camera warranty. Sincerely, however, it's unlikely that a lens error will qualify for the warranty.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Nov 16, 2011 | Nikon Coolpix S210 Digital Camera
BATTERY is fine, but lens barel will not extend and lens open when I hit the open button
Problem with the lens stuck; is common defective that need new lens unit replacement or just repairable.
How to Repair a Lens Error: As scary as a lens error might seem, there are some easy fixes. Before trying any of them out, however, first take a good long look at your camera warranty and maybe have a chat with the company. If the lens error will be covered under the terms of the warranty, go for it. Even some of the simple fixes mentioned below might void the camera warranty. Frankly, however, it's unlikely that a lens error will qualify for the warranty.
Additional details could find in this article link: fixing-lens-error-on-digital-camera.html
Keep us updated.
May 31, 2011 | Cameras
Lens error restart camera / lens will not open
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Feb 10, 2010 | Canon Powershot SX110 IS Digital Camera...
Lens error
that could be the lens cover not opening all the way, try and look at the lens as if you were doing self-portrait, and power on. if lens cover opens all the way but lens doesn't come out, the lens might be stuck or motor broke.
Sep 06, 2009 | Canon PowerShot SD850 IS Digital Camera
Lens won't open, & it says lens error, restart camera.
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try
Jul 24, 2009 | Canon PowerShot A560 Digital Camera
Powershot A80 error E18
Lens errors (E18 errors on Canons) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
Jan 05, 2009 | Canon PowerShot A80 Digital Camera
Lens error: Lens is stuck open when I power on.
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Dec 29, 2008 | Nikon Coolpix S50c Digital Camera
Lens Error
Dec 17, 2008 | Nikon COOLPIX L4 Digital Camera
Lens error
wheni go to turn on my camera it says"lens error"on the screen and wont turn on lens is "stuck"open.
Nov 26, 2007 | Nikon COOLPIX L3 Digital Camera
Canon PowerShot A560 Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
