Question about Brother HL 1440 Laser Printer
I just replaced drum and toner and now will NOT
Brother hl 1440 I just replaced drum and toner and now will not print at all! Never happend before!
    President:
  • 1,961 Answers
Reset it
Please try this
There's two ways to reset it
First: Soft Reset
1. Open front cover.
2. Hold down button located under LED's until all LED's are lit.
3. Release button and make sure drum LED is off, then
4. Close cover
Second: Factory Reset
1. Turn the printer off.
2. Hold in the circular button on the front panel of the printer.
3. Turn the printer back on.
4. When the DRUM light is lit by itself let go of the button.
5. Hold in the circular button on the front panel again.
6. Once the Alarm light comes on, let go of the button.
This will perform a factory reset on the printer.
I hope that's everything you want.
Please accept this answer if this will help you.
Thank you for using Fixya.
Please rate this answer and leave testimonial too!
Thanks
Posted on Nov 21, 2010
PRINTER DRUM ERROR
The drum unit needs to be replaced as it has reached maximum prints for the drum.
The drum unit is the carriage part that the toner unit sits in before it is put in the machine.
Aug 29, 2014 | Brother HL 1440 Laser Printer
Brother HL 1440 How do you change printer drum
The printer drum (photoconductor) is part of the toner unit.
There is a button on the left side of the printer.
Push the button. The front will open up.
The drum unit and toner can be pulled out.
Remove the toner unit from the drum.
Install the toner unit into the new drum unit.
push the whole unit back into the printer.
Feb 14, 2011 | Brother HL 1440 Laser Printer
Changed the drum & ink cartridge in HL-1440-ink bleeds on edge
This problem is often caused by spilled toner. Open the printer, carefully remove the cartridge, and give it a few bursts of compressed air. Often running several pages or type through will also fix this. If it persists, replace the toner cartridge.
Hope this initial info/idea helps. Let me know for any clarifications.
Jul 08, 2010 | Brother HL 1440 Laser Printer
Brother HL-1440 copies have light layer of toner on left side of
You are nearing time for a drum replacement. Here is link to the Brother site for your printer. Be careful when purchasing drums - I made the mistake of buying an after market drum kit and after 100 prints was replacing it again with a OEM part.
http://www.brother-usa.com/Accessories/Accessories.aspx?Model=HL1440&ACASCID=12
Feb 02, 2010 | Brother HL 1440 Laser Printer
The drum light came on constant my Brother HL-1440. I changed the drum and also put new toner in, slid the cleaning button back and forth. But I still have the drum light on constantly and the print is...
Could be a defective drum, but do the reset first, Open the front door and hold the go button until the lights flash and it will be reset. after that just shake the toner and hope for the best...
Aug 10, 2009 | Brother HL 1440 Laser Printer
Prints ok, but dirty page. Happened suddenly. No lights are on. HL 1440.
The problem is with the toner ow paper feeding. Proper feed the papers, if that dosn't solve you may have to change the toners. It is best that you put a new one. If that dosn't solve then thre cables must have got damaged. Send it to Repair.
Mar 24, 2009 | Brother HL 1440 Laser Printer
Black horizontal lines in printout
Seems like the drum needs changing. This is the most common cause for print problems in these printers. If using the high yield TN 6600 toner then you need to change the drum every 3-4 toners. If using the low yield TN 6300 toner then the drum will need replacing every 6-7 toners. Hope this helps
Nov 16, 2008 | Brother HL 1440 Laser Printer
Toner
Likely thing is that you have a faulty toner cartridge return it to the store and ask for a replacement in exchange as yours is faulty. IF this does not cure the fault then maybe the drum unit causing the fault and this may need replacing.
Thanks J
Jan 24, 2008 | Brother HL 1440 Laser Printer
Brother HL-1440
(blinking every 5 seconds) Toner Low Indicates that the toner cartridge is nearly empty. Purchase a new toner and have it ready for when Toner Empty is indicated. (solid) Toner Empty Replace the toner cartridge with a new one. User's Manual is available at the following location: http://www.brother-usa.com/Data/Documentation/Printer/User/UM_HL1440_1450_1470N.pdf Hope this helps.
Aug 22, 2007 | Brother HL 1440 Laser Printer
Brother HL 1440 Laser Printer Logo
413 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
