Question about Oki Electric Industry C6150N Laser Printer
OKI C6150 Paper Jam Issues
When trying to print anything the printer will receive the data start adjusting temp and then the error 391: Paper Jam will pop up. Usually opening the front cover and then closing it will fix the problem and allow the page to be printed but when a new document is sent to the printer it will once again get the error code 391. The rollers are in good shape and the printer is fairly new. There is never any paper jammed it just always gets the error. Any help?
Okidata error 391
That's a paper feed jam in tray 1. Try cleaning the feed roller and separation pad or just replace them
Jun 25, 2014 | Oki Electric Industry C6150N Laser Printer
I get a 391 paper jam on my Oki C5200 printer all the time
Hi
Try turning the printer off and on.
Look through the paper paths and remove any visible stuck papers.
Clear any print queues.
Solved?
Disconnect printer from power for a few minutes and then connect it again.
Feb 27, 2012 | Office Equipment & Supplies
Error code 391 paper jam - no paper jam though. Open front cover and close and that resets machine but when you try to print error code 391 again!
Check the area where its showing the paper jam to see if there are bits of paper there. Most of these issues are caused by tiny pieces of paper blocking the sensors.
May 04, 2011 | Oki Electric Industry C6150N Laser Printer
I have a OKI C6150 got a jam now I have a Fatal #980
Inside fixing unit are also thermoswitch and thermistor wich can burn out, but also the fixing lamp too. You must dissasemble it and by DVM test the circuits, if the circuit is opend on thermistor, that means that he is burnd out.
Jul 08, 2010 | Oki Electric Industry C6150N Laser Printer
Says a front paper jam but no paper jammed any where
Your paper feder belt has ink on it and will not feed the paper. Remove the rubber belt and clean it good and clean and use compressed air on the printer tray area. If this does not work open the front feeder tray and set your computer to print from it. After about 500 copys it will normally have c leaned itself and be ready to feed from the main roller.
Feb 14, 2010 | OKI C5500n Printer
Okidata C6100 getting an error 391
It means paper jam in the 1st paper tray. Check above the pickup roller sometimes, paper will get jammed in there good.
Jul 08, 2009 | OKI C3200n Led Printer
Fatal error 980 OKI C5500 printer
I had a paper jam and removed the jammed papers. The paper jam cleared and then the Fatal Error 980 appeared. OKI C5500 printer
Mar 15, 2009 | OKI C5100n Laser Printer
Paper jam
try by reinstalling the drivers, if the printer gives the same error then your printer need to be serviced
May 30, 2008 | OKI B4250 Led Printer
Error 391: paper jam
See below for Error 391:
CLEANING THE FEED ROLLER AND THE PAD
Clean the feed roller and the pad when [391: Paper Jam] appears frequently.
(1) Remove the paper cassette.
(2) Clean the feed rollers (large and small) with tightly wrung wet cloth or an LED lens cleaner.
Note! An LED lens cleaner is enclosed in an optional replacement toner cartridge.
Feed roller (large)
Feed roller (small)
(3) Clean the pad on the paper cassette with tightly wrung wet cloth or an LED lens cleaner.
Note! • If [392: Paper Jam] appears frequently, clean the second tray (option) in the same way.
• If [390: Check MP Tray] appears frequently, clean the feed roller of the multi-purpose
tray in the same way.
Pad
Apr 04, 2008 | OKI C5200n Laser Printer
Error LED blinking after paper jam, won't print
I have a similar but different model B4300. Several others, & I have found that a small piece of paper 1/2 square may lodge under a plastic guide, holding open a switch. This is very difficult to notice if you don't know where to look.
Open top lid
Remove the ink cartridge/roller drum as a single unit.
Look in the printer at the metal roller in front.
A Plastic strip on top & in front of the roller covers 2 square holes which should look dark. On your LEFT, as you face the unit, there is a small magnetic switch, to the LEFT of the LEFT square hole, under the plastic.
In my case, the paper was seen as white in the hole, and extended under the switch. I was able to grasp it with a small medical forceps, next to the switch. By gently twisting, I pulled it out without taking the unit apart.
The printer then worked perfectly after the paper under the switch was removed.
Dec 13, 2007 | OKI B4100 Laser Printer
Oki Electric Industry C6150N Laser Printer Logo
609 people viewed this question
Top Oki Electric Industry Office Equipment & Supplies Experts
Tony
Roger Binsfeld
Victorman
Victorman
Are you an Oki Electric Industry Office Equipment and Supply Expert? Answer questions, earn points and help others
