Question about HP Vs17 17" LCD Flat Panel Monitor
My hp monitor keeps going dark every time i turn off the monitor and the whole computer but i can still see the background of my monitor but it keeps going dark
  • 11,361 Answers
Please read below if you are going to DIY repair so you will know what to look for inside.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed HP monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on May 12, 2010
My second computer monitor keeps going dark
Most likely backlight circuit failure....
Oct 18, 2015 | Dell Computers & Internet
Erratic display
So your Gateway is brand new or a refurb?
Aug 02, 2008 | Computers & Internet
Monitor goes blank less than a second after turning on.
Sounds like either there is a bad connection from the computer to the monitor, or the monitor has a faulty power regulator, causing the monitor to overheat prematurely, and shut off.
Feb 21, 2008 | Proview PL926WBi 19" LCD Monitor
When I start the computer the Windows XP Logos light up on the Monitor (HP w1907) when the computer starts the Logo disappears and the monitor goes to sleep
If this monitor (HP w1907) is going into sleep mode the normally blue power led will change to yellow. This indicates loss of video signal or possible out of range resolution. If the picture goes dark and the power lite stays blue, you have a backlight malfunction. It can be an inverter power fault but this model mostly has worn out backlights causing a shutdown condition.
Monitor Mike
Aug 19, 2010 | HP vs19 (Silver) 19" LCD Monitor
My hp monitor keeps going dark every time i turn off the monitor and the whole computer, but i can still see the background of my monitor but it keeps going dark
qalmar1217, Power supply may be bad and need some work done on it! First, go visit this site and do some reading. http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/ I suspect your monitor no different than what you will be reading about. Your symptom(problem) not new. In fact it happens to be an epidemic disease among CCFL back-lit lcd monitors of all brands. Do some research in my fixya profile and you will see what I mean. Good luck with the repair. Come back here if this was of some help to you and rate this response. 12fixlouie
Mar 17, 2010 | HP Vs17 17" LCD Flat Panel Monitor
My hannspree hs257hps monitor keeps going dark after a short period of time. I can turn it off and on and it works for a while but after a few minutes it goes dark again
backlight inverter is loose or bad.. dissasemble and check..shile a light on it while it is dark , but still on ..just like you would with a laptop
Jan 10, 2010 | Hannspree 22" widescreen LCD Flat Panel HD...
My screen keeps going dark like it is going to sleep
Right click on any free space of desktop and go to properties and go to Screensavers tab and click on Power Tab and select Never in Turnoff monitor option and click apply OK.. now it will not go dark..
Soluzia.net
Jan 07, 2010 | HP f2105 21" LCD Monitor
Monitor will sometimes go dark
This is a hardware problem inside the monitor.You need to open up the monitor and Resolder dry contacts inside.
Dec 30, 2008 | HP w1907 LCD Monitor
Monitor going black
HP's are known for bad capacitors in the power supply.
Replacing them is simple if you know how..not so simple if you don't.
Try your local TV repair centre. It should not cost alot to have the capacitors replaced.
Hope it helps =)
Apr 06, 2008 | HP Pavilion F1903 19" Flat Panel LCD...
HP Vs17 17" LCD Flat Panel Monitor Logo
101 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
